04-01-2004, 08:27 AM | #1 |
Member#: 1216
Vehicle:2007 WRX WR Blue |
Flashing Oil Light?
I have a 2003 Forester that had a flashing yellow at oil temp light, which the owners manual says it is a Trans problem. Any one else have this problem? HELP
04-01-2004, 08:31 AM | #2 |
Member#: 23676
Vehicle:. |
have you checked your oil?
04-01-2004, 08:38 AM | #3 |
Member#: 2263
Vehicle:2014 Sportwagen TDI |
dipstick
04-01-2004, 08:54 AM | #4 |
Member#: 4140
Vehicle:02 WRX 00 MR-S |
tranny overheating?
were you driving up hill all day? I had heard somewhere slipage in the tranny could cause it to overheat. hopefully it is a bad sensor (ie false error). TMK |
04-01-2004, 08:59 AM | #5 |
Member#: 1216
update
It is my Wifes car, it was the yellow at oil temp light. I am going to check the fluid levels at lunch. I am just looking to see it their is a trany recall that this could be linked to.
04-01-2004, 09:02 AM | #6 |
Member#: 45613
Vehicle:2005 Legacy GT Ltd. Satin White Pearl |
I have no clue about cars newer than, well, mine...but could it be a tranny fluid thing? Is your car standard 5-spd, or automatic transmission? If it's auto, you can check the fluid level right under the hood. If it's a 5-spd, there should be a yellow dipstick sticking out of the gearbox.
It also could just be low oil level - so check your oil while you're at it! Good luck! //marcus |
04-01-2004, 10:33 AM | #7 | ||
Member#: 16653
Vehicle:2017 Mazda 6 2013 Toyota Vanling |
04-01-2004, 10:40 AM | #8 |
Member#: 1216
Trany Type
It has a Auto Trany.
04-01-2004, 10:47 AM | #9 |
Member#: 4140
any slippage? ie slow shift.
TMK |
04-01-2004, 10:54 AM | #10 | |
Member#: 10235
Brian you are such a jerk! go easy on the dude!! |
04-01-2004, 11:07 AM | #11 |
Member#: 16653
I was going easy. -Brian Edit: to keep this on topic- Sen- if your tranny fluid level is ok, but the light still flashes, I'd call your dealer (presuming your car is still under warranty). |
04-01-2004, 12:26 PM | #12 |
Member#: 1216
Looking better
Well the trany fluid level is OK and it does not smell burnt, looks nice and red. Hopefully just a fluke.
03-13-2021, 12:05 PM | #13 |
Member#: 522954
Had this problem a while back. Let it cool and was just fine. It was also 110 out going up hill.
04-01-2021, 04:31 PM | #14 |
Member#: 201995
Vehicle:06 ings+1 STi 04 STi |
04-01-2021, 05:40 PM | #15 |
Add Lightness
Moderator Member#: 13699
Vehicle:2021 Building It Better |
Similar Threads | ||||
flashing oil temp indicator | submariner416 | North West Impreza Club Forum -- NWIC | 5 | 04-23-2009 03:38 PM |
AT Oil Light flashing.... | metalsman | Newbies & FAQs | 7 | 03-26-2006 09:38 PM |
Oil light occasionally flashes........why? | riverarob | Service & Maintenance | 6 | 12-07-2005 03:15 AM |
Check Engine light w/ flashing Cruise Light? | SBasinger18 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 07-23-2004 11:55 PM |
Flashing CE Light @6000 in 3rd? | pleiades | Normally Aspirated Powertrain | 0 | 03-27-2001 07:25 PM |
