04-26-2018, 02:29 PM | #1 |
Vendor Sales Rating: (0)
Member#: 484813
Presenting the new AWE Exhaust Suite for Subaru VA/GV STIs. Available now.
Presenting the AWE Exhaust Suite for Subaru VA/GV STIs! BOXER® uncorked:
The Options: Touring Edition Exhaust: A direct bolt-on, full 3” straight-through design. The Touring Edition allows the WRX / STI to deliver its famous rumble without rasp or in-cabin drone, while introducing intoxicating crackles when shifting, thanks to AWE’s proprietary drone-canceling solution, 180 Technology®. This configuration compliments the EJ25 is every way. Seriously. Sound Perfection: AWE 180 Technology® Perfect tone, compliments of AWE 180 Technology®. As exhaust gases exit the EJ25 engine and flow into an AWE 180 Technology® equipped resonator, they pass through strategically located ports, and into reflection chambers. Sound waves, carried by these exhaust gasses, bounce off the walls of the reflection chambers. By controlling the size and location of the ports and the chambers, we also control when the sound waves exit the chambers. The specific timing of when the reflected sound waves rejoin the main exhaust flow creates a one-hundred-and-eighty-degree out-of-phase sound wave that cancels out problematic frequencies. Track Edition Exhaust: For those looking for take it to 11, and leaving it there, go Track. The Track Edition retains all of the precision engineering from the Touring Edition, minus the AWE’s 180 Technology®. The result? Unfiltered BOXER® rumble both in and out of the cabin. This version is known to get rowdy, and may be too much for many. For that reason, this particular version cannot be returned due to sound preference. Prepare yourself. Conversion Kits: We made it easy to convert from a Track Edition to a Touring Edition, or vice versa, if you decide at a later date to turn it up, or turn it down. Tip Options: All tip options include the AWE logo and double-walling to ensure a mirror finish even under hard usage. All tips are individually adjustable, allowing depth into the bumper to be set according to personal taste.
What’s in the box? Complete Touring or Track Edition Exhaust, four 102mm tips in chosen finish, and all necessary hardware for installation. Data: Here for discussion and questions!
__________________
Performance Specialist To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > 1.888.565.2257 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
05-21-2018, 01:58 PM | #4 |
Member#: 484813
Installation of the Touring configuration on a GV WRX with a catless Jpipe and ELHs.
__________________
07-23-2018, 11:08 AM | #5 |
Member#: 484813
__________________
11-21-2018, 12:30 PM | #6 |
Member#: 484813
__________________
12-26-2018, 11:32 AM | #7 |
Member#: 484813
__________________
05-07-2019, 06:21 PM | #8 |
Member#: 484813
We did our very first giveaway in our company's history a little while ago, and enjoyed it so much we're back for round two. This time, it's a bit more specific, and we decided to go with our Subaru line this time around.
Click here to head to our YouTube channel to enter.
__________________
11-15-2019, 05:19 PM | #9 |
Member#: 484813
__________________
Performance Specialist To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > 1.888.565.2257 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by AWE; 11-15-2019 at 06:44 PM. |
11-27-2019, 03:46 PM | #10 |
Member#: 484813
It's time to secure your deal. Until December 3, receive 15% off AWE Subaru products, valid through participating dealers and at AWESubaru.com.
__________________
12-02-2019, 12:38 PM | #11 |
Member#: 484813
Barreling down the final straight for special pricing. You have until noon on Dec. 3 to secure your deal! Get equipped here.
__________________
12-12-2019, 02:28 PM | #12 |
Member#: 484813
__________________
12-17-2019, 04:00 PM | #13 |
Member#: 484813
__________________
01-31-2020, 03:59 PM | #14 |
Member#: 484813
__________________
02-28-2020, 10:39 AM | #15 |
Member#: 484813
A recent Track Edition Exhaust install done here at AWE. Get more details on the AWE Exhaust Suite right this way.
__________________
03-12-2020, 12:47 PM | #16 |
Member#: 484813
Freshly-installed AWE Touring Edition Exhaust, courtesy of @khaki.sti. Get more details at right this way.
__________________
04-08-2020, 09:52 AM | #17 |
Member#: 484813
Boxer business with @geoff_merrritt.
***8226; AWE Track Edition Exhaust for the Subaru GV WRX and VA / GV STI Sedan [paired to an aftermarket DP]. Get more details on the AWE Exhaust Suite right this way.
__________________
04-20-2020, 05:28 PM | #18 |
Member#: 484813
__________________
04-22-2020, 04:44 PM | #19 |
Member#: 484813
Pipe up and rev ‘em loud.
Tag your rev videos with #AWERowdyRevChallenge on Instagram for a chance to be one of five winners to receive an AWE GearBox. Follow us on Instagram: @awetuningofficial
__________________
04-30-2020, 05:38 PM | #20 |
Member#: 484813
Freshly-installed AWE Track Edition Exhaust with 102mm diamond black tips, courtesy of NINE1FIVE Performance.
More details right this way.
__________________
05-08-2020, 03:56 PM | #21 |
Member#: 484813
#RumbleTogether with @atc_07 and the AWE Touring Edition Exhaust [paired to an aftermarket DP].
More details on the AWE Exhaust Suite right this way.
__________________
Performance Specialist To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > 1.888.565.2257 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. > To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by AWE; 05-08-2020 at 04:04 PM. |
11-30-2020, 11:08 AM | #22 |
Member#: 484813
Last chance to save. Secure your deal for your Subaru right this way, or through any participating AWE dealer.
__________________
