05-03-2022, 07:45 PM | #1 |
Member#: 422024
Car won’t start after clutch install
So here’s what I have going on. Replaced the clutch and flywheel on my 2015 wrx. Install went smooth as far as I knew. Put everything back together and the car won’t start.
The starter engages and the motor spins, just can’t get it to start. I went over everything and all my grounds and harnesses are connected. No CEL either. Any ideas?
05-04-2022, 03:04 PM | #2 |
Member#: 517987
Did you disconnect batter before clutch job? If you did not, possibly some fuse got blown while unplugging things, check all your fuses under the hood and under the dash first.
