Old 12-25-2014, 01:06 PM   #201
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
If you wanted to cut a huge hole in your hood, a heat exchanger could go there, almost like a v mount, then you could low mount thr turbo, and put tbe intercooler in the piping to the intake manifold.
Moore performance actually combined the intake manifold and intercooler into individual banks over each head, with the charge pipe in the middle.
Old 12-25-2014, 11:40 PM   #202
k mier
Member#: 98000
05 sti e85@420hp
No, you're absolutely right, room is going to be an issue. This is more with what I was thinking; type 26 ic, (15x6.5x6), long but not very wide mounted against the firewall and set low, right above the rear engine mount, and a heat exchanger similar to type 100, (24x12x1) but smaller, maybe 20x10x1, mounted on the hood beneath the scoop opening which measures around 18x6. The 1" thickness would be great but have yet to find one around that size. There might be room to mount a thin fan to the underside of the heat exchanger and still clear everything below.
A smaller exchanger and IC 'might' work and the smaller size would be nice but expected numbers for my build, once I get the drive to return working on her, should be in the solid 500+ range. I think that will require the larger rated cores.
... and yes, it would be nice to have the better throttle response loosing those 8' of IC plumbing should provide.
Just thinking out-loud, YMMV.
k mier is offline   Reply With Quote
Old 12-26-2014, 03:08 PM   #203
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
So with their S/C kit for the 86, Cosworth built a quad-pass heat exchanger to go in the front.
I've looked around and I can't seem to find anyone selling a quad-pass exchanger, has anyone seen such a think out there? I was tempted to buy one of the Cobra dual-pass ones until I saw the Cosworth one.
http://www.cosworth.com/media/452826...inImgLarge.jpg
Cosworth sadly won't sell me just the heat exchanger which is a bummer since it bolts right up.
dwx is offline   Reply With Quote
Old 12-26-2014, 04:37 PM   #204
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
The frozenboost one is a dual pass, it looks like that one is two of the same style stacked together. That would be huge, and would probably be overkill unless you are over 1200 hp at the crank.
Old 12-26-2014, 04:44 PM   #205
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
If you really want the scoop mount location, there really is no need for awic. A good top mount air to air (spearco, ETS) have been shown to work into that power range. They will suffer heat soak, but so will anything top mounted. Granted it will take longer to heat awic, but will take longer to cool down also.
Old 12-26-2014, 07:24 PM   #206
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I don't think dimension wise it's that large. They built the kit to handle 20-30 minute track sessions, so they felt they needed a large surface area and the quad pass heat exchanger. I believe they started with a dual pass and it wasn't sufficient. This is with a TVS900 blower running at almost max RPM. The system also has no reservoir.
Old 12-26-2014, 07:35 PM   #207
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Having no resevoir is why it needs to be that big.
Also it could be 1 inch thick as opposed to 2 to 4 inches thick. If you have the frontal area to run something like that go for it.
Old 12-26-2014, 09:22 PM   #208
Type2
Member#: 200436
2004 Forester XT
Originally Posted by dstroy View Post
It's a type 26 core, the turbo is a gtx3582r with a .82 tial v band turbine housing.
20gpm pump and reservoir in the trunk, 3/4" lines. GM iat sensor.
I forgot to ask. Are you running a radiator, if so, what kind? Also, what kind of pump are you running? Thanks.
Type2 is offline   Reply With Quote
Old 12-27-2014, 11:10 AM   #209
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
Type 101 heat exchanger, meziere 20gpm pump mounted in my trunk next to my reservoir.
dstroy is offline   Reply With Quote
Old 12-27-2014, 11:12 AM   #210
dstroy
Member#: 283711
2012 STI sedan
I had the large 1" thick radiator for a while, and with ducting it would probably be great but just mounting it up and sealing the edges around it to the condenser it didn't work as well as the ones that go in the usual fmic location
Old 03-10-2015, 08:06 PM   #211
slomofo
Member#: 134180
04 FXT
Gold
Sorry to bump an old thread, but out of curiosity, are you guys running fans on your heat exchangers?
I have an 04 Forester and I don't want to cut my bumper up, but I don't think I'll have room to mount a fan behind the exchanger. Can I get away with custom ducting to route my air dam opening into the exchanger?
slomofo is offline   Reply With Quote
Old 02-11-2016, 11:01 AM   #212
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
It has been a long time since I posted here. Time for a very small update. I haven't changed anything. Only maintenance I have done was top off the system about once a year. Other than that, no issues. I am currently doing a hybrid build, and the core type I have will not flow enough for the new setup. I have a type 14 sitting here which will do the job nicely. Since I'm doing a little work on the car, I am going to take the fender mounted reservoir box out and add on in the trunk, along with a better pump. I suspect that I will also edit the way the exchanger is mounted. I cut the bumper beam to get it to fit and that has bothered me since day one. I want to spend some time and see if there is a better option.
svynx is offline   Reply With Quote
Old 02-18-2016, 04:56 AM   #213
vicious_fishes
Member#: 158864
2003 SOHC destroker
the type 14 gives around a 60 degrees C reduction in intake temps
Old 02-18-2016, 05:29 AM   #214
mwmplayboy
Member#: 241755
1998 2.5RS
Brilliant Red
Saved for future reference. Once I build up some funds, I'll be reworking my setup.
mwmplayboy is offline   Reply With Quote
Old 02-18-2016, 11:25 AM   #215
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
Good to know. I wasn't worried about temps as much as the CFM issue I'd run into by using the core I have now. Going from the stock TD04 to a 41lb/min turbo.
Old 02-18-2016, 07:14 PM   #216
mwmplayboy
Member#: 241755
1998 2.5RS
Brilliant Red
Has anyone thought of using the 12L Spec C intercooler tank as a reservoir? It has a pump installed from the factory, but I'm not sure if it would work for an AWI setup. I know people have converted them to work for meth injection. They are pricier than the frozenboost.com reservoir, but are "factory" products and look pretty slick.
http://www.rallysportdirect.com/part...-sti-2002-2007
Old 02-19-2016, 08:10 AM   #217
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
I originally looked at that tank when I built my system. I'm sure that it could be modified to work, but I thing that at that point you might as well go with something that is designed for the job. You'd have to put a different pump on as the stock one won't flow enough. Then add a hole or two depending on how the new pump was mounted to get water in and out (not just the fill point, which would work beautifully as it looks like it would be the highest point in the system).
Old 02-19-2016, 12:51 PM   #218
wrxhard
Member#: 108091
I knew I recognized your user name when I looks at your "budget baller" build thread... HAH!!!
wrxhard is offline   Reply With Quote
Old 02-19-2016, 01:09 PM   #219
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
LOL. Always nice to hear that there is some recognition on this site for us lonely people.
Old 02-19-2016, 01:44 PM   #220
mwmplayboy
Member#: 241755
1998 2.5RS
Brilliant Red
Tried to look up your build thread on the NASIOC app by going to your profile.
Relevant?
http://i.imgur.com/AG02oV4.jpg
Old 02-19-2016, 01:49 PM   #221
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
Relevant?
Not sure why it's saying I don't exist. Clearly I'm here.
Build thread is in the Built Motor Discussion. Hybrid build.
Old 02-22-2016, 03:25 AM   #222
vicious_fishes
Member#: 158864
2003 SOHC destroker
Yes, and I was going to do exactly that, but there's an easier option: get a wagon washer fluid reservoir, pull the rear window pump out, and feed the water line through the *perfectly* round hole that now remains.
A quick squirt of silicone around the join and 24 hours to let it set and you're in business
The 14 will be more than enough. We've been using the 13 with a 50lb/min for years.
Old 02-22-2016, 09:03 AM   #223
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
Interesting. I currently am using the type 13 (450cfm max). From what I've read, the TD04 flows around 390-400cfm. The 41lb/min Blouch turbo I will be using flows around 593 cfm (using the 1 lb/min = 14.47178cfm equation), and that is the reason I have the type 14 (700cfm). Going by that, the type 13 would choke the turbo on the higher end. I guess it's more of a sustained use vs anything else.
Old 02-22-2016, 09:19 AM   #224
vicious_fishes
Member#: 158864
2003 SOHC destroker
I don't think they rate them by cfm meaning "choke" but rather, approximately how pressurised the charge can be before the IC simply can't cool it enough/is overwhelmed. Obviously how hot the charge gets depends on a lot of stuff so they kind of have to make a bit of a guesstimate/ballpark on what the IC can handle with some underpromise built in so people don't start buying gear that loses them performance.
But the 14 and the 13 are like $10 different so if you've got the room there's no reason not to run the 14. Bigger IS better here
In my case with my N/A manifold I only have room for the 13. I tried to get them to custom fab me one but no luck, so I'm now considering running twin coolers with one on top of the IM and one down where the battery is mounted from the factory. The fantastic thing about water cooling is that you can mount the cooler(s) anywhere you want.
Old 02-22-2016, 10:23 AM   #225
svynx
Member#: 210371
2002 hybrid 16gxt
'03 Lifted TS
I'll have to play around with the 14 to see how it fits. Even with the stock manifold, there isn't much room for the 13. It's close to the A/C lines. I'd really like to turn the compressor side 90 degrees and have the output in a vertical position. Would make it easier, and shorter, to route the I/C pipe to the passenger side, but that can't happen with the turbo I have. So, I'll keep the routing I have now the same.
I do plan on purchasing an expansion tank, bolting that to the firewall, and using that to fill and service the system. I don't like how I have it now, and I think the expansion tank will look better.
What the heck is this on his intake manifold? air/water intercooler?? STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 03-25-2003 12:27 PM
STi air-water intercooler?? kotaro Legacy Forum 22 12-19-2002 01:51 PM
Air/Water intercooler install, any suggestions? BlueDemon South East Region Forum 3 08-25-2002 09:39 PM
Air/Water intercooler? FuZZyLoGiC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-29-2002 11:45 PM
Interesting Air/Water intercooler thought Legacy GTR Normally Aspirated with bolt-on Forced Induction Powertrain 9 02-13-2002 11:53 PM
