#1 |
Member#: 58433
![]() Does anyone know what gains if any can be expected from water injection with say 100 octane fuel ? I know the position with 91 or 93 octane but does the same apply to higher octane fuels?
#2 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
![]() Not a whole lot with something like c-16 which basically does not detonate. Remember there's no more energy in race fuel than pump fuel, just less likelihood of detonation.
#3 | |
Member#: 32636
Vehicle:2004 Impreza STi Silver/Silver |
![]() Quote:
offset |
#4 |
Member#: 62221
![]() aquamist says its will greatly help in-cylinder cooling. The only other thing that can do that is dumped fuel I think. My guess is better in-cylinder cooling = lower EGTs?
#5 | |
Member#: 18960
South East
Vehicle:02 WRX MBP It lives! ; ) |
![]() Quote:
...and bboy...VP C16 will allow detonation, I promise. ![]() S. |
#6 | |
Member#: 23676
NESIC
Vehicle:. |
![]() Quote:
You would still see benefits from reduced intake charge temps. Remember, cooler charge=denser charge. Denser charge= more power |
#7 |
Member#: 37934
![]() I asked this question of Richard L, the guy from aquamist, and he said that it will help in cooling the intake charge and EGT, but that is about it when used with race gas.
#8 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
![]() .....d0000ds....there is a B-I-G difference between 100 and c16.
W/A and 100 should be da bomb, if tuned properly. |
#9 |
Member#: 62221
![]() should be expensive
#10 |
Member#: 14141
Vehicle:2002 Impreza WRX |
![]() It depends on how much boost your setup can run. If your turbo can generate enough boost to reach knock limited power output on 100 + WI you would be making some serious power. It should be close to C-16 or possibly better.
If you are turbo limited so you do not need that sort of octane to reach the limits of your turbo, then it would be a waste of effort. Larry |
#11 |
Member#: 58433
![]() Thanks for the replies. My tuner does not believe in WI at all. Perhaps someone can do a dyno test on 100 octane fuel with and without WI-- if you chaps are right the results should convince him.
PS the turbo I have in mind is 700bhp capable--- certainly enough to test the limits of det on 100 octane fuel. Last edited by macaws; 10-20-2005 at 10:58 AM. Reason: error |
#12 |
Member#: 32636
![]() Some tuners will never warm up to WI. I have developed the impression that it can have great results on Subies. Especially for those of us who do daily driving on pump gas for sure.
offset |
#13 | |
Member#: 18987
NESIC
Vehicle:2014 Forester Dark Grey Metallic |
![]() Quote:
DP macaws, are you using just water, or running a mix, and what mix if you don't mind me asking. I am using methanol/water at about a 40/60 ratio. I love it much better than Denatured alc. DP |
#14 |
Member#: 23676
NESIC
Vehicle:. |
![]() WI rules.
I am running SMC's setup 50/50 water/alchy. Figure on in the area of 30whp on a "stage 2" STI once tuned. |
#15 |
Member#: 62221
![]() Dave did you install that kit yourself....if so how difficult was it?
#16 |
Member#: 58433
![]() [quote=DonkeyPunch]It's the shizzle
DP macaws, are you using just water, or running a mix, and what mix if you don't mind me asking. I am using methanol/water at about a 40/60 ratio. I love it much better than Denatured alc. [quote] I'm running nothing yet. I have a Rigoli Racing 2.35 short block on the way which I will run with race cams and the HKS T04Z turbo. Here in South Africa 100 octane leaded race fuel is the best one can get without importing special fuels at ridiculous prices--hence my question about WI specifically on a highish octane setup. |
#17 |
Member#: 14141
![]() WI needs to be used in a manner that is suitable for it. If you just throw WI on a car and make no tuning changes, you will likely see a small drop in power unless the car is already running hard enough that detonation is a problem and the ECU is pulling timing to protect the engine , simply adding WI will yield a small power gain.
There are basically two approaches to using WI ( with lots overlap between them). First you can run it to add a cushion of safety from detonation and make little if any tuning changes. In that case your probably better off with an alcohol injection setup or at least a high alcohol content mix of water and alcohol. Don't use more water than you need to give you a safety factor and your good to go. Add too much water and you are absolutely guaranteed to lose power due to the overcooling of combustion, especially if you are already running a tune that has a rich AFR. If you lean the mixture out toward 11.5 - 12:1 you will see some advantage to the WI and still have a moderately safe tune if the WI quits on you. The second approach is to use WI to raise the maximum cylinder pressures you can run without getting detonation. To do that you MUST tune for the WI. Typically you will add a couple of degrees of ignition advance and lean the mixture to a point that would be unthinkable without the WI. This is the boundary that many tuners simply cannot accept or will not even attempt. If done carefully you can lean a WI system to mixtures that would melt pistons on gasoline only and run safely and with much greater power on lower octane fuel PROVIDED the WI never has a problem. If you lose the WI due to a clogged nozzle or failed pump or hose while under heavy load and boost it will very quickly kill the engine. Failure of the WI under light load and this sort of tune will still give you time to recognize you have a problem. So bottom line you must decide how much risk you are willing to accept for how much power gain. WI tuned agressively will allow boost levels that can achieve a 50% to 70% increase in engine power. No that is not a typo!! but that is a very risky setup for the average user. Most do a compromise between the two. They tune a bit more aggressively than usual as if for a fuel octane 10 or so octane numbers above your normal fuel. (ie a 100 octane tune on 91 octane), and take reasonable measures to prevent WI failure. Some especially folks that live in very hot environments like the desert south west of the U.S. add WI and hardly change the tune at all. That gives them a car that runs like it is always a cool spring day, but if the WI fails they will probably not kill the engine. It all depends on where you fit in that range of acceptance of risk and hunger for power. Larry |
#18 |
Member#: 18987
NESIC
![]() Kinda what larry said, you are effectively making say 91 or 93 octane fuel about 100 octane on a conservitive safe tune, that if you have a failure, you can either,
A. Not drive the car hard until you fix the problem. B. Use a UTEC, and have a constigency map that runs with out WI or AI. I have my normal no WI VF22 maps on slots 1 and 2 and water injection maps on 3, 4, and 5. That way if I lose the pump or whatever, I can disconnect my pressure solenoid that kicks on the pump, and just run without WI on the regular maps. This has already come in handy as I had a leak that took a while to track down. I gained 30 HP and 30 Ft lbs on a dynapack on a EJ205 with a VF22, and am pushing 23 lbs of boost in 5th. That is about as far as I want to go pressure wise with this block and internals. So yes if you use the higher octane stuff with alcohol or methanol, you will effectively make the octane level that much higher. Be careful with leaded race gas as it will eventually ruin you 02 sensors. DP |
Power difference between water injection and alky injection? | scooterforever | Water/Methanol Injection, Nitrous & Intercooler Cooling | 10 | 06-21-2005 05:58 PM |
water injection and cobb stage 2 HWG map feels good !! | phamster | Water/Methanol Injection, Nitrous & Intercooler Cooling | 11 | 04-23-2005 03:01 PM |
Water/Methanol Injection or Race Fuel or Both | ejh25 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 03-28-2005 06:35 PM |
FS: EBC, Water Injection and voltage clamp | stevenh | Private 'For Sale' Classifieds | 3 | 09-19-2004 01:17 PM |
Water Injection AND Nitrous??? | annointed | Water/Methanol Injection, Nitrous & Intercooler Cooling | 1 | 10-20-2003 11:48 PM |
