05-19-2022, 08:50 PM | #17951 | |
Member#: 58504
South East
Vehicle:2004 STi Aspen White / Silver |
12k BTU single zone units can be found for well under $1k. 2-zone 2x 9k BTU units run in the $2-3k range. I was just looking at a 2-zone 2x 12k BTU unit for about $2650.
05-19-2022, 09:30 PM | #17952 |
Member#: 85327
RMIC
Vehicle:1964 Miata Hairdresser Red |
05-22-2022, 12:56 AM | #17953 |
Member#: 52314
South East
Vehicle:... 02 and 04 WRXs! 2020 G70 3.3T RWD |
The growing amount of PT wood I need to replace on my deck and on my shed ramp is quite depressing. Also, pretty sure I killed a rather large holly bush with some lawn weed killer due to drift of the mist. It's not looking too good after a few weeks now.
05-22-2022, 04:10 AM | #17954 | |
Member#: 4103
Vehicle:2016 Mazda6 Red |
Wait to see if it's truly dead until next spring. |
05-22-2022, 10:05 AM | #17955 |
Member#: 52314
South East
That's what a friend who has a degree in some form of herbology said. They annoy me in how much I have to trim them, but definitely didn't want to off one or two of them.
05-22-2022, 11:10 AM | #17956 |
Member#: 4103
05-22-2022, 06:14 PM | #17957 |
Member#: 177235
NWIC
Vehicle:2016 Focus RS 2002 WRX Wagon |
My street-side outdoor faucet was working last weekend. The water company came out and replaced our water meter while they were flushing the hydrant.
My street-side outdoor faucet is no longer working, but the one in my backyard is. Water pressure inside the house is fine. The water came out clean after they flushed it no sediment or anything. As far as I can tell there is no pressure getting to my faucet. I pulled the valve and turned the water back on and nothing, just a little bit of a trickle that filled up the faucet but wasn't enough to even make a drop come out of the open hole where the valve normally sits. I pulled the faucet out from the wall and there's a pex connector behind it, and an elbow connecting that to the wall line. Couldn't find a shut off valve or anything for that specific faucet. Something stupid I may be missing? Or time to call a plumber? |
05-22-2022, 06:18 PM | #17958 |
Member#: 34670
South East
Vehicle:2016 slowmobile |
Call the water company. Say maybe it's a coincidence, but....
They might send somebody out to investigate. |
05-22-2022, 06:24 PM | #17959 |
Member#: 58504
South East
Sounds like some crud got into the line during the switchover and ended up in the branch feeding the faucet.
If it is a clog, turn off the water at the meter, and open a couple of the fixtures. Blow compressed air into the clogged faucets. That might be enough to dislodge the clog. Might take several cycles. |
05-22-2022, 07:04 PM | #17960 |
Member#: 1910
NESIC
I was quoted between 5 and 6k per head. Window units it is still
05-22-2022, 07:15 PM | #17961 |
Member#: 90804
SCIC
Vehicle:2021 Ascent 2012 Accord |
f4 is quoting the price of the unit, not the installed price.
05-22-2022, 09:58 PM | #17962 |
Member#: 58504
South East
Well f**k. That's double the quote I got for a 2-zone (2 head) system. It was $6k installed. Yes. If I end up having to replace mine, I'll be doing it myself for about $2600 for the system I have picked out.
Bonus...if I DIY, I'll have HVAC in my workshop. |
05-23-2022, 10:48 AM | #17963 |
Member#: 92634
RMIC
05-23-2022, 10:53 AM | #17964 |
Member#: 90804
SCIC
I think you got a good deal shik.
05-23-2022, 04:44 PM | #17965 |
Member#: 53222
Vehicle:'10 Genesis Coupe '99 Miata |
I want to DIY mini deck/stairs for above ground pool. Something like that https://www.etsy.com/listing/1074549...search_click=1
Do I have to dig 4 feet holes and pour concrete under every post, to get under frost line in northern Illinois or those $10 concrete deck blocks will be enough? |
05-23-2022, 05:23 PM | #17966 |
Member#: 292403
Vehicle:2012 Legacy Graphite |
Frost line. Sorry
Wish I could give ya the latter answer but you want longevity |
05-23-2022, 05:58 PM | #17967 |
Member#: 90804
SCIC
Footings for sure. Sorry bud.
05-23-2022, 06:23 PM | #17968 | |
Member#: 58504
South East
Just dug down about 3ft and no concrete. But of course, no frostline here. |
05-23-2022, 10:06 PM | #17969 | |
Member#: 21356
NESIC
Vehicle:2017 Subaru Corolla STI Limited SE-R Type (R) |
What about using concrete form tube? Make hole, add gravel and compact, insert tube, pour concrete that you mixed in a 5 gal bucket? Be sure to add fibers or rebar. |
05-23-2022, 10:07 PM | #17970 | |
Member#: 21356
NESIC
05-23-2022, 11:00 PM | #17971 | |
Member#: 58504
South East
I wouldn't think a tube form would leave enough space to add rebar without it being too close to the surface of the concrete. Seems like enormous overkill for such a lightly loaded deck post. What am I missing? |
05-24-2022, 04:17 AM | #17972 |
Member#: 4103
05-24-2022, 07:47 AM | #17973 | |
Member#: 21356
NESIC
I need to fix the deck footing on my house. The concrete on the top side is spalling. If its just the top and exterior areas, Ill be learning how to resurface concrete this summer. |
05-24-2022, 07:47 AM | #17974 | |
Member#: 21356
NESIC
05-24-2022, 07:59 AM | #17975 |
Member#: 292403
The only time you need rebar in concrete is for foundations and pads.
You should not have to use rebar in deck footings if you do it properly. Just rent an auger from HD for the day. Drill down 4 feet. Get quick dry concrete where you just pour that **** into the hole, and then pour a gallon of water. Center your posts. Let it dry and cut the other bull**** out If you have flat land and want lazy, get a few of those TuffBlocks. They say they can be used/ suitable for that type of ground, but don't blame us if that **** sinks into the ground over time. |
