12-06-2020, 07:56 AM | #1 |
Member#: 519102
Suggestions for motor mounts
I have the engine out and about to put it back together. It’s an 05 OBXT with an AT daily driver. 170000 miles.
12-06-2020, 09:04 AM | #2 |
Member#: 395793
Vehicle:2005 92x Aero Beige |
Group-N are a good choice. Firmer without being harsh.
12-06-2020, 12:45 PM | #3 |
Member#: 519102
I’ve read that the group-N is not so good for an automatic transmission. Too much vibration.
12-06-2020, 01:39 PM | #4 |
Member#: 338131
RMIC
Vehicle:2003 wrx wagon black |
I would probably just get new stock. If group-n is too harsh there really isn't anything in between. You could see if the WRX and OBXT mount are any different
12-07-2020, 11:18 AM | #5 | |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
I agree. Firmer but barely any NVH. Ran these for most of 19 years with zero issues.
What exactly was this issue you read and where did you read it? |
12-07-2020, 02:39 PM | #6 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
Group-N engine mounts and pitch-stop mount and an OEM transmission mount with a urethane insert.
01-12-2021, 06:16 PM | #7 |
Member#: 519102
I got the Group N engine mounts. Does anybody know the torque specs for the mount to the plate? It’s not in the OBXT FSM. I would guess it’s 35 N m.
01-12-2021, 06:52 PM | #8 |
Member#: 395793
I have 26lb/ft in my notes. Not sure what that translates to in Nm as I don't have my wrench near me.
01-13-2021, 10:32 AM | #9 | |
Member#: 21145
NESIC
IIRC, it is 50 ft/lbs = 67.7909 NM
03-30-2021, 12:47 AM | #10 |
Member#: 519102
After 2 months of the group N motor mount and pitch stop, I think that the car feels more responsive. There is ever so slightly more vibration but nothing that is at all bad. So, very happy with them.
03-30-2021, 01:28 AM | #11 |
Member#: 67807
Keep an eye on your rear carrier around the rear diff. They are liquid and when they go it ****ing sucks and makes a mess. If your 5EAT has a habit of hard shifts in manual mode, it will wear that out. I had that go, an axle go, and a radiator go all within a few months of each other. Then the battery leaked.
03-30-2021, 07:37 PM | #12 |
Member#: 515308
04-17-2021, 11:36 AM | #13 |
Member#: 523629
Do the motor mounts have rubber boots around them? Drivers side on mine looks like it’s ripped and hanging, the passengers has no rubber around it. Does any other that make sense?
