06-10-2021, 10:49 PM | #76 |
Member#: 139693
Vehicle:Dura ngo 95 horrorshow |
If driving dynamics are high on the list there will only be one. If max capability is a higher priority it will be another. It all depends on what you are going to do with it. Then you weigh the pros and cons after driving each. It was a very easy decision for me.
06-11-2021, 11:03 AM | #77 | |
Member#: 192568
Vehicle:'23 F150, '23 Camry '21 RAV4 |
06-11-2021, 11:37 AM | #78 |
Member#: 161333
Vehicle:135i vert fast leaf |
They need to come out with a Maverick Lightning.
06-11-2021, 11:50 AM | #79 |
Member#: 202642
RMIC
Vehicle:08 Impreza,80Vette 68 Impala, 15 SantaFe |
Spain, really? Ford said they won't be releasing the Maverick in Europe. If true, wouldn't those be subject to the Chicken Tax, unless they some weird final assembly in the U.S.
06-11-2021, 11:51 AM | #80 | |
Member#: 183032
Vehicle:RWD Camry Pull me over red |
I'm in no rush to pick up a truck (pun not intended, but I'm leaving it there), my FIL is retired, he just bought a Ridgeline I can have access to whenever I want, and he loves driving my IS (not getting in and out of it though). I'll let the trucks drop and see how the dust settles, maybe buy a toy to tide myself over. |
06-11-2021, 11:58 AM | #81 |
Member#: 202642
RMIC
Yep, you're right. I think it was rumored at one point but probably confused with the Bronco base engine. But probably an even better reason for Ford to offer it as a Maverick Raptor.
06-11-2021, 12:30 PM | #82 |
Member#: 183032
Focus RS drivetrain in a maverick, 6mt and all, while maintaining 4k towing and payload capacities? I'm in.
06-11-2021, 02:39 PM | #83 | |
Member#: 44501
Vehicle:that 's, like, your alternate facts, man. |
06-11-2021, 03:36 PM | #84 | |
Member#: 192568
But, to your point, and back to the Ford trucks, that's not enough to sway a lot of people. For example, I see no reason to get a Ranger instead of my F150, because the size different doesn't correlate well enough to the mpg change. The same goes for why I didn't buy a gen. 2 Ridgeline. Hopefully the Maverick, the 2.0T can manage 24-25mpg combined, but we will see. If I see one glaring hole in the product, it's that you either get FWD and great MPG, or probably low-20s. A truck this small would be better suited to a drivetrain that obtains 30mpg combined, but that may come later. If they'd only offered the 3cyl., we would all be dismissing it right away, so ballsy move on their part. |
06-11-2021, 03:58 PM | #85 | |
Member#: 161333
06-11-2021, 06:52 PM | #86 | |
Member#: 192568
Oh, for sure, I totally agree. The numbers tell a good story...the Ranger is 11" longer, with 8" of that being in the bed. The other three inches are probably in the front end, leaving us with a similar size cab between the two. The four door F-150 is 32" longer than the Maverick, and who knows how much wider. |
06-11-2021, 07:15 PM | #87 |
Member#: 4562
Vehicle:2014 Electric Datsun 2005 Adventure van |
06-13-2021, 03:51 AM | #88 |
Member#: 5673
BAIC
Vehicle:05 LGT, 02 WRX Hellcat CTR LC500 GRC |
Wonder what's the EV only range on the hybrid.
06-13-2021, 01:35 PM | #89 |
Member#: 44501
Yeah, a better gearbox and cylinder deactivation has helped.. but when larger trucks (F-150/Silverado/Ram) are getting better fuel mileage on the Monroney, it's a tough sell.
06-13-2021, 02:20 PM | #90 | |
Member#: 139693
They improved the cab significantly as well as the handling and driving dynamics. The current RL has a different drivetrain from yours and makes for an excellent handling vehicle. So much did change, especially how it handles. I owned a Gen 1. The Gen 2 is better in every way. You need 7500 lb towing then buy a full size truck then. When buying a vehicle there is so much more than a stat sheet. |
06-13-2021, 09:00 PM | #91 | |
Member#: 14913
TXIC
Vehicle:2009 Ford Ranger Red |
Ugh late night typing. the turbo motors are built in Ohio and Spain but assembly for all trucks is Mexico. |
06-13-2021, 10:03 PM | #92 | ||
Member#: 44501
My '10 (mid-model refresh) RTL (18" wheels) handles just great... but I have no interest in upgrading my Ridgeline for improved handling. It's frankly, the furthest thing from my light truck needs. If I was that concerned about it I'd buy something I could mod. Right now nobody makes better shocks for the Ridgeline of any generation. The OEM KYBs are the best option. Quote:
There is no truth to the claims that unibody trucks are less capable at towing than ladder frames. There is no glut of Ridgelines running around with bent frames. The ladder frames are popular for truck manufacturing because they're a significantly simpler platform on which to build niche utility components onto. Everything from Kei trucks to Semis uses ladder frames because they're easily produced in dozens of length/drivetrain configurations and the commercial market can tack on anything the industries need with nothing more than but some U bolts and L brackets. That's why they're the default for towing.. not because the unibody is somehow inferior. Tesla is advertising the unibody CyberTruck to be good for a 3,500lb payload and 7,500lb-10,000lb towing capacity in a package similar in size to the Ridgeline. When the Gen 1 launched it not only had the highest payload rating, it also had a higher towing rating than the Tacoma (it's only direct competition at the time). Toyota upgraded the towing package on the Tacoma (which rode like crap, but hey, it could suddenly tow 6,500lbs, although the payload remained to low to make it useful). I don't think it's unreasonable to suggest Honda can aim for upping the ante again. |
06-14-2021, 11:01 AM | #93 |
Member#: 202642
RMIC
One thing that I didn't realize until now is the length of the Maverick, 200" long. This is longer than many 7 passenger CUV's. Width is still narrower. Still trying to gauge the size of this in real life. The Ranger doesn't look that much smaller than full size trucks in real life. The Santa Cruz will be shorter at 196". I know this is meant to be a compact truck but really seems closer to a true midsize truck instead of the 3/4 size trucks the Ranger, Colorado, and Taco really are. Width seems to be the more deciding factor now when looking at exterior dimensions. Still think the Maverick is a good size.
But again everything seems to get bigger every couple of years anyways. I don't even know what compact, midsize, fullsize means anymore. |
06-14-2021, 11:02 AM | #94 | |
Member#: 873
TXIC
Vehicle:2020 JEEP / RAM Datsun 71 240Z & 68 2000 |
My Gen 2 Ridgeline got a legitimate 29mpg on the highway with my wife two kids and luggage. No turbo, no cylinder deactivation, nothing. Just a good reliable Honda engine. Honda still builds some of the best NA engines around. After my Accord, I fear for their electrical systems now... but I would buy a RL again... It would be foolish to not consider the Mav and Sante Fe though |
06-14-2021, 11:36 AM | #95 | |
Member#: 161333
The maverick is 10" shorter than the old Ford Explorer Sport Trac though, which never really seemed like a midsize pickup truck. I think the sizing is just right, but I'll wait to see one in person. |
06-14-2021, 04:23 PM | #96 | |
Member#: 202642
RMIC
06-14-2021, 04:24 PM | #97 | |
Member#: 44501
https://www.fuelly.com/car/honda/ridgeline |
06-14-2021, 05:27 PM | #98 |
Member#: 44501
I'm sorry about talking Ridgeline so much, yall.
The Maverick is going to make major waves in the truck industry. It seems like a near perfect package for the affordable driveways of the suburbs. Ford throwing a unibody truck into the North American market will have far more effect than Honda did with 16 years of Ridgelines. It being a hybrid with solid stats is going to appeal to even more folks. Ford is firing on all cylinders here. This year's product debuts has made me nearly forget all about their decision to ditch cars. |
06-14-2021, 05:48 PM | #99 | |
Member#: 873
TXIC
Now I am using the number calculated on the dash... so that accuracy may not be 100% guaranteed. I know it seems like it is on the high side. However on a road trip, I averaged 28.2 mpg and I backed that up when I filled up. The Ridgeline is a beast on the freeway. That graph was avg mpg combined man. My average tank MPG was 19 mpg with mostly city and just a tad freeway. So that graph is spot on. I said HWY mpg. |
06-14-2021, 06:39 PM | #100 |
Member#: 183032
Waiting for a uni-body Ranger replacement based on the new Explorer AWD w/longitudinal layout.... they could stuff an ecoboost V6 in it for the hot version.
