04-26-2022, 01:45 PM | #1 |
Member#: 529215
Vehicle:2012 WRX Limited Sed 37j White Pearl |
04 FXT 4.44 final drive into a 2012 wrx 5 speed?
I have a whole 04 fxt transmission that is broken and irreparable since the clutch fork pivot hole cracked into pieces. its a 4.44 final drive
I want to put the 4.44 final drive into my 2012 5 speed, but I cant figure out if the transfer gears would also go with it since I need 1:1 gears instead of the 1.1:1 that should be in it already. ppg makes a 4.44 final drive that seems to go into all post 1998 subaru transmission so I assume that the actual final drive gears fit in, but I dont know if I can just swap the transfer gears too. if anyone has any input it would be much appreciated I then need a 4.44 final drive rear diff but that shouldnt be too hard to get my hads on.
04-26-2022, 01:53 PM | #2 |
Member#: 515308
I’m looking forward to the 390 in my new to me 2011 wrx over my current 4.44 05fxt
04-26-2022, 02:48 PM | #3 |
Member#: 529215
whys that? i dont mind the 3.90 but i wouldnt mind some more pep. i dont mind nvh or anything like that
04-26-2022, 03:46 PM | #4 |
Member#: 515308
It’s a lot of rpm on the interstate and first is gone before you can get close to spooled, I like a longer gear with a turbo
04-26-2022, 06:12 PM | #5 |
Member#: 529215
interesting, i have the same ratios as the sti ra gears, so i think having the 4.44 would be like that. probably okay for my uses
