05-06-2017, 04:41 PM | #29226 |
Member#: 421858
Vehicle:2012 Impreza |
05-06-2017, 04:42 PM | #29227 |
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
05-06-2017, 04:57 PM | #29228 |
Member#: 421858
Well thanks for ruining my weekend.
not really, jk |
05-06-2017, 06:05 PM | #29229 |
Member#: 304306
Vehicle:2012 Impreza-premium Ice Silver |
My 2012 Impreza has 28,594 miles on it. I bought the car on December 26,2011.
05-06-2017, 06:52 PM | #29230 |
Member#: 421858
05-06-2017, 07:11 PM | #29231 |
Member#: 304306
I drive it to work 5 days a week -6 miles roundtrip. On weekends I use it for errands- grocery store, home depot, etc..
05-06-2017, 07:33 PM | #29232 |
Member#: 421858
Well it's probably half dead with short tripping... but good luck anyway.
05-07-2017, 01:04 AM | #29233 |
Member#: 425248
Vehicle:2015 Impreza Prem 4d Dark Grey Metallic |
Alright, so who's on a trend for the most? My 2015 has 38k miles on the clock. *Almost* two years old, May 11, 2015 was when I picked 'er up. ***128561;
05-07-2017, 08:58 AM | #29234 |
Member#: 89967
NESIC
Vehicle:2020 Volvo S60 Gray |
I'm at 82k or 83k I believe for my 2012. Picked her up almost 5 years to the day
05-07-2017, 11:16 AM | #29235 |
Member#: 421858
So would crosstrek coilovers fit the imp without any extra modifications?
edit: if it makes a difference the height range is only +/- 0.5" over stock Last edited by drpoop; 05-07-2017 at 11:23 AM. |
05-07-2017, 08:04 PM | #29236 |
Member#: 301179
BAIC
Crosstreck coilovers SHOULD fit the impreza without any modifications since they are the same chassis. Height range will differ between manuf., so look at the specs on how much they drop at the highest setting. Because we're nearly 2~3" lower than a XV, I'm sure you will be able to set stock height.....
05-07-2017, 08:24 PM | #29237 |
Member#: 421858
The BC coilovers w/ swift springs is only $1300 or so. I say "only" because plenty of WRX coilovers are 2-3k or even higher. Their drop is 2.5-3.5" on the XV so it would be +/- 0.5" on the Impreza. Again, I probably won't buy them, at least not any time particularly soon, but they're an option in the future.
Anyone know if dieseldorf died? He's been really quiet |
05-08-2017, 03:04 PM | #29238 |
Member#: 313575
Vehicle:2012 Impreza 2.0i HB |
whining sound at higher fan speeds
my fan with my HVAC system has developed a high pitched whine at medium to high speeds on my 2012 Limited ... i think its there for all of the higher speeds but the loudness of the fan at higher levels can drown out the high pitched sound.
it's not terribly loud but annoying if i don't have the radio on (sometimes off if my special needs daughter is in a bad state and wants the music off :\)... any thoughts on what this might be and if there is any easy fix or diagnosis? it's definitely livable because i usually have the fan at low levels and when it's hot in summer, i have it cranked high. but i am concerned that in time it will get worse... (wish i had the exact count, but if the fan has 9(?) speeds, it is audible for speeds 5-6, and then 7-9 its drowned out by the fan's white noise and isn't evident for speeds 1-4) |
05-08-2017, 03:07 PM | #29239 | |
Member#: 301179
BAIC
Try pulling your glove box and inspect the cabin air filter, and manually spin the blower fan. |
05-08-2017, 03:58 PM | #29240 |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
The whine could be mechanical or PWM-induced.
PWM will usually have a fixed frequency but the character of the tone will change with power. This noise can originate from the blower motor, the control module or even the speakers. It's usually most pronounced around 50% power, like you've noted. A loose winding in the motor can turn it into a speaker. If it is PWM noise at the motor and the motor is otherwise OK, you can add parallel capacitance to smooth the supplied power. |
05-08-2017, 09:00 PM | #29241 |
Member#: 421858
Oh god, I got a good look at my paint in the afternoon sun today. It looks worse than I thought. Doesn't NXT Tech Wax fill swirls a bit?
05-08-2017, 10:41 PM | #29242 |
Member#: 425248
Speaking of rock chips, paint, and bad drivers, who wants a close up picture of my front bumper? I sure don't ***128514;***128577; Dark grey doesn't hide things too well.
I guess it's what I get for joining the clusterf**k that is I-95 rush hour, before the congestion while everyone's still doing 80. I'll be damned if there's more than a 1 second gap in front of me, it'll get filled instantly. |
05-08-2017, 11:03 PM | #29243 |
Member#: 327440
South East
Vehicle:2012 IMPREZA SPT LTD DARK GRAY METALLIC |
I have a 2012 sport limited w/CVT approaching 100k miles. So last night i exited a highway sitting at traffic light. All of the sudden my check engine lights up, the AT TEMP light, cruise starts to flash, ABS lights up. I park it for a half hour fire it up the AT TEMP light is off but the rest remain lit up. This morning i fire it up and the check engine is lit up, then went out. Take to dealer because I got the 5yr 100k ext warranty and I have 99,287 miles on the odometer. I'M GETTING A NEW CVT TRANSMISSION for $100.00!!deductibe!!! the dealer paid for a rental from enterprise also.
05-09-2017, 01:00 AM | #29244 | |
Member#: 435599
Vehicle:2016 Impreza Sport White |
I drive mine pretty hard, always engine braking and downshifting. I wonder how long it will last. |
05-09-2017, 01:36 AM | #29245 |
Member#: 445904
When the mods remove posts from these forums, why don't they at least private message the parties involved? That would be courteous.
05-09-2017, 01:50 AM | #29246 |
Member#: 319157
I'm guessing the language in the image violated forum rules, but several innocuous posts were deleted as well.
05-09-2017, 04:44 AM | #29247 | |
Member#: 301179
BAIC
Yup, language in the image violated forum rules. Oh well... lesson learned. |
05-09-2017, 11:26 AM | #29248 | |
Member#: 421858
Gonna go ahead and guess it was something directed at me that I missed while I was working this morning... |
05-09-2017, 12:21 PM | #29249 |
Member#: 445904
Oh I see ... I never saw the image and my posts unrelated to the image were deleted, but I can see where the mods just wanted to clean some things up while they were doing post deletes since my post was not Subaru car related and was somewhat insulting to a forum member. I have no problem with the deletions I just think it would be nice to be told that it happened just so that I'm not left baffled. Thanks.
05-09-2017, 01:54 PM | #29250 |
Member#: 301179
BAIC
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 05:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 02:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 07:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 04:09 PM |
