03-01-2018, 11:20 AM | #1 |
Member#: 458401
Vehicle:2005 WRX Black |
05 WRX Swap to 4.11 Help
Alright so I am basically just in need of some clarity. Over the past 3 days I have been on Nasioc, google, ebay, craigslist, etc. searching for transmissions, gear ratios, final drive, and researching what the best transmission for me is. I have read many forums stating that the 4.44 just isn't good for a dd car, and that the 3.90, 1.1-1, 3.54 in the stock 05 wrx should have been the 4.11 or 4.44 setup for various reasons. I believe I have decided on the 4.11 transmission. The code is 4S-TY754VBBBA. I read that you would need to use an auto wrx rear diff with the 4.11 ratio. I found an 02-03 for a good price. From what I have read my car has a pull style clutch, so does this trans, so I know that's good. Now the things I want to make sure of are
- Will the shift linkage from my 05 wrx swap over to this transmission(it does not come with the shifter)? - Will the 02-03 auto wrx diff fit properly(I believe I read that my axles will fit into this diff, please correct me if I'm wrong there)? - I know that for the front axles I need something different, mine are male on both ends currently, and this trans has stubs. So should I be getting 04 wrx axles then? - and finally which driveshaft do I need to be using my stock 05 wrx, or do I need an auto wrx ds? I've read in some places where an 02 wrx swapped to this trans using the stock 02 wrx 5-speed ds, and a 04 wrx that used and auto ds. Just want to make sure I have what I need. Any input would be greatly appreciated.
03-01-2018, 12:26 PM | #2 |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
OK, so this is what you have:
4S-TY754VBBBA JDM WRX / WRX STi MY 1999 - 2000 3.166 1.882 1.296 0.972 0.738 1.0:1 transfer gear 4.444 rear diff p/n 27020AA050 would be a matching rear diff from a manual transmission You would use your OEM WRX driveshaft The shift linkage would be a direct swap Whether or not the 3.90 vs. the 4.44 rear diff is good all depends on if it is goof for YOU and what you want it for? |
03-01-2018, 01:10 PM | #3 | |
Member#: 458401
This jdm 4S-TY754VBBBA trans is 4.11 ratio, shouldn't I be matching that with a 4.11 rear diff and not a 4.44 rear diff? |
03-01-2018, 02:43 PM | #4 | |
Member#: 21145
NESIC
That transmission is for a JDM Legacy Turbo, MY 2001 - 2003 It does have a 4.111 final drive. The rear diff p/n I listed above is the correct rear diff p/n. Everything else is the same |
03-01-2018, 03:07 PM | #5 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
why dont you adjust your tire size its alot easier... ifn you are really interested in the gearing though, my 98rs had a 4.11 fr its a r160 on a 1.1 center diff so yeah there you go. it did suck on the freeway though
03-01-2018, 03:26 PM | #6 | |
Member#: 458401
03-01-2018, 03:31 PM | #7 |
Member#: 458401
Huh, from what others said about the 4.11 on here it seemed to be a good "middle man" for both dd and those who want better acceleration. Lots said that its not bad on the highway compared to the 4.44(being in the ballpark of 3200-3600 @ 70-75 mph). My reason for looking into this is I believe my transmission is going out. I'm not having any issues shifting into any gear, but it sounds like a piece of something is moving around in the trans/diff, only when the clutch is out and driving though. The second the clutch is put in to come to a stop the noise stops as well. I looked into the possibility of it being the TOB, but its almost brand new and sounds farther back than its location.
03-01-2018, 06:58 PM | #8 |
Member#: 333468
RMIC
Vehicle:93 SS - 06 OB XT 03 WRB GD 205/22T 20G-XT |
I love my 4.44 for DD. Isn't bad on the freeway at all, but everyone is different. The higher rpms don't bother me.
03-01-2018, 07:40 PM | #9 |
Member#: 458401
Hey just out of curiosity what rpm do you sit at going 70-75? I really like what I heard about the acceleration of the 4.44 setup, and I actually found a 45k mile trans/diff for sale cheaper than the 4.11. I drive mostly small city, but go on road trips and i currently sit around 2700-3000 at 70-75mph. Thanks for chiming in on this
03-02-2018, 12:40 AM | #10 | |
Member#: 333468
RMIC
Longest road trip I've done so far is about 7 hours. Also, my car is pretty damn loud, lol. |
03-02-2018, 09:34 AM | #11 | |
Member#: 458401
03-02-2018, 08:27 PM | #12 |
Member#: 333468
RMIC
Approximately 3150 rpms @ 72 mph. This is on stock 16" rims w/Blizzaks. My speedometer seems like it is correct when I have driven past indicators. It's a JDM cluster but has been flashed to read in mph. Dang, car is dusty, lol. |
03-03-2018, 12:27 AM | #13 |
Member#: 458401
Thanks for taking the time to post that information man! I really appreciate it. I spoke to a jdm trans dealer today and they said the 4.11 transmission must be paired with a 4.11 diff, however I have seen a trans/diff combo of 4.11 with 4.44 diff on ebay(I know ebay's not the best place, but I was looking all over). The company stated that they have helped with many of these swaps and also selling them and that it would destroy the transmission to run a 4.11 trans with a 4.44 diff, because the rear diff can't be a higher ratio than the front. Do you know that to be true as well? I'm assuming that has something to do with the T.R of 1.0 in the trans? The company's name was JSAMotors.
03-04-2018, 12:27 AM | #14 | |
Member#: 124252
TXIC
Vehicle:0506 STI/Tribeca OBP/SGM |
I have a 06 Outback XT 5spd with 4.44 and matching diff. I also have a legacy GT with a 4.11 and matching diff. Ill sell either of them I did a forester xt 4.44 into a 03 wrx. It was a blast on the street. |
03-04-2018, 01:20 AM | #15 | |
Member#: 29292
SCIC
03-04-2018, 04:35 AM | #16 |
Member#: 479808
Vehicle:02 Impreza wrx 2.0 Grey |
Yes both diffs need to be the same to match, jist like for any 4x4 rear needs to match up with front because of tooth count... cant hsve 42teeth in rear with 39 infront...faster rotation in the back vs the front ...which in return will screw the tranny up...unless u put bigger tires on the front to make up for the rotational lost...still wouldnt recommend that because tire size would be way bigger
03-04-2018, 06:54 AM | #17 |
Member#: 379271
Please please inform yourself. ..... don't listen to these people who say 4.11 always needs rear and front matching diff ratio....
Only one perfect and accurate way to find out ..... Pull of the transfercase plate and count the teeth on the transfer gear A transfer gear is a gear that moves power from the gearbox to the center diff There is only 2 options... subaru came with a 1:1 center diff ratio that means back and front need to be matched ...and the other is a 1:0:1 I think.... can't remember the exact number but what the other one is besides the 1:1 is like having a 3.9 front diff with a 4.11 rear diff If u have a drop gear/ transfer gear with a drop in different ratio it means u have to match it to the % of the drop gear... LISTEN UP this is were people get it trouble BIG TIME .....like me once apon a time.... U can't go by what is specified on the gearbox part number because that gearbox is 20 years old ..... in 20 years a lot of parts internals could be changed like what happen to me. I was driving with a 4.44 front gearbox and a machinic said I'll find out what your front diff ratio is ...Witch was OK to do but. ..he didn't know that some jdm gearboxes have a drop gear in the transfer case meaning it's not a 1:1 ratio ...It was a 1:0:1 or some other number So what that ment was I needed to put in a diff ration with 19 or 25% difference. . After mechanic put the wrong different gear ratio it was low on power and 80% front wheel and only 20% rear diff active... Center diff didn't know what to do and went through 2 center diffis and many other parts ...this costed me 7 to 8 k in a waste of money because no one explained this .... Can't explain anymore will touch on it tomorrow need to go to bed for work tomorrow But on also reading about 4.44 being not good for DD I call big ass rubish on that ... 4.44 is awesome I kill ls1 having 240rwkw and my gf8 only had tbe and vf22 untuned.. Also did 12.8 1/4 mile untuned 14psi... 4.44 is the magic number that makes a subaru come alive .... no suprise Honda cars have 4.11 and lower even to 5.11 ...thats why Hondas are so quick and good |
03-04-2018, 12:15 PM | #18 | |
Member#: 21145
NESIC
He has no idea what he is talking about. Like many of us already said, you have to match your rear diff ratios to your transmission ratios, inclusive of the transfer ratio. I provided you the p/n of the rear diff that matches your transmission. Also remember I said IF you buy from a reputable importer, not some hack off of e-bay. Take this statement, for example, "There is only 2 options... subaru came with a 1:1 center diff ratio that means back and front need to be matched ...and the other is a 1:0:1 I think.... can't remember the exact number but what the other one is besides the 1:1 is like having a 3.9 front diff with a 4.11 rear diff " Subaru has a 1.0:1 ( 1:1 ) and a 1.1:1 ratio. That's it. Then he said that having a 3.90 front diff gets matched to a 4.11 rear diff?! Do that, and you'll trash your transmission. 3.90 front diff with a 1:1 transfer gear needs a 3.90 rear diff. |
03-04-2018, 03:02 PM | #19 |
Member#: 29292
SCIC
I disagree with the reason why the are so fast is because of the gear ratios. it all depends on what you are looking for, for the 1/4 mile you want to shift as little as possible. So you want to set up your gears so that you are at the height of 3rd gear at the very end of the run. that is what will make you fast. also one thing i have noticed is that when you do lower your gear ratio, you need to adjust your wastegate duty as you are taking away some of the load that helps to spool the turbo
03-04-2018, 03:53 PM | #20 | |
Member#: 458401
03-05-2018, 10:38 AM | #21 |
Member#: 416107
International
Vehicle:2002 WRX Wagon EJ207 Spec C 4EAT |
get a jdm suretrac lsd rear diff. i got one for my 4.11 R160 setup and it is badass.
03-05-2018, 11:11 AM | #22 | ||
Member#: 210371
Vehicle:2002 hybrid 16gxt '03 Lifted TS |
03-05-2018, 06:38 PM | #23 | |
Member#: 458401
09-01-2019, 08:45 AM | #24 | |
Member#: 505867
Idk how to use this forum yet
Did you have any success with this swap? I’m doing it in my 04 Wrx as of now. Did the stock Wrx clutch work for you? Thanks! |
09-01-2019, 12:56 PM | #25 |
Member#: 29292
SCIC
you know what you can do too is get smaller tires. instead of 205 55 16 get 2055016 it does make a difference and not too much difference in cruising speeds
