#401 |
Member#: 96866
![]() 2019 wrx with approx 30,000miles has developed a timing chain cover leak on the drivers side. It also has the annoying 4th gear shifter vibration. Not too pleased with the issues so far.
#402 |
Member#: 504038
Vehicle:2015 WRX Grey |
![]() 2015 WRX 151,000 Miles. Stage 1 and still going strong!
#403 |
Member#: 394856
#404 |
Member#: 330407
![]() 2016 stage 1+ 150 000km
Blown on #2 cylinder rod bearing. All other bearing looked like new. Don't know what happened |
#405 |
Member#: 515430
Vehicle:2017 WRX Premium '19 X3 M40i |
![]() 2017 WRX Premium 6MT. Bought it bone stock at 5,000 miles.
Went Stage 1 (intake + Cobb OTS map) at 12,000 miles. Went Stage 2 (turbo-back exhaust + Cobb OTS map) at 30,000 miles. Went full bolt-on (intercooler, SoCal turbo upgrade, headers, EBCS, bypass valve, TGV/EGR delete) at 43,000 miles. Car currently has 45,000 miles. No problems whatsoever, though I don't drive it hard that often. I had a CEL for low voltage to O2 sensor (I think - it was a while ago), but cleared it and haven't seen anything since. |
#406 |
Member#: 251061
SCIC
Vehicle:18 Trek 6mt, garage queen 15 WRX 6mt |
#407 |
Member#: 486921
Vehicle:2018 Outback Tungsten |
![]() 2018 WRX base model
about to roll over 29000 miles 3000 mile oil changes with motul 8100 efe 5w30 w/ subaru oem filter Protuned since 9000 miles at Bren Tuning, EGR/TGV delete with GS EBCS ~315whp, protuned again at 21000 for Cobb Flex Fuel kit, ~365whp on E60 So coming around 30,000 miles I'll be doing my 10th oil change, the car has been reliable with no issues what so ever. I switch between Ethanol and 93 octane pretty regularly for the mpg's and extra power when ever I feel like it. I'll be looking at the sparkplugs and transmission fluid per Bren's recommendations, might replace the spark plugs if they're out of spec for gap or fouled in any way. My only issues I've really investigated was a loud clicking and jolting when the wheel was at full turn, going forward or reverse coming from the differential or CV boot. I went to the dealership about it but they couldn't hear it or replicate it. They went for a drive instead of just trying it out in the parking lot so they really missed the point. Although, hey say they didn't see any CV boot leaks or tears, no grease seen otherwise. The issue went away when I swapped out for winter tires but it came back when I swapped for summer. I think the issue stemmed from the stickier tire being less forgiving when at full turn and the diff fluid being cold causing a lock up. One thing I have noticed is a "plopping" sound when at idle from what I think is the cylinder closest to the driver side. It kind of sounds like the engine is going "plop, plop, plop, plop". This started thousands of miles ago but I'm not sure when exactly. At first I thought it might have been piston slap but youtube videos were hit or miss, some sounded like it, others didn't at all but mine was faint comparatively in any case. I know the DI system sounds like a typewriter and this definitely isn't that. It doesn't sound like rod knock or spun bearing as many youtube videos don't sound anything like my plopping. When I got my car inspected I asked a dealership tech about it and he said he couldn't hear anything through his stethoscope and he thought it was injectors. I have no knock or DAM drops especially since I started running Ethanol. I thought it could be the fueling so I swapped back and forth between Ethanol at ~60% and 93 octane (10% Ethanol) with no real change in sound. I think its getting louder or more pronounced but I don't recall if it was this prevalent before so I don't have a good reference. The plopping goes away when you apply throttle and the sound doesn't seem to carry into the rev range at all, just at idle ~750rpm. My idle is stable with no real fluctuations, the sound doesn't change much when the air compressor kicks in. Either way I'm gonna check spark plugs and stuff, maybe an injector is getting fouled up but my AFR isn't noticeably different. No CEL's or data abnormalities from what I can see. I might be overreacting to this or my engine is just wearing in but my friend's brand new WRX with less than 2000 miles doesn't sound like mine, its the exact sound minus this plopping. |
#408 |
Member#: 511751
TXIC
Vehicle:2017 WRX Silver, Flat gray |
![]() 92K on 17 wrx 6 speed. New clutch and TOB at 30K. No issues, until last week. I believe I lost 6th gear syncro but i'm no transmission guy. I assume its a major teardown so I will be pinching some pennies, and driving a 5 speed for a few weeks. Still can engage into 6th gear, but with any power the stick is knocked out of spot.
Best car I've ever owned though! Edit* car is all stock. even the tune... |
#409 | |
Member#: 431550
Vehicle:2016 WRX ALL THE STAGES |
![]() Quote:
#410 | |
Member#: 511751
TXIC
![]() Quote:
Ive grown up a bit since then....85 at 3800rpm , will be just fine for now ![]() |
#411 |
Member#: 487805
![]() 2017 WRX 6MT bought brand new with 9 miles on the odo
20k miles: Installed Borla S-Type catback 30k miles: MAP Stage 1 93 octane 35k miles: MAP Stage 1+ 93 octane, MAP intake, Perrin turbo inlet hose, Boomba BPV 40k miles: MAP Stage 2 93 octane, MAP catted downpipe, Perrin EBCS Pro, Perrin sump restrictor, Crawford AOS 46k miles: Installed Process West Verticooler and charge pipe Car currently at 47k miles, no issues to report. Only occasionally knocks when the AC compressor kicks on, giving -1.41 & -2.81 on the FBK & FNL but otherwise it rarely gets a knock reading and has only dropped DAM from bad fuel (different gas station). |
#412 |
Member#: 488146
SWIC
Vehicle:2015 WRX Red |
![]() 2015 6MT got it new when inused to work at Subaru with 6 miles on it shes sitting around 42k only issue was clutch fork chirp, they replaced the entire clutch with the throw out bearing fix.
Went MAP stage 1 at around 39k, waiting for a GS catted J and EBCS and TGV/EGR deletes. |
#413 |
Member#: 500337
![]() 2018 wrx premium
300mi stg1 MAPerformance 91oct no problems whatsoever 1500mi stg2 etune 91oct - first oil change 0w40 3k Flex tune stg2 91oct/e50 25k later car purs like it did at 3k Oil changes every 5k with 0W40 lubricant, overdue by 100mi now. |
#414 |
Member#: 320473
Vehicle:11 Wrx DMG |
![]() 2020 wrx 6mt bought it with 7 miles on dash ,
Now at 1123 miles AEM intake Perrin charge pipe N1 catback AEM 340 E85 pump Perrin BPV Tvg deletes on the way Egr on the way Boost controller on the way Process west intercooler on the way. Catted J pipe on the way. Tuned by Clark turner . |
#415 | |
Member#: 500975
![]() Quote:
#416 |
Member#: 520469
![]() 700 miles, hasn't blown up yet.
#417 |
Member#: 419593
#418 |
Member#: 500337
![]() 31k on the engine, about 28k on straight e50, no regular tanks in between. Not one problem to report yet.
#419 |
Member#: 450713
Vehicle:2017 WRX Stage 3ish world rally blue |
![]() 109k 17' wrx
50k on FBO with a phatbotti tune and running strong, no flex fuel |
#420 |
Member#: 418242
Vehicle:2017 WRX |
![]() There is a TSB for that. Not sure when they implemented the fix in production, but just Google for wrx 4th gear shake/rattle TSB and you'll easily find it. Requires splitting the trans case and replacing the 3rd/4th gear shift fork assembly with a thicker stronger one and a bushing or sleeve. Covered under 5yr/60k mile powertrain warranty. Had it done to our 17 wrx and no issues since.
#421 |
Member#: 418242
Vehicle:2017 WRX |
![]() Am I the only one to notice if you sort by Cobb Stage 1 OTS and MAP Stage 1 OTS none of the MAP tuned engines have blown and several Cobb tuned engines have? I know it's a small sampling and subject to the truthfulness of the one submitting the data, but still.
#422 | |
Member#: 311622
Vehicle:2020 WRX Lapis Blue |
![]() Quote:
Anybody having any issues with MAP tunes ?? |
#423 |
Member#: 431550
![]() I ran the MAP tune for a while before my old stg 1 pro-tune. I wanna say 20k miles worth on the MAP stg1? ran well. I would only see FBK if i held 4k rpm. Not sure why but nothing crazy.
#424 |
Member#: 311622
![]() Nice! I just got the COBB AP along with the MAP tunes .just haven't installed it as of yet .
#425 |
Member#: 522084
![]() Model/Year:2016 WRX Base
Milage: 48000 EM: pro-tune from ETS in CT Mods: AEM intake Perrin BOV Mishimoto TMIC Grimmspeed E-Boost Control Perrin headers Turbo back Invidia R-400 COBB AP Fuel: pump 91 Oil: full synthetic 5w30 Circumstances: accelerating 50% throttle onto Autobahn A3, was feeling a loss in power. Noticed my AP said my FKL was -9.5, heard the engine just cough and complete loss of power. Actual engine failure: threw a rod and broke the short block |
