Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 07-05-2013, 12:43 PM   #1
CrazyCatfish5
Member#: 245236
2003 WRX
Rally Blue
Default RWD/AWD Selectable
Does anyone make a center diff that would work like this? I understand that this isn't how a diff actually works and the resulting mods that would need to be done to the drivetrain. I'm working on a design project.
What I mean is a center diff that you could essentially disconnect the front driveshaft and still get full power to the rear wheels, but when selecting AWD it would still act as a Torsen or open diff. Anyone heard of something like this?
CrazyCatfish5 is offline   Reply With Quote
Old 07-05-2013, 01:19 PM   #2
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
look at some old school suby transmissions... One of my cars has an RX transmission which was kinda neat because it has a center diff lock.
If you were to use this trans and come up with a reasonable way to disconnect one or both of the front axles and you lock the center diff you'll have RWD. If you reconnect axle(s) and unlock the diff, you've got AWD.
I did this a couple times for entertainment and to tide me over while I wait for new front axles to show up when I wrecked them. It's not really "selectable"... Had to pull an axle every time... haha
Have a look at a picture of a suby trans and you'll see why this is going to be impossible to do totally internally with a center diff being that the front pinion is apart of the main shaft.
Zefy is offline   Reply With Quote
Old 07-05-2013, 01:30 PM   #3
CrazyCatfish5
Member#: 245236
2003 WRX
Rally Blue
Ah I didn't realize the front pinion was set up like that
Old 07-05-2013, 01:31 PM   #4
CrazyCatfish5
Member#: 245236
2003 WRX
Rally Blue
So if you used the RX trans and basically came up with an easier way to lock the hubs in and out like an old school 4wd that would do it
Old 07-05-2013, 06:08 PM   #5
WoodsWagon
Member#: 180769
lots of junkers
Front pinion is not part of the output shaft. On the older 4x4 and FWD ones it was, but on all the AWD/FT4wd transmissions it runs through the hollow output shaft.
So yes, with a re-designed center diff and transfer housing it could be done, but why bother when you can get a dccd?
WoodsWagon is offline   Reply With Quote
Old 07-05-2013, 06:37 PM   #6
CrazyCatfish5
Member#: 245236
2003 WRX
Rally Blue
Because the DCCD really only controls the amount of torque that is transferred when a wheel slips..I want something that can be full time RWD as well as AWD at the flip of a switch. Completely user controllable
Old 07-06-2013, 12:06 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
You want a blazer.......You have a Subaru.
What you want is not possible until you design your own center diff to transfer 100% of torque to the rear when "open" instead of the 65% that the DCCD does. Good luck with that.
Jay
Old 07-06-2013, 12:13 AM   #8
thescreensavers
Member#: 333820
2013 WRX Limited
Also the rear diffs cannot see 100% of the engines power reliably as well right?
thescreensavers is offline   Reply With Quote
Old 07-06-2013, 12:46 AM   #9
Storm
Member#: 5218
96L Most Over-
Developed Beater
I am putting more than 100% of power through my R160. I know of folks putting twice stock power through them.
What you will find out quickly is that the geometry sucks for putting power down. You will have wheelspin, you will not be putting down 100% power. If you do, you will eventually break stuff.....that's a given.
Jay
Old 07-06-2013, 06:31 AM   #10
CrazyCatfish5
Member#: 245236
2003 WRX
Rally Blue
I understand the issues with the rear diff. I was just curious if anyone had done anything like this before
Old 07-06-2013, 11:04 AM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
The answer would be no.
Old 03-06-2021, 02:58 PM   #12
Mzsinko84
Member#: 480585
I have 05 Legacy GT and I'm extremely interested in being able to choose AWD or RWD, can I get some help or advice even though I'm on an extremely limited budget?
Mzsinko84 is offline   Reply With Quote
Old 03-07-2021, 05:43 PM   #13
Chi_San
Member#: 53558
2005 Baja Turbo
White/Silver/Black 3tone
The center coupler is just not capable of this.
If you get a center spool, you can 'select' AWD or RWD, however, 'AWD' will be with a solid center diff (no limited slip, no open diff), and when you 'select' RWD from AWD, you have to physically jack it up, and remove the front axles, and fit stubs in so you don't lose oil.
Chi_San is offline   Reply With Quote
Old 03-12-2021, 05:39 PM   #14
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The Subaru 5eat runs a planetary gear center diff; 45:55 torque split. The 5spd runs a viscous LSD center diff. The non-VTD 4eat AWD runs a transfer clutch that drives the rear wheels. Get some engineers to reverse that and have the transfer clutch to the front and then you'll be like Nissan GTR.
FuJi K is offline   Reply With Quote
Old 03-24-2021, 06:36 AM   #15
Mzsinko84
Member#: 480585
Default AWD with RWD selection possibility?
I know a little bit about the Nissan GTR and the Skyline r32 but not that much, did Subaru ever have AWD with RWD selection option? The. Skyline r32 AWD with RWD selection option is exactly what I want for my 05 Legacy GT with more power going to the rear wheels even though it’s currently a 45/55 split.
Old 03-25-2021, 02:39 AM   #16
binny
Member#: 198108
MY98 WRX
No.
You'll need aDCCD 6 speed
binny is offline   Reply With Quote
Old 03-25-2021, 05:07 PM   #17
Mzsinko84
Member#: 480585
A DCCD 6 speed?
