07-22-2020, 09:10 PM | #26 |
Member#: 516353
I'm swapping my 02 bugeye wagons trans right now it is a 4.11 jdm legacy trans and The diff it came with was a 4.44 which I thought was a mix up. Should I just get the 4.11 LSD or???
07-23-2020, 08:37 AM | #27 | |
Member#: 138994
Vehicle:2006 WRX, 6MT, 5x114 |
If it was mine I would spend extra efforts making sure the installed parts all match up. Even if that means opening up the Rdiff cover and pulling the extension housing to count teeth. What trans code is this JDM legacy 4.11 5MT (TY75######)? As far as I know it should be a 1.000 TR 5MT. Are you absolutely certain that the R160 that shipped with it is a 4.444? Simply going with which R160 ratio "sounds right" might risk damaging that 5MT. |
09-06-2020, 01:26 PM | #28 |
Member#: 165335
RMIC
Vehicle:2002 RS Dirty |
Clutch slave?
I'm doing a 2004 4.44 tranny into my 2002 RS. Reverse of the OP's swap
The only snag has been the clutch slave. On the 02 Tranny the slave mounts ahead of the clutch fork, on the 04 it mounts behind. Clutch fork is the same part number for both.... I can't see how that would work the slave mounted aft. Thoughts? |
04-14-2021, 03:37 PM | #29 |
Member#: 522778
Vehicle:2003 Wrx Sonic yellow |
a bit of death rising myself here... but i recently purchased a 4.44 with the matching diff. Im super excited.
i keep reading about the speedo sensor. do i need to swap them out? put my cars sensor into the 4.44 or leave the 4.44 in and plug it into my car? |
04-14-2021, 03:45 PM | #30 | |
Member#: 395793
Vehicle:2005 92x Aero Beige |
Depends on what model and year it came out of. |
04-14-2021, 03:59 PM | #31 |
Member#: 522778
Bummer, i have no idea. how do i find this out? will the code tell when where and when it came from? The shop i purchased the transmission told me "this is a direct bolt on for your 2003"
I was given this car with a bad transmission and been working on this car since December. the light is the end of the tunnel Will check the code when i get home |
04-14-2021, 05:15 PM | #32 |
Member#: 395793
If the trans has the code on it still then you can look it up. Cross reference the trans code with info on Rallispec's website. They have most codes listed in their data base
04-14-2021, 05:41 PM | #33 |
Member#: 522778
jk-ty755vb5ba
Thanks for the xhart. According to that chart, says it 04 |
04-15-2021, 08:33 AM | #34 |
Member#: 522778
soo... forester cross sport 04... which sensor?
04-16-2021, 09:01 AM | #35 |
Member#: 522778
nobody?
