Old 06-09-2012, 02:50 PM   #1
mayozack
Member#: 321525
2017 WRX base mt
-wrx cvt; -FXT '14
Default 2012 Impreza hatch rattle/creak solution
Hi,
Have a 4 month old 2012 Impreza that started developing creaks and rattles from the hatch area.
To save some of you the time and trouble on where it is coming from, i will tell you how to solve your problem w the hatch and other rubberised components.
The trick is buying some silicon grease. The rubberised parts WILL dry and need to be lubed, but you need to use a grease that will preserve the rubber -- make it supple again. Pick up $3 faucet SILICON GREASE from Home depot.
Apply it to the spots circled on the pics attached to this post.
Obviously, if you find other parts of your car creaking -- such as the dash or piller, locate it and apply the silicon grease to the rubber/plastic component.
mayozack is offline   Reply With Quote
Old 06-10-2012, 11:55 AM   #2
nubsub
Member#: 313575
2012 Impreza 2.0i HB
Originally Posted by mayozack
Hi,
Thanks for sharing this. I'll definite ly look into doing this for all doors atoms point.
nubsub is offline   Reply With Quote
Old 06-10-2012, 01:37 PM   #3
IMPREZA 2012
Member#: 318422
2012 Impreza Limited
Oh my god thank you very much, i have this rattle for a long time ago and i didn't find it.
I will try it right now.
IMPREZA 2012 is offline   Reply With Quote
Old 06-12-2012, 03:15 PM   #4
sager
Member#: 309315
2012 Impreza Sport
Marine Blue Pearl
I would think that this would solve any squeaking or rubbing noises, but a hard metal sounding rattle? Wouldn't that require a removal of the plastic shroud from around the latch and loosening the bolts and moving the latch down such that the hatch is held more tightly against the opening in the body shell?
Has anyone yet moved the latch down to address the rattle sounds coming from the hatch? Don't get me wrong, I will try this...I just assumed the intermittent rattle sound was going to require moving of the latch.
Thanks!
sager is offline   Reply With Quote
Old 06-12-2012, 09:15 PM   #5
mayozack
Member#: 321525
2017 WRX base mt
-wrx cvt; -FXT '14
well, a squeak/creak could begin to sound like a rattle. And a rattle could have some components of a squeak. And a component that is supposed to have some give/flex cause a squeak and rattle.
But, by all means, if you find someone loose that shouldn't be, tighten it down.
As for other possibilities of "rattles" coming from the hatch area: check the plastic push in pins connecting the bumper to the rest of the car. Those tend to relax their grip over time/rough roads and may cause a rattling sound from the back.
But, i guarantee, those plastic/rubber bits will begin to dry sooner or later and you should apply silicon grease to them to prolong its life and mitigate unwanted noises.
Old 06-12-2012, 10:20 PM   #6
sager
Member#: 309315
2012 Impreza Sport
Marine Blue Pearl
Thanks mayozack - I was not trying to be combative, I realize it might have sounded that way. I was really more amazed that the problem could be something so simple. I will definitely give your method a try. Can you post a link to the silicone grease you mention?
Old 05-26-2020, 12:13 AM   #7
Luke0718
Member#: 515082
Default Creaking hatch on 2012 Impreza
I can't see the pictures on where to apply the grease. Could you possibly post them again?
Luke0718 is offline   Reply With Quote
Old 05-28-2020, 02:53 PM   #8
shane_c
Member#: 168062
2014 Impreza Touring
My rattle / squeak turned out to be the hatch spoiler. I took the inside trim piece off last weekend and it appears the outermost driver side bolt pulled it self through a bit and caused some play on that side. I installed a plastic washer and bolted it down and it's been quite since.
shane_c is offline   Reply With Quote
('11-'14) 2012 Impreza Rattle thread (and solutions...???) nubsub Impreza Forum 217 03-20-2019 01:41 PM
('11-'14) WeatherTech Mats for 2012 Impreza Waterlogged Impreza Forum 84 01-10-2013 07:22 PM
2012 Impreza cabin rattles Bsmitty5913 General Community 14 05-05-2012 09:52 PM
FS : OEM 2012 impreza hatch splash guard 2012WSP Exterior/Styling 1 03-24-2012 10:16 AM
