05-20-2022, 10:54 AM | #1 |
Member#: 323166
Vehicle:'17 WRX |
Access to pressure plate bolts?
Hello all! I just finished swapping my oem clutch in my 2017 WRX limited and had a question. I went with the ACT SB11-HDSS kit which has a new pressure plate with a lightweight flywheel as well, and followed all oem torque values for when re-assembling the car. Since I have access to alldata and oem service manuals, it made it easier. Anyways, I also referred to the ACT install video and realized they said to torque the pressure plate to 26 ft. Lbs, which is substantially higher than the OEM values. The video had M8 bolts but I realized I have M10 bolts. After I put it all together and test drove it, I realized the sheet of paper it came with said that the M10 should actually be at 50 ft. Lbs. Is this going to be a massive issue or can I just pop the starter out and gain access to one of the 6 bolts at a time, re-torqueing them? I realized the clutch in the video they used was a lower-grade one which explains the M8 bolts. Clutch feels excellent right now since I also switched out the fork and pivot for chunky billet ones.
05-20-2022, 01:11 PM | #2 |
Member#: 323166
Vehicle:'17 WRX |
Anyone know of an access hole I can see the edge of the pressure plate if I cannot see it through the hole in the bell housing where the starter goes through?
05-21-2022, 01:54 PM | #3 |
Member#: 283429
South East
Vehicle:2016 Fuji Sunfire 03 Silver |
I think you are confused with sizes. Based on the ACT specifications for that flywheel the kit included 8mm bolts for the cover. In fact ALL the ACT flywheel for 2017 WRX have 8mm mount holes for the clutch cover.
The flywheel to crankshaft bolts are 10mm and about 50 ft.lbs. sounds about right for a single torque - older ST/WRX were about 54/55 IIRC. I think the Subaru spec for that model is actually a torque angle for the OEM bolts. You try to torque those cover bolts to 50 ft. lbs. and you're going to be pulling the transmission or engine back out. |
