Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 04-17-2012, 08:18 PM   #1
shade1569
Member#: 222047
2006 Impreza Outback
twotone green/grey
Default ej253 turbo
so my friend decided to turbo his ej253. i tried talking him into getting a wrecked wrx but he wasnt buyin it. i just wanted to ask a few ?s to someone who has already done this. im curious as to running the oil return line. his is a 2007 and is pretty much impossible to remove his oil pan without pulling the engine. so is there another spot to run a return. a waffle maybe. . . ?? any feedback will help. thanks guys
shade1569 is offline   Reply With Quote
Old 04-17-2012, 08:31 PM   #2
GT11
Member#: 128002
2023 Toyota 4Runner
Tell him to do it. Then laugh when his engine blows.
GT11 is offline   Reply With Quote
Old 04-17-2012, 08:36 PM   #3
xilles
Member#: 147056
plumb it into the valve cover.drill and tap install a barb and connect hose to oil return
xilles is offline   Reply With Quote
Old 04-18-2012, 10:35 AM   #4
GEE-OTTO
Member#: 201277
2008 08 QSM 5MT LGT
QSM
This is a good option.
GEE-OTTO is offline   Reply With Quote
Old 04-18-2012, 10:39 AM   #5
GEE-OTTO
Member#: 201277
2008 08 QSM 5MT LGT
QSM
Ask/your friend if he/she understands that the min_boost the WRX turbo puts out is far too much for a stock EJ253.
After that tell them to buy the AVO turbo kit.
Old 04-18-2012, 11:37 AM   #6
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
dead on! i had the ej253 in my 03 LGT and could get everything to bolt a turbo on it for nothing and i said no. you would need to seriously build up the internals and have some major work done. not worth it
J.Gibbs is offline   Reply With Quote
Old 04-19-2012, 07:06 AM   #7
sergey2007
Member#: 304910
2004 LGT ej207 7163
Please write your opinion about the reliability of the turbo (0,3-0,4 Bar) engine (eg253) without changing the internals. ABO very optimistic talk, a very large increase in power without changing the internals.
AVO:
Our new turbocharger kit for the 2005-2009 Legacy and Outback 2.5i, and 2008+ Impreza 2.5i! These kits transform your 2.5i into an absolute beast with double the horsepower from stock! AVO was the first to develop a turbocharger kit for the 1999-2004 Impreza 2.5RS in 2001 - and people are still running around in the original kits! We've drawn on our decade of experience with turbocharging naturally aspirated Subaru motors to create this highly engineered kit.
While our initial kits for the early model RS were based around a top mount intercooler, we have moved to a front mount intercooler for the newer vehicles. A FMIC based design means that users don't have to find a new hood for their that had a hoodscoop, saving a bunch of money right there. Plus the FMIC allows for more flow and better cooling.
We've also designed a turbocharger specifically for this appliction, that spools up quickly, has fantastic mid-range torque, and has more than enough headroom for your needs! This is due to our own cast exhaust housing design which was created specifically for this application. Along with the stainless steel uppipe and downpipe, the kit contains all the necessary hoses, oil lines, water lines, and other fittings necessary to bolt this kit up. The turbocharger is both oil and water-cooled, just like in stock turbocharged vehicles - and just as reliable.
What kind of power can you expect? Take a look at the graph below! Over 200whp on a dyno where stock N/A cars barely break 100whp. And it's easy power too, generated at just 4.5-5psi. This is thanks to our specially designed boost actuators that will run at these lower boost levels, keeping your system from overboosting. Our experience with these kits has shown us all the issues that need to be addressed for running a turbo reliably, and we have taken care of them all.
sergey2007 is offline   Reply With Quote
Old 04-19-2012, 10:26 AM   #8
GEE-OTTO
Member#: 201277
2008 08 QSM 5MT LGT
QSM
The reason the AVO EJ253 turbo kits works so well is the turbo is custom made to work with a STOCK EJ253. The reason J.Gibbs didn't use the turbo parts he alluded to is b/c they were made for a stock TURBO Subaru. The parts would fit and plumbing things up wouldn't have taken too much extra effort but once it all was in place it wouldnt last very long.
Old 04-19-2012, 10:34 AM   #9
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Thank you. Exactly what I meant. It CAN be done right. But using stock Subaru Turbo parts isn't the right way to do it if you want a reliable build
Old 04-19-2012, 03:13 PM   #10
shade1569
Member#: 222047
twotone green/grey
ewll like i said its not my car and he does want he wants. im just tryin to find out how to make it work. i guess heads will have to work. thanks
Old 04-20-2012, 07:32 PM   #11
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The high compression of the EJ253 is not friendly to boost. Boost+compression=grenade. Tell your friend he has four choices:
1) Waste a lot of time and money making a stock Subaru turbo work with the plumbing on the EJ253 block and then blow it up pretty soon because wastegate pressure on the turbo is high enough to blow the engine up.
2) Spend a lot more money (but less time) buying an off-the-shelf turbo kit that runs low enough boost to not grenade the engine. The sad thing is that low boost means low power, so you're spending a lot of money and not going very fast.
3) Spend a lot more money and a lot more time to rebuild his engine with the pistons from a turbo, which require the rods from a turbo, and then spend yet more time and money making a stock Subaru turbo work. Upside to this is that you'll have the ability to turn up the boost enough to make it fun. Downside is the huge cost and massive labor
4) Just buy the damned WRX engine and swap it. Cheap, quick, reliable, and can be ramped up to really big power.
Old 04-21-2012, 03:55 AM   #12
sergey2007
Member#: 304910
2004 LGT ej207 7163
I'm serious in the future the turbo 253 engine. And I intend to do it competently. Ready turbo kit is expensive and I think there is nothing supernatural. The same can be done independently. The main thing to strictly control the boost and fuel mixture. I understand that, ideally, a little lower compression ratio, but do not want to disassemble the new engine - I prefer the first stage to do a little boost (0.3 bar).
Old 04-22-2012, 10:11 PM   #13
GEE-OTTO
Member#: 201277
2008 08 QSM 5MT LGT
QSM
Hey one of the most knowledgeable Subaru guys gave you 4 options. If you cut corners and do this you will HAVE to exercise one of those options so why not skip the trouble ?
Old 03-07-2021, 07:16 AM   #14
Brandnew4now
Member#: 516974
Default Wow
Maybe the bottom end will blow up... so what... go get a 205 207 255 257 block and use sohc heads afterward. Oil feed from oil pump, return to the pan, coolant in and out through water heater heater. You could drill and tap your valve cover but then you’re dumping hot turbo oil on your valvetrain. My setup is a 251/257 with 253 intake manifold. 251 IM allows more room for the turbo if you use aftermarket fuel lines and rails. 253 IM has more aftermarket support. I’ve run 6-8psi with no intercooler without issue in the infancy of the build, but with an sti block.
Brandnew4now is offline   Reply With Quote
Old 08-28-2021, 02:53 PM   #15
Dewzer
Member#: 441925
Default Bumping old thread
Hey guys. Mainly making a post so I can post in classifieds so dismiss me for wasting any time. I have an 06 2.5i and looking to turbo it. I have an 03 wrx engine I tried to swap but didn't work out. Now thinking about taking the internals out of the wrx and putting them in the 2.5i. Maybe another learning experience but hopefully it works out.
Dewzer is offline   Reply With Quote
Old 08-28-2021, 03:55 PM   #16
benflynn
Member#: 515308
100$ for sti rods, and get some used forged pistons and npr rings. Crank will be fine. Then ur going to want some E85. Heads flow ok, nothing from the 2.0 will fit the 25
benflynn is offline   Reply With Quote
Old 08-28-2021, 03:56 PM   #17
benflynn
Member#: 515308
I’d do a 3.6l before I boosted the 253
Old 08-31-2021, 02:41 PM   #18
caden0313
Member#: 525639
2006 Impreza 2.5i
Keep in mind that the EJ253 is not just an NA version of the EJ255 or EJ257, it is a single cam motor with high compression and weaker internals that are not suited to handle boost. It would be much easier and likely cheaper long term for him to buy a WRX motor or even an JDM turbo motor that can bolt up to his stock 5 speed with less modification than an STI motor swap
caden0313 is offline   Reply With Quote
FS/FT : sold s!D_v!c!ouS Private Vehicle 'For Sale' Classifieds 33 05-23-2012 10:52 AM
VF52 turbo on 2008 wrx WREX792 Newbies & FAQs 15 04-19-2012 09:32 AM
FS/FT : Turbo & Random Other Parts thestory8 Tri-State Area Private Classifieds 2 04-17-2012 06:37 AM
Turboing a MY05 EJ253 SOHC JonzFaSTi Normally Aspirated with bolt-on Forced Induction Powertrain 35 09-08-2006 10:43 PM
EJ25D vs. EJ253?? Hawk296 Normally Aspirated Powertrain 7 01-02-2003 11:46 PM
