Old 06-05-2004, 03:32 PM   #1
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
Default Max boost on vf30
Could someone tell me what the max boost i can run on a vf30 is?
03WRX83 is offline   Reply With Quote
Old 06-05-2004, 03:39 PM   #2
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
That is a question with NO real answer.
With WHAT for mods?
What EM?
What fuel?
For what purpose will this vehicle be used?
The VF30 will put out plenty of PSI....
Old 06-05-2004, 04:18 PM   #3
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
vf30, sti pinks, turbo back catless system uppipe..fp, and cobb tunning, im just wondering what its max potential can be...
Old 06-05-2004, 04:36 PM   #4
Uncle Scotty
OK buy Nates beans
If you have "Cobb tuning" then I guess it's up to them.
Old 06-05-2004, 11:55 PM   #5
HonduHunter
Member#: 28408
2002 vf48ed WRX
true true
HonduHunter is offline   Reply With Quote
Old 06-06-2004, 12:20 AM   #6
InfamousDX
Member#: 25413
How's your Stage 2.5 treating you man??? Sorry to jump off topic.
InfamousDX is offline   Reply With Quote
Old 06-06-2004, 01:10 AM   #7
berzerkled
Member#: 40200
Cobb Stage 2.5
i have a vf34 with the same setup and hit 19 psi and stay there (no peak )
berzerkled is offline   Reply With Quote
Old 06-06-2004, 02:23 AM   #8
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
Seems that on the top end vf30s like to taper to 16-17 max psi.
MJU1983 is offline   Reply With Quote
Old 06-06-2004, 03:33 AM   #9
V REX
Member#: 11102
02 WRX,05STi Sold
01 Boosted IS300
The most I would run on pump gas is 18psi. On C16 I run 23 but it tapers to 18 by redline.
V REX is offline   Reply With Quote
Old 06-06-2004, 05:12 AM   #10
Big Turkey
Member#: 32118
I ran 24psi of boost and tapered down to 21psi on C16.. that was had some crazy amounts of torque.
Big Turkey is offline   Reply With Quote
Old 06-06-2004, 10:07 AM   #11
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
That is what mine does anyways
MK19_ is offline   Reply With Quote
Old 06-06-2004, 10:48 AM   #12
mikeG8U
Member#: 55299
02 WRX
mine was tuned to 18-18.5 on pump and 22.5 on C16
mikeG8U is offline   Reply With Quote
Old 04-03-2021, 03:16 PM   #13
Kestrel416
Member#: 514608
On 94 octane my EJ207, with pinks and VF30 peaks at 19.8 psi and holds that to redline, which was reduced to 7200 rpm due to maxed out injectors. I'm installing a Walbro 255 and Aeromotive FRP (plan to run + 0.5 bar fuel pressure) and water meth injection and hope to hit 22-24 psi, with a goal for 275+ lb/ft of torque.
Kestrel416 is offline   Reply With Quote
Old 04-04-2021, 10:21 AM   #14
K3rm1tth3fr0g
Member#: 508105
Link G4X flex tuned
02' EJ205 20G 6MT wagon
Psst, this thread is over 15 years old.
K3rm1tth3fr0g is offline   Reply With Quote
Old 04-29-2021, 12:03 AM   #15
Zurq94
Member#: 523989
Default I just bought vf30
So what is max boost with his mods and what do you guys think that’d put to the wheels ?
Zurq94 is offline   Reply With Quote
Old 05-18-2021, 06:23 PM   #16
Kestrel416
Member#: 514608
There are are numerous posts on here with people making more than 300 who with VF30, which seems strange since it's rated for 33-36 lb/min of airflow which is roughly 350-370 hp at the crank. Peel off drivetrain losses and you barely scratch 300 whp. Maybe some turbos are capable of high pressure ratios (good wheel housing match), but the turbines some say are flow limited, so not sure how to push the compressor that hard.
Old 05-18-2021, 07:14 PM   #17
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Max boost is really subjective to your car, your mods, your fuel, your tune, your environmental aspects (elevations for instance) and a crap ton of other things. Figure somewhere between 15-20psi depending on all the factors and more listed
snow_bound26 is offline   Reply With Quote
18psi Max boost with vf30 and fmic? BurtonCR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-07-2004 09:17 AM
Max boost on VF30? TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-13-2003 12:55 AM
Max boost on stock boost guage with TXS Stage 2? digitaltekniq Engine Management & Tuning 2 05-27-2003 11:52 PM
Max Boost for VF30/VF34? Si2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-07-2002 07:23 PM
Real-world max boost on the WRX? Minnesota WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 11-15-2001 01:58 PM
