Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 01-21-2018, 07:49 PM   #26
Edrev24
Member#: 476744
Default rust repair panels
ive got a 2002 wrx and has typical rear quarter panel rust. in looking for repair panels. do you offer them for purchase?
Edrev24 is offline   Reply With Quote
Old 01-31-2021, 06:27 PM   #27
Jerfunk
Member#: 520442
2006 WRX
Steel Grey Mettalic
Thanks for this thread! Now I just have to work up the courage to try it on my car...
Jerfunk is offline   Reply With Quote
Old 03-10-2021, 03:58 PM   #28
FXT_WRB
Member#: 521901
I have an 08 forester in WRB that has slight bubbling on the driver rear quarter panel, any idea on where to get replacement parts to weld in for that?
FXT_WRB is offline   Reply With Quote
Old 03-15-2021, 10:40 PM   #29
JoeNobody
Member#: 493377
dumb question whats bubbling?
JoeNobody is offline   Reply With Quote
Old 07-12-2021, 12:30 AM   #30
hoodscoops
Member#: 525480
Originally Posted by zkhennings View Post
I have rear quarter panel rust and fender rust. I am going to cut out the rust and weld in patches. I have some epoxy primer and evercoat putty in the mail. I haven't done this before in an area where it aesthetically matters, I have only ever welded in patches for returning strength to rusted metal. I am going to document what I do here to help anyone else out, and ask some questions too probably.
For example, I have no plan on how the repaired areas will end up WRB again. the Grimmspeed aerosol cans look good, but I have never had much luck with air curing paint sticking to actual paint. There is also quarts of color matched WRB for 80 bucks. I could also just have a body shop do the final paint and blend also, or get paint color matched by a body shop.
So I will update this soon, I may cut and weld today. I am planning on stitching spot welds to attach the panel to prevent any warping and excess heat, and then I will grind down the weld bead, shoot a layer of epoxy primer with reducer so that it seals properly, then I will use the putty to smooth everything, shoot some final layers of primer I can block sand, and then figure out what I will do for the WRB.
I have never blended paint exceptionally well before, I plan on having a gradual feathering of the paint when I sand so it is hard to tell where the jump is. Would it be beneficial to do some high grit wetsanding after the color is shot, and before the clear? to help smooth out the transition?
edit... nevermind
hoodscoops is offline   Reply With Quote
Old 07-12-2021, 12:30 AM   #31
hoodscoops
Member#: 525480
nevermind
