Old 03-16-2021, 07:37 AM   #5901
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
'08 Mustang GT (the toy)
Originally Posted by karuuma View Post
year: 2003
model: WRX
wheel model: Enkei T6S
wheel size/offset: 18x9.5 +45
tire brand/model: Kenda Vezda UHP AS
tire size: 225/40ZR18
suspension: Tein Street basis Z coilovers (little bit lower than stock waiting to put wheels in before dialing in)
alignment: stock
fender mods: None
spacers: None
wondering if i should roll fenders to run the above setup.
any tips?
This is strictly from a tire and wheel perspective - I have no idea how well any of this is going to fit your car.
A 9.5" wide wheel is outside tire industry guidelines for 225/40 tires (and it really doesn't have enough sidewall height to accommodate that much extra 'stretch').
I suggest either going with 9" wide wheels if you want to stay with the 225/40-18 tire size or going with 235/40-18 tires if you want to keep the 9.5" wheel width.
Norm
Old 03-22-2021, 04:23 AM   #5902
adriang7
Member#: 517135
Originally Posted by adriang7 View Post
What tire size? offset? fender mods? camber? asking cause i have 18x8.5 +45 for a 04 wrx wagon and i wanna know how much tire i can fit and what i have to do to minimize rubbing. thank you
Update: ended up getting Michelin p/s a/s4 245/40/18 stock suspension with a light fender roll all around. I don’t rub unless I’m going into corners at high speeds or bumps going fast. The rubbing isn’t digging into my sidewall it’s just grazing it. I plan on getting a flush fender roll and it should do the trick.
adriang7 is offline   Reply With Quote
Old 03-24-2021, 04:57 PM   #5903
MastiffHouseBrewery
Member#: 517390
2005 WRX STI
year: 2005
model: STI
wheel model: Enkei PF05
wheel size/offset: 17x9 +40
tire brand/model: RE71R or Pilot Sport 4S
tire size: 245/45 or 255/40
suspension: Tein Flex Z coilovers (currently 13.75 inches hub center to fender), WL sway bars, and anti lift and roll kits.
alignment: stock
fender mods: None
spacers: None
I think these will clear brembos but I don't know that for sure, I have a fender roller and plan on getting the WL rear lateral links for better adjustment as well. Trying to keep camber at -1.5 max but not sure if that is possible. I know the +42-48 range for offset would be better for fitment but I really like the PF05 and they are pretty light and come in gold lol. Just trying to see how much work it would take to fit these before I pull any triggers.
any advice would be appreciated!
MastiffHouseBrewery is offline   Reply With Quote
Old 03-26-2021, 07:21 AM   #5904
TSID
Member#: 522335
2006 WRX Sedan
World Rally Blue
Default Fitment?
Year: 2006
model: WRX
Wheel Model: Enki RPF1
wheel size/offset: 17x9+45mm
tire brand/model: Bridgestone Potenza RE-71R
tire size: 235/45
suspension: stock (I have Tien H.Tech lowering springs I can install as well)
alignment: stock
fender mods: None
spacers: None
I'm pretty new to the fitment game and this is my first modified car, and will be my first wheel setup purchase, so I was just curious if this would fit well, or if anyone with a bit more experience than I sees something wild here or has any advice. I've been trying to do research (including Unabomber's thread) and this is what I've come up with, however still figured it would be a good idea to run it past you guys since the forums have infinitely more experience in this field than I do.
I am thinking I may have to roll my fenders to prevent rubbing, however I figure someone has certainly tried running a similar setup to this at some point and knows firsthand what is needed in order to fit this setup. Any help that anyone can offer would be greatly appreciated.
TSID is offline   Reply With Quote
Old 03-27-2021, 07:31 PM   #5905
Bosstycoon
Member#: 365609
Norm
On a 18x9 +38 offset would a 265/35/18 fit a 2012 wrx?
Bosstycoon is offline   Reply With Quote
Old 03-28-2021, 08:28 AM   #5906
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
Here's how it plots up against OE 245/40-18 on 8.5" ET+48 wheels - I don't know how much sheetmetal clearance exists on a 2012 but it looks good on the inboard (strut) side. OE wheel and tire sizes pulled from wheel-size.com.
Hope it helps.
Norm
Old 04-05-2021, 11:50 AM   #5907
AxeIsForChop
Member#: 523500
I have been searching high and low to try work out what the wheel and tyre setup is on this car comparing to others etc.
Hoping to find someone familiar with the car, or otherwise someone good at guessing wheel/tyre sizes as I'm trying to work out wheel size and offset, as well as tyre size as I would like to do something similar. Anyone keen to take a guess?
I'm thinking 15 or 16 inch... leaning towards 16 with perhaps a 225/55 or something like that.
Have found the pics of the car in a couple adds for king raised springs in a few places including primitive racing, but have had no luck finding wheel specs anywhere.
AxeIsForChop is offline   Reply With Quote
Old 04-09-2021, 01:00 PM   #5908
05STiOwner
Member#: 522032
05 STi
Platinum Silver
Originally Posted by marczeru View Post
2007 STI
Wheel Model: BBS LM
Size / Offset: 17 x 9 +20
Tire Brand: Falken ZE950
Suspension: BC Coilovers
Alignment: ~ -2 all around
Spacers: None
Rubs rear on hard bumps
I love the look of this car! I just bought some BCs and was wondering what fender mods you did to accommodate the bigger tires? Other than your wheel offset, I have the same setup. Thanks man.
05STiOwner is offline   Reply With Quote
Old 04-25-2021, 03:18 PM   #5909
marczeru
Member#: 466138
All fenders rolled and slight pull in the front.
Don’t think the pull was needed but just wanted to make sure they didn’t rub.
Hope this helps.
marczeru is offline   Reply With Quote
Old 05-13-2021, 11:18 AM   #5910
bobbathesolo
Member#: 488442
2007 Impreza WRX STi
Default 2007 STI Fitment Question
Year: 2007
model: STI
Wheel Model: Avid1 AV20
wheel size/offset: 17x9+35mm
tire brand/model: Michelin Pilot Sport 4s
tire size: 245/40
suspension: Feal 441 Coilovers
alignment: -2.3F/1.3R
fender mods: Rear trimmed
spacers: None
Wondering if anyone can confirm that the Avid1 AV20s with the specs above will clear the Brembos on an 07 STI. I did some searching and found info on the 18s but nothing for the 17s. I really don't want to run spacers and those spokes look pretty steep so I'm a little concerned.
bobbathesolo is offline   Reply With Quote
Old 05-13-2021, 04:50 PM   #5911
barch88
Member#: 410097
2015 Subaru Impreza
2021 WRX - totally STOCK suspension
Will it fit:
18x9.5 +35
255/40 tires?
265/35 tires?
I have no plans to modify suspension at all. I want as beefy of a setup I can get on stock suspension with no rubbing issues what so ever.
Considering 18x9.5 +35mm offset, possibly a higher offset if I can find something +38 or +40, but for now I’m set on some wheels with +35.
Ideally 255/40 because it’ll be beefier, but if 265/35 looks just as good I’ll go with those.
Thank you!
barch88 is offline   Reply With Quote
Old 06-20-2021, 11:15 PM   #5912
Xforce1409
Member#: 504746
I have. 2018 sti was seeing if I would be able to run 18x9.5 +18 I just have stock suspension right now but I’m not opposed to rolling the fenders
Xforce1409 is offline   Reply With Quote
Old 06-21-2021, 08:00 AM   #5913
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
Pretty sure you'd need to do more than just roll the fenders - the outer faces of the wheels and tire treads/sidewalls would be almost 2" further outboard than stock.
Norm
Old 06-21-2021, 09:03 AM   #5914
Needlesedge
Member#: 523165
Year: 2015
Model: STI
Wheel Size: 18inch Stock
Tires: 245/40 ZR 18
I am looking to put some beefier tires on my STI. Currently I am running 245/40 ZR 18. Looking for a higher profile was wondering if anyone has recommendations on wheel size and tire size.
Needlesedge is offline   Reply With Quote
Old 06-21-2021, 12:03 PM   #5915
Xforce1409
Member#: 504746
So I need a little help with some fitment I am trying to run a 18x9.5 + 18 I am assuming that I need to roll and pull the fenders.Does anybody have any insight for me on the set up
Old 07-14-2021, 10:31 PM   #5916
PeteJM
Member#: 244836
2018 STi
xxx
Team Dynamics 15x7 5x100, 225/60/15, king springs (custom to primitive racing). Talk to Paul at Primitive Racing
PeteJM is offline   Reply With Quote
Old 08-12-2021, 04:59 AM   #5917
jimbo1
Member#: 524543
year: 2003
model: WRX STI Sedan
wheel model: VOLK TE37 SL
wheel size/offset: 18x9.5 either +45
tire brand/model: ?
tire size: 235/40/18
suspension: BC RACING
alignment: -?
fender mods: ALL FENDERS HAVE BEEN ROLLED
spacers:no
would this wheel work with just camber changes?
jimbo1 is offline   Reply With Quote
Old 09-03-2021, 01:47 PM   #5918
H4yduk3
Member#: 521629
Default 2015 WRX Base Stock Maximum Tire Size
Good day.
year: 2015
model: WRX Base
wheel model: Method MR50267012515
wheel size/offset:16"x7" 15mm (OR can be 30mm(?))
tire brand/model:BF Goodrich All-Terrain T/A KO2
tire size: 16" LT225/70R16
suspension: Currently Stock, waiting on gravel coilovers to Raise it.
alignment: Stock
fender mods:None
spacers: yes/no? size? None- Currently All Stock.
So I'm waiting on some KSport Gravel Rally Spec Coilovers, and I've just lost my third tire in 18 days. The question is: will the above rims and tires safely clear and work on my 100% stock car until the coilovers get in? My calculations indicate they they are just under 1" in diameter from the 235/45 R17 Continental DWS06's on the stock 17" rims.
Secondarily, I am also interested in opinions regarding the best wheel and tire set-up for gravel, dirt, rock, snow, slush and ice driving, as I have yet to order the rims and tires.
I intend on doing so today. All input welcome.
Swift response appreciated- having a ride out here is Survival.
Thank You.
H4yduk3 is offline   Reply With Quote
Old 09-23-2021, 07:28 AM   #5919
sharp007
Member#: 526691
Cool
I live in Arizona and was looking for some good tires for my subaru
checked several online and finally decided to go for
Michelin LATITUDE SPORT 3
weighs around 40 pounds and tread of 9/30"
so far I am happy with my purchase, no noise or suspension issues, none.
You can check out more on: https://autosphile.com/best-tires-for-hot-climate/
sharp007 is offline   Reply With Quote
Old 10-11-2021, 10:17 PM   #5920
subawoo94
Member#: 390461
2004 sti
midnight black
year:2010
model: STI Hatch
wheel model: Enkei TS-V
wheel size/offset: 18x9.5 38 or 45
tire size: 235 40 18
suspension: Stock, looking into HKS Coils
fender mods: None. Would consider rolling if needed but don't have easy access !
Just looking for advice ! I'm not married to these numbers as I'm just looking for a clean fitment and they are just what I have found as potential fits. Advice is appreciated.
subawoo94 is offline   Reply With Quote
Old 10-18-2021, 09:09 PM   #5921
Breadwrx
Member#: 527017
2004 WRX
Default 2004 wrx wheel fitment, mainly tires
please follow this format:
year: 2004
model: wrx
wheel model: enkei pf09
wheel size/offset: 17x9 +45mm
tire brand/model: don't know
tire size: don't know
suspension: stock
alignment: I don't like camber but don't mind fender pulling
fender mods: none yet
spacers: no spacers yet
I like the enkei pf09 wheels but I am very confused on tire sizes and which to pick. Yes I've looked through this forum, yes I've looked at it on other sites but I haven't really seen these wheels in this size. I don't mind fender mods but don't like camber so if anyone can rec tire sizes that'd be great.
Breadwrx is offline   Reply With Quote
Old 10-20-2021, 06:34 PM   #5922
Leaguer4
Member#: 516427
Default Fitment help 2004 Sti
Year:2004
Make: Subaru
Model: STI
Wheels: Work Meister S1
Tires: not sure
Suspension: BC racing br series
Fender mods: willing to roll fenders NOT roll them
Spacers: none
Camber: don’t know current camber
I’m looking to purchase some wheels on my sti and wanted some input before I placed the order. The wheel I plan on installing is a work Meister S1 18x9.5 with a 37 offset. I understand there will need to be modifications done to the fenders such as rolling and I am willing to do that. However, I would draw the line at pulling them. I want to keep body as close to OEM as possible. My question would be: will these be able to fit without having to pull the fenders?
I did the calculations and from my setup I have now, the new wheel would stick out 27 mm more and would be 11 closer to the suspension. I currently have coilovers on the vehicle (BC Racing BR series) fronts have camber plates and rears do not. Not sure what tires I would do yet but wanted to confirm these would work without having to pull fenders. I am willing to adjust camber as needed. Would prefer nothing super crazy but I’ll do what I have to.
Leaguer4 is offline   Reply With Quote
Old 12-15-2021, 11:20 AM   #5923
nicholaspryde
Member#: 441400
2006 WRX LTD Wagon
Steel Gray
year: 2006
model: WRX Limited Wagon
wheel model: Rotiform LAS-R
wheel size/offset: 18x9.5 +25mm
tire brand/model: Toyo Tires Proxes Sport
tire size: 235/40ZR18
suspension: BC Racing BR Coilovers
alignment: Unmodified(?) not sure.
fender mods: None
spacers: None
Note that it doesn't rub from steering at all, but fenders will rub in the back when hitting big bumps in the road. Not too bad, but the plan was to install Karlton Flares and run a spacer to get near flush.
nicholaspryde is offline   Reply With Quote
Old 12-15-2021, 12:22 PM   #5924
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
02' EJ205 20G 6MT wagon
Originally Posted by nicholaspryde View Post
year: 2006
fender mods: None
spacers: None
Now try hitting a bump in the rear with a full tank of gas lol
K3rm1tth3fr0g is offline   Reply With Quote
Old 01-06-2022, 02:35 PM   #5925
TriniPhantom
Member#: 528224
2016 WRX
Default Enkei RPF1 on 2015 WRX
Hi there, I'm a new member to the forum. I have a 2015 WRX with stock suspension, brakes, rotors and stock wheels. I want to install new wheels and tires, but keep the stock brakes, rotors, and suspension (for now). After some research the Enkei RPF1's have come out on top in terms of engineering design, weight and cost. Ideally would like to keep the stock wheel size (18 x 8.5) and tire size (245/40/18) to maintain the suspension geometry of the car.
However, the RPF1's at 18x8.5 have a sort of concave look, something like a 'D' when viewed from the side profile, which I really don't like. The 18x9.5 however have a more convex or dish look, something like a 'C' when viewed from the side profile. The stock tire size can accommodate the 18x9.5 wheel. I prefer this look.
My question then, is how does going from an 18x8.5 to 18x9.5 wheel change the handling and performance characteristics of the car, given that my main intention is to track my WRX. Would the wider wheel affect upgradability to bigger rotors and brakes, as well as suspension? Any advice/thoughts are much appreciated, and I would love to hear from anyone running this type of setup.
Thanks.
TriniPhantom is offline   Reply With Quote
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
