Welcome to the North American Subaru Impreza Owners Club Tuesday May 18, 2021
Old 06-01-2016, 03:41 AM   #1
dglebke
Member#: 448060
Default adjusting headlights
so I ordered new stock headlights for my bug eye... they shine a lot in the trees lol how do I fix this?
dglebke is offline   Reply With Quote
Old 06-01-2016, 05:39 AM   #2
rallyart
Member#: 343725
There is an adjustment screw behind the headlight. The adjustment should be done with care and consideration for on coming traffic. There are tools to get this adjustment correct but you may achieve a decent result if you use a wall or garage door to adjust the headlight aim. Please take consideration for oncoming traffic.
rallyart is offline   Reply With Quote
Old 06-01-2016, 11:06 AM   #3
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
See that philips screw with a hex head above the two gears (just to the bottom right of the turn signal bulb base):
satrya is offline   Reply With Quote
Old 06-06-2016, 10:01 AM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
The wall or garage door should be 20' away to get good alignment
Samurai Jack is offline   Reply With Quote
Old 01-28-2021, 11:47 AM   #5
Jaws4God
Member#: 521646
2003 Impreza WRX 207
02C, 42C World Rally Blue
thank you! i'll look again!
Jaws4God is offline   Reply With Quote
Old 03-10-2021, 05:39 PM   #6
65Jeffrey
Member#: 408808
is there an "industry standard" for point of aim at 20"? 10ft maybe?
65Jeffrey is offline   Reply With Quote
Old 03-11-2021, 11:00 AM   #7
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Roughly take 25ft distance to a wall, on a flat surface, and aim so the "elbow" of each headlight's low beam is pointing about 2" lower on the wall than the height of the low beam center from the ground. Here's one step by step guide: https://carfromjapan.com/article/car...rd%20direction.
If you use a projector low beam, the "elbow" is that first bend from the lower side (left in this case) to the higher side:
Note that with both low beams on the vehicle, it will look a bit fuzzy because of the overlapping patterns of both (left & right) low beams. You can cover one headlight at a time with cardboard to make it clearer. See an example of the overlap here, especially when the wall is close:
If you have freeform reflectors, like the OE bugeye headlights (with dual filament for low + high beams), then the "elbow" may be a bit difficult to discern. Covering one headlight at a time will help more than in the projector case imho. Here's one using the OE bugeye's low beams. You can almost spot the two elbows; the one on the right side is just a little to the right of that vertical beam on the wall painted white.
Old 04-17-2021, 03:45 PM   #8
Thedogmother
Member#: 523760
Do they all have this adjuster? Anyone know how to adjust on the 2009 Legacy?
Thedogmother is offline   Reply With Quote
Old 04-19-2021, 11:05 AM   #9
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
There should be. From used parts classifieds (like this one below), that grey round metal part with hex screw head below and between the high and low beam bulb service openings seem to be the pitch adjuster.
https://www.ebay.com/itm/GENUINE-OEM...EAAOSw3AFgZziN
