Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 03-22-2023, 07:38 PM   #1
GodsColdHands
Member#: 465760
2017 WRX
Ice Silver Metallic
Default 2018-2021 STi Front Spoiler Template (PN: E2410VA030)
Hey there, I need the templates from this STi front under spoiler so I can mount it to my new car. It was installed on my previous car, but I threw out the templates once finished. I would like the templates so I can produce an OEM like install.
Also, does anyone know the name of the little rubber grommets that fit into the bumper during installation? I need to purchase more but don’t know the proper nomenclature to search for them. They are number three in the diagram below.
GodsColdHands is offline   Reply With Quote
Old 03-24-2023, 02:59 AM   #2
SpicyPeaNut
Member#: 43310
1978 Brat
Could you just line the lip up with the ends of the bumper, near the wheels? It should just sit in its happy spot and just secure it with some nuts & bolts etc.
SpicyPeaNut is offline   Reply With Quote
Old 03-27-2023, 08:33 PM   #3
Third Coast
Member#: 518907
2020 WRX
Ice Silver Metallic
After a little bit of googling I see a couple slightly different part numbers: 'E2410VA000 may be the part instead; but I'll list both guides below.
Found the install instructions outlined for the one you referenced (E2410VA030) here.
Guide for E2410VA000 is here just in case.
Also, not sure since everything will be the same since your WRX is a 2017, but there is another thread with an install guide for E2410VA000 on that located here.
Hope this helps.
Third Coast is offline   Reply With Quote
Old 04-10-2023, 11:58 PM   #4
GoFrogs
Member#: 507317
2019 WRX
Pure Red
Hope this helps.
To the OP, blue tape is your friend. As much as you need.
Since it was installed on a VA chassis car previously, the mounting holes should be the same, with some slight variations in some positions.
Get a roll of 2" wide painter's tape. put the tape on the underside of the front bumper so you can mark (with a black marker) where the holes need to be for the lip.
To help hold the lip on the bumper while you are marking holes (and being a one-man show), use the blue tape to hold the lip to the bumper in as many places you think are necessary. The tape can be repositioned as necessary.
Use three or four strips on each side. Then use several strips in the center. Then add another few strips btwn the center and sides. Again, use as much blue tape as you need.
Once you have the holes marked on the blue tape (that was on the underside), see how those marks line up with the factory markings and/or factory holes.
Once all holes are marked AND you are confident they are in the right place, the blue tape can be removed easily and w/o much fuss.
GoFrogs is offline   Reply With Quote
