08-30-2003, 06:35 PM | #1 |
Member#: 38045
TurboXS exhaust melted my bumper
Has anyone else had this problem?
I had installed the full turboback and the tip doesn't go out past the bumper. Today at the race track + TurboXS turbo back = melted bumper. Has anyone added a steel plate to protect the plastic at all? Also when I downshift hard, about a foot and a half flame comes out. Thanks Rob |
08-30-2003, 07:46 PM | #2 |
Member#: 31748
Tri-State
Vehicle:'19 WRX STI Series.Gray |
i just put mine on a couple hundred miles ago. no black residue yet. hopefully i won't experience the same problem, but if there is a metal plate made where can i get one?
08-30-2003, 08:36 PM | #3 |
Member#: 3348
NESIC
Vehicle:2013 Polo TSi Red |
Scott (Supra98) has the RFL muffler and after a few sessions at NHIS his bumper too was melting.
08-30-2003, 10:14 PM | #4 |
Member#: 31748
Tri-State
if someone w/ some metal skills could make a piece to fit in the half circle about the muffler i'd be happy to pay someone. i could probably do it myself, but if someone has some experience and could mold a piece of metal that will withstand the heat i'd really appreciate it. ~nick
08-30-2003, 10:32 PM | #5 |
Member#: 39546
Vehicle:2010 WRX Sedan Blue |
I would think the manufacturer would be responsible for repair costs, if you installed it correctly.
08-30-2003, 10:40 PM | #6 |
Member#: 34416
Vehicle:2002 BMW M3 Alpine White |
Montreal STi
Failing that, could you just use some of the flexible insulator, such as commonly found in the engine bay of many cars? Remember what you had in your M3, that silver insulating blanket above the headers? |
08-31-2003, 12:11 AM | #7 |
Member#: 27812
Vehicle:2004 STi NESIC TrackH0z # 28 |
yup... meltorama
08-31-2003, 02:59 AM | #8 | |
Member#: 37184
Vehicle:2004 STi Silver |
Re: TurboXS exhaust melted my bumper
So sorry to hear about your damaged bumper. Hope you will be able to repair it nicely. Perhaps it is my thick skull, but this still doesn't sway me away from my consideration for a TXS exhaust upgrade. If you don't mind me asking... Where can I get TXS kits (TBE / TB Stealth) and get them installed professionally here in Canada?? Thanks, -Rich |
08-31-2003, 07:55 AM | #9 |
Member#: 3401
NESIC
Vehicle:2018 BMW M2 Mineral Ghey |
you, my friend should get this http://subydude.com/parts/details.php?8
08-31-2003, 08:16 AM | #10 | |
Member#: 31748
Tri-State
08-31-2003, 08:28 AM | #11 |
Member#: 38045
That is the concept of what I am looking for but not exactly that look. That piece looks pretty awful.
08-31-2003, 08:34 AM | #12 | |
Member#: 31748
Tri-State
08-31-2003, 08:38 AM | #14 |
Member#: 31748
Tri-State
japanparts has the same one as subydude for $51.17 before shipping. http://164.46.112.185/SubaruParts/ImprezaGDGG/Aero.htm
08-31-2003, 09:30 AM | #15 |
Member#: 38045
Actually I met a guy at the racetrack who is a machinist and he told me he could make me something custom made for a good price in high quality stainless.
If anyone else sees a good product let me know, on my end I will see what I can do with this custom piece. If it's good maybe I can get it mass produced for other STi'ers out there Rob |
08-31-2003, 10:13 AM | #16 | |
Member#: 31748
Tri-State
08-31-2003, 03:07 PM | #17 |
Member#: 34416
I was thinking something along the lines of this might be useful.
I'm not sure that a fixed metal guard will work because it will absorb heat, not reflect it, and get just as hot, conducting that heat to the bumper it's attached to. Insulator This link also has a number of insulators, heat blankets, heat shields, etc: more here Last edited by Mr. Grinch; 08-31-2003 at 03:13 PM. |
08-31-2003, 03:36 PM | #18 |
Member#: 31748
Tri-State
i don't think it will look so great wrapping the tip of my muffler w/ some material. the rest of the exaust fine, but the tip is the problem and wrapping it just doesn't seem to be a great solution.
08-31-2003, 09:09 PM | #19 |
Member#: 34416
Well given the choice between something that may not look great and a melted bumper, I'd probably pick the first. At least it's a cheap fix until a better solution is found. Also, it may be possible just stick some insulating mat on the bumper rather than the exhaust.
Other option might be if the exhaust tip (I have not seen it) had both an inner and outer piece, that way the outer piece could actually be insulated from the inner one, reducing heat transferred to the area of the bumper. Also, if people do find a suitable looking bumper guard made of metal, I'd wonder if it could be designed in a way that actually installs as a replacable valence installed right into a cutout in the bumper, rather than a tack-on piece. I'm wondering if anyone's contacted the muffler vendor and what they have to say about it, if anything. A small alteration in the tip design might be all that's required. |
08-31-2003, 10:12 PM | #20 | |
Member#: 13931
Vehicle:02 WRX 13 Boss 302 |
Re: Re: TurboXS exhaust melted my bumper
09-01-2003, 01:45 AM | #21 | |
Member#: 37184
Re: Re: Re: TurboXS exhaust melted my bumper
But, I will check out Worldoneperformance.com. Thanks for the tip. I may, after all, have to order parts from them. -Rich |
09-01-2003, 08:43 AM | #22 |
Member#: 31748
Tri-State
i think a piece that fits right inside the cutout would be an easy make for someone with experience. basically, if my thinking is correct: 1) make a template out of paper or something flexible and easy to cut, 2) trace the template onto a sheet of metal, 3) cut the metal, 4) drill 3-4 holes in the metal, 5) place the metal piece on the bumper, 5) drill holes in the bumper to match the holes, 6) screw the piece down. too me it doesn't seem too tough. my only problem is cutting the metal since i have nothing to do it with. someone around has to have experience or know someone who does. i just don't know anyone around here so i'm kind of out on devising the metal piece.
09-02-2003, 06:45 PM | #23 |
Member#: 31748
Tri-State
just want to get this back up to the top for everyone to see. please, if someone has or knows someone w/ metal experience let us know.
09-02-2003, 07:19 PM | #24 |
Member#: 13931
I'm interested as well since I just ordered a turboxs axleback, and plan on getting the stealthback next. I know it's a relatively new muffler, but I'm wondering why noone else has complained about it thus far. I wonder if it happens more often during continuous track use compared to daily street use?
(sorry no metal fabrication skills here ) |
09-02-2003, 07:31 PM | #25 |
Member#: 31892
I would like something as well. I have put 2000 miles on my car and it is only slightly discolored, but I have had zero track time. I do have a high flow cat installed.
That stainless bolt on contraption is hideous. Last edited by Hummer; 09-06-2003 at 10:17 AM. |
Similar Threads | ||||
So I melted my bumper | TheLegacy | Interior & Exterior Modification | 13 | 12-03-2005 09:35 AM |
Exhaust melting my bumper lip! Help! | wrathfirex | Interior & Exterior Modification | 10 | 07-27-2004 04:28 PM |
Melting my bumper? | Section 8 | Normally Aspirated Powertrain | 4 | 06-23-2002 02:38 PM |
New exhaust hangers- muffler now going to melt rear bumper? | annointed | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 19 | 04-25-2002 10:08 PM |
My exhaust is melting my bumper cover. | JC | Normally Aspirated Powertrain | 5 | 09-10-2001 08:47 PM |
