03-31-2015, 12:35 PM | #1 |
Member#: 388969
E85 DI high pressure fuel pump
Hi guys, I'm on my second HPFP using E85 and I know many of you have had pump failures do to lack of lubrication of factory pump and a 30% increase of pump. Does anyone know if any manufacture is working on making an E85 compatible high pressure fuel pump? I was one of the first E85 WRX back in June of 2014 and two pumps in one year total. If anyone has any solutions please let me know!
03-31-2015, 12:42 PM | #2 |
Member#: 341546
South East
Vehicle:2015 WRX CWP |
Probably shouldn't run fulL e85.
03-31-2015, 12:49 PM | #3 | |
Member#: 348254
SCIC
Vehicle:2013 WRX SWP |
There are a few companies that have e85 compatible pumps. DW for instance does. In addition, you can run an additive to the e85 to provide the needed lubrication. I know for certain tuners (Clark Tuning, for example), this is a requirement of their tune. This is quite nonsensical. |
03-31-2015, 01:02 PM | #4 | |
Member#: 388969
03-31-2015, 01:26 PM | #5 |
Member#: 393545
Vehicle:2015 WRX (6MT) DGM |
03-31-2015, 03:01 PM | #6 | |
Member#: 348254
SCIC
Check out some of the supra and n54 forums. Those guys have multi-pump E85 options. Also, do you have info on the lucas treatment causing premature wear? I have never heard that, but would be very interesting in looking into it since Ill be doing another e85 conversion in the future. |
03-31-2015, 03:18 PM | #7 | |
Member#: 232940
Do you have a link to these E85 high pressure fuel pump you are talking about? I suspect they are all in-tank pumps. I've never seen an actual HPFP sold by the aftermarket and advertised as fitting a specific application while being rated for higher flow rates and resistance to ethanol. Supras are not direct injected and don't have high pressure fuel pumps. |
03-31-2015, 03:36 PM | #8 | |
Member#: 348254
SCIC
I'll take a look when I get home to see if I can find the link I was thinking, however it'd probably not be applicable here after reading your post. Thanks for clarifying, and yes I was referring to an electric pump. The pumps I have seen have only be universal as well because it just isn't cost effective for a company to produce a specific pump for a smaller segment of the market IMHO. |
03-31-2015, 05:02 PM | #9 |
Member#: 388969
Thanks guys, I was talking about the cam driven HPFP. It is the biggest limitation to the E85 conversion on a 2015 WRX. If a solution were to come up then we would be 100% golden on running E85 on a 2015 WRX. Any insight is appreciated.
03-31-2015, 06:29 PM | #10 | |
Member#: 398361
Vehicle:2015 wrx ice silver,wr blue |
04-01-2015, 08:09 AM | #11 | |
Member#: 341546
South East
I would say Clark Turner's tuned cars don't have any issues... YET. It's just a matter of time. The factory hpfp is not meant for full e85. To OP, what is the power difference from a blend of e85 and running full e85? If we are talking 5-10whp, is it really worth it on something you probably daily. I'd take 290whp and it last forever than 300whp and create problems. |
04-01-2015, 09:24 AM | #12 |
Member#: 232940
I've never heard of an electric high pressure fuel pump on a production DI system. I don't see how that could be controlled with the stock ECU.
04-01-2015, 10:17 AM | #13 |
Member#: 401977
TXIC
Vehicle:IDFK Wat bish whet |
This is probably never going to happen. We are talking about 2400psi here....
04-01-2015, 05:04 PM | #14 |
Member#: 393493
Vehicle:2006 GLHFDD 06wrx,03miata,04cbr600f4i |
I know theshopCT or EFI took apart their fuel pump to see what could be changed. I don't recall anything coming out of that... I know some places are working on HPFP replacements though. Surprised some place like Corksport or some place that has them already for teh BMW or MS3 world isn't popping up to make parts. It'll be interesting what parts come out for our cars in the course of the year, with so many being sold...
04-03-2015, 11:48 AM | #15 |
Member#: 373908
RMIC
Vehicle:2015 WRX Pearl White |
My HPFP is also beginning to fail. Sudden power loss during high speed steady state driving. I'll probably have to get it replaced sometimes soon.
04-03-2015, 05:29 PM | #16 |
Member#: 398361
04-03-2015, 07:26 PM | #17 |
Member#: 373908
RMIC
04-03-2015, 08:58 PM | #18 |
Member#: 398361
04-05-2015, 01:07 AM | #19 |
Member#: 406152
Vehicle:2015 WRX Black |
My car was doing the same thing dude. I switched back to pump and it went away. I have a feeling I'll be buying a new fuel pump as well sometime soon just due to me missing the power from E85.
04-14-2015, 06:51 PM | #20 |
Member#: 388969
Guys if anyone comes up with a fix for it, please post here!!!! I miss the power and I don't want to sell my WRX for a more powerful car!
06-06-2015, 09:46 AM | #21 |
Member#: 203025
Vehicle:2015 WRX Limited 2000 RSTi IAG EJ257 |
Looking for a high pressure fuel pump solution as well. Anyone find anything?
06-06-2015, 11:50 AM | #22 | |
Member#: 206851
Vehicle:56 Belair Pro Street |
06-08-2015, 09:22 PM | #23 |
Member#: 395731
SCIC
Vehicle:2015 WRX Premium DGM |
I'd recommend asking your tuner about what the fuel pump duty cycle is set to.
I am on an ecutek flexfuel tune, and have only gone through about 3-4 tanks of e85 so far. I've been going through some different map revisions, and after flashing one rev last week I experienced repeated sudden power loss anytime I gave the car throttle. I threw a p0203 fuel pump primary circuit cel, and the car would not start at all after I parked. Called my tuner and he said the issue was he had tried increasing the fuel pump duty cycle, sent me a new map to flash, and the car immediately started and hasn't had an issue since. |
06-09-2015, 04:29 PM | #24 |
Member#: 356241
SWIC
Vehicle:2015 Forester XT Venetian Red |
I am running e30, but have left stock Fuel Rail Pressure alone. Are you guys ramping up your desired Fuel Rail Pressure on the e85 tunes or something? I have just been modifying the Injector Trim tables to accommodate for the ethanol.
If you guys are looking for "head room" to allow for the longer Injector Pulsewidth, you could try to request the Start Of Injection angle to begin a little bit sooner. Right now the stock tune has the SOI at around 340* at high RPM and high load. You could bump that up to 350 or more degrees if need be. I realize that does almost jack squat, but it can help a tiny bit. You just always have to be mindful in your tune that your Injector Pulse does not overlap your ignition. Last edited by Psykostevo; 06-09-2015 at 05:05 PM. |
06-19-2015, 03:29 PM | #25 |
Member#: 118500
Vehicle:02 Silver Wagon "Stage 2" |
Ethanol and high pressure fuel pumps are a nightmare. I would suggest looking to see if Subaru sells DI engines in Brazil. If they do, sourcing a pump from there would be the best bet, since they use 100% Ethanol.
If Subaru doesn't, you'll have to find a pump from another vehicle. There are only a few suppliers of high pressure fuel pumps (Bosch, Denso, Delphi), so someone sells your pump or one close enough in Brazil (or even a flex fuel in the US). If you cannot find a Subaru specific for ethanol, then find other makers with DI flex fuel vehicles, and get your hands on the pump. If the pump body looks similar, the chance is good the control strategy for the solenoid on the pump is the same. |
