09-20-2000, 08:55 AM | #1 |
Member#: 1575
South East
Vehicle:2011 WRX Premium Blackest Black |
Dispelling myths of the P1
Let me start by saying that this post is not meant to flame anyone who has bought the P1 suspension or anyone who likes it. I just wanted to share some things that I have found while researching the P1 suspension. First of all the P1 is an STI suspension. Despite what Prodrive marketing is trying to convince the world they designed the suspension by picking from STI's parts bin. Also the P1 suspension understeers more than an STI ver5 by design
quote: "So large is Subaru Technica International's ( STi ) range of springs and dampers that Prodrive tried no less than 22 variations. In standard spec the WRX is too harsh for UK roads, so the P1 retains the WRX's rear springs but uses softer front springs and uprated dampers all round to achieve a more compliant ride. " This quote is from a P1 review on a british website. This change would make the P1 corner worse than the WRX but handle bad roads better. This was done on purpose. The Prodrive folks wanted to make a more streetable car for British roads. So, if you want a maximum performance suspension go through one of the subaru parts people like subaruparts.com and get the WRX STI suspension NOT the P1. What makes the P1 special is the Brit specific design and Prodrive heritage not the suspension. quote:"VERDICT: Developed in the UK for the UK market" more about understeer-"The other slight blot in the copybook is the P1's less than dogged resistance to understeer. We're used to Imprezas amazing us with awesome front-end grip, but the P1's front 205/45 ZR17 Pirelli P-Zeros start to slither earlier than expected. Perhaps the biggest disappointment is not being able to deal with the understeer by adding to or cutting the throttle" [This message has been edited by skidplatez (edited October 03, 2000).]
09-20-2000, 09:46 AM | #2 |
Member#: 287
Vehicle:2019 Outback Blue |
Simply changing the front springs to softer ones would reduce understeer not add to it. Maybe it was something in the damper/swaybar selection that causes the poor handling.
Tony |
09-20-2000, 10:41 AM | #3 |
Member#: 524
Vehicle:04 STi White |
That is not always the case, the softer springs could be allowing the P1 to washout the outside front tire, with exessive wieght transfer, or camber changes due to suspention compression.
09-20-2000, 10:45 AM | #4 |
Sooby Guru
Member#: 1914
SWIC
Vehicle:2000 2.5RS w/ EJ22T swap and N20. gone. : ( |
So if I go through Subaruparts.com, what are the part numbers for the WRX springs and shocks. I have the P1 part numbers but I want the suspension for aut0-x so I don't care how bumpy the ride is. Please help!
Eric |
09-20-2000, 10:48 AM | #5 |
Member#: 1997
Vehicle:2006 Acura TL 6spd STMGM6 alumni |
If you goto the STi section, they now list the WRX springs under the suspension section along with the struts.
09-20-2000, 11:00 AM | #6 |
Member#: 856
International
Vehicle:2123 JDM STi Black |
The P1 as bought from the UK dealers does understear at the limit. All Imprezas do. It is designed in to make the car safe for the average driver.
Here in the UK lots of the really keen drivers of imprezas take there car to a company called powerstation. What these guys do is move the position of the steering rack to eliminate bump steer from the front end, they also alter the geometries to make the chasis as neutral as posible. These mods are not limited to the P1, i have friends with 22B's, P1's, STi's and of course UK turbos who all rave about how the car is transformed by these changes. At the end of the day, subaru has to tune the cars suspension to be safe for the lowest common denominator, an inexperienced or relatively unskilled driver. If you want a great handling subaru you have to change the stock suspension and steering settings, changing spring rates and dampers isnt always the answer. Take a look at their web site, you will see non other than the Prodrive Impreza WRC car at their premises prior to the RAC rally having its setting checked. http://www.powerstation.org.uk/Projects_Page.html |
09-20-2000, 11:13 AM | #7 |
Member#: 265
Vehicle:1998 22B Blue 1986 Ford RS200 White |
hi John,,
i fully concur on the Powerstation setup.. It is absolutely awesome.. Although some people, "no names no pack drill" were trying to convince me that the Leda C suspension was a must have on the 22B their minds were changed after driving my car with stock suspension but with the Powerstation bump steer removal setup.. With this setup you almost "think" the car through a corner. Amazing on both the road and track. Understeer is eliminated but the suspension is still compliant and comfortable for everyday use ( I wish ) Richard |
09-20-2000, 11:40 AM | #8 |
Member#: 856
International
hey richard,
As a lucky SOB i have had the pleasure of driving richards 22B both on track and road both before and after the powerstation mods. Before the car was stunning, very easy to drive quickly but after, WOW, so easy to drive on the limit, 4 wheel drifts under full control are childs play and non of the dreaded understear. Such a shame the 22B is over hear and not in WA with its dad where it belongs. Its even more of a shame that i get to run around in the beasty on occasion, just to keep things from seizing up you see. LOL |
09-20-2000, 02:21 PM | #9 |
Member#: 1178
South East
Vehicle:2011 BMW 535i Alpine White |
Richard,
Or actually anyone in the UK that can get us poor Souls in the US the information on the "Powerstation" modification. If they were to train Rallispec or someone over hear to do that I'm sure there are plenty of us Lowly 2.5 Owners that would love to kill the dreaded Understear... Thanks in advance Eric |
09-20-2000, 02:31 PM | #10 |
Member#: 856
International
why dont you guys fire off an email to the guys at powerstation and ask the question.
The Impreza is basically the same car the world over, i dont see why the RS should be any diferent than the Jap and European models. It's such a drag having friends like richard at times, takes a huge amount of effort to motivate me to sit in the 22B. LOL |
09-20-2000, 04:38 PM | #11 |
Member#: 277
SCIC
Vehicle:98 Not a Subaru BRACK |
I just sent an e-mail to the guys at Powerstation. I'll keep you guys posted.
09-21-2000, 12:25 AM | #12 |
Member#: 907
Vehicle:2002 WRX Sedan Silver |
johnfelstead,
what a good friend you are... making such a big sacrafice for your buddy richard. LOL. richard, just curious.. how often do you get to see your 22B?? do you have a job that you travel to the UK often or do you take lots of vacations? sorry for all the questions but to have such a beautiful car and not be able to see/drive it must be torture. thanks shaun |
09-21-2000, 12:30 AM | #13 |
Member#: 277
SCIC
Can our US spec cars benifit from a simiar bump steer elimination mod? If so, does anyone know where this can be done in the US? I've been keeping up with the UK peeps and yes, they all seem to rave about the results.
09-21-2000, 04:07 AM | #14 |
Member#: 1178
South East
Sauginius,
Thanks for sending off a E-mail.. Please let me know what you get back from them.. Anything that we can do the help solve some of the Understear situation would be awesome... Thanks again Eric |
09-21-2000, 04:57 AM | #15 |
Member#: 613
Vehicle:'95 Nissan Maxima S |
Skid...one little error. Most of the suspension components may be STi, but the dampers and springs are not. They are Eibach/Bilstein, custom made to Prodrive specs. As far as understeer, as stated above, it is there by design. Most of us are not like Michael Schumacher, and cannot handle a totally neutral-light oversteering car.
Lovejoy [This message has been edited by Lovejoy (edited September 21, 2000).] |
09-21-2000, 05:33 AM | #16 |
Member#: 1502
Vehicle:2000 2.5RS & SV1kS BRP |
I may be no Schuey, but it sure is fun to try to drive like him. One question about the make up of the P1 sus, I had heard that the springs were Prodrive specified rates from Ebiach and the dampers were Version 5/6 (which are made by KYB from what I have read) from the STi WRX. The WR sport is the one that I thought came with the Bilstiens (hence the larger price increase). That sound right? Given that most of the roads in the NE (PA/MD backroads) are prob equilevent to UK roads AND the fact that I have been known to take a dirt road or two, I would think the less stiff P1 suspension would be better for me. Does anyone know if the WRX spec suspension would work as well as the P1 in that enviornment? Does the P1 have inherently MORE understeer than the full spec STi WRX? Can't we just run a bigger rear bar (or higher setting) to dial the understeer out? Also does either the WRX or P1 setup provide any lowering over the stock suspension?
Bob [This message has been edited by Bob O (edited September 21, 2000).] |
09-21-2000, 06:15 AM | #17 |
Member#: 856
International
next get together i will crawl under my mates P1 and take a look, bilstiens are usually pretty well marked up with damping specs.
I will ask him also, he is a bit of a car nut so he may know off the top of his head. |
09-21-2000, 08:23 PM | #18 |
Guest
Member#:
"What these guys do is move the position of the steering rack to eliminate bump steer from the front end, they also alter the geometries to make the chasis as neutral as posible."
I read a post somewhere on the sidc board that basically said "It doesn't matter where in the U.K. you are. You simply MUST get your Impreza into Power House for this susp. mod." |
09-21-2000, 08:27 PM | #19 |
Sooby Guru
Member#: 1914
SWIC
Anywhere in the US to get this done? Any instructions on the net??
Eric |
09-22-2000, 12:47 AM | #20 |
Member#: 277
SCIC
Well, still no word from Powerstation yet........
09-22-2000, 04:31 AM | #21 |
Member#: 1178
South East
As we sit and wait...
Oh to get rid of understeer What a happy day that will be.. I feel like Dr. Fankenstein "It's ALIVE,,,IT'S ALIVE!!!!!" and it doesn't understeer Oh well, E. |
09-26-2000, 02:33 AM | #22 |
Member#: 856
International
You guys still waiting?
I will have a chat with my mate who spends half his life doing work for these guys, see if he can get the info from them. He is on holiday right now so may be a week. cheers john |
09-26-2000, 06:05 AM | #23 |
Guest
Member#:
Yes still waiting. Now I notice the bumpsteering. I am wondering if the relocater shim for the rack is the a standard piece. I would like to have one.
09-27-2000, 01:09 PM | #24 |
Member#: 856
International
OK guys, some bad news i am afraid.
As powerstation brought this mod to market they are reluctant to let the info out. Thats fair enough, they spent the time to check this out. However. I can tell you how to sort this myself, it's not rocket science. What you guys need to do is go to a race workshop or similar, someone who sets up race cars, and get them to measure the front bump steer. This is a straight forward thing to do, every race car should have this dialed out. What they then need to do is shim the steering rack on its mounting points to move it until the bump steer is eliminated. A competent race shop will be able to do this, its common race car practice. I am going to try and get hold of the suspension geometry settings from a printout taken from a car set up on there laser alignment kit. The bump steer mod is worth getting done on its own, as long as you can handle a car with less inherant understeer. |
09-27-2000, 01:25 PM | #25 |
Member#: 644
Bump steer kits a very popular for lowered Porsches. If I remeber correctly bump steer is related to the tie rods not being parallel to the ground (at compresed ride height).
When a car is lowered, the rack is lowered hence the tie rods must rise to meet knuckle/hub. The kits lift the rack with shims until the tie rods are parallel with the ground (horizontal)again. I am not sure if the same applies to the Powerhouse mod. Tim |
10th anniversary of the P1 | Chris & Rosy B | Member's Car Gallery | 13 | 05-11-2010 03:36 AM |
The Myth of the Recovery | Mike Wevrick | Political Playground - Chaotic Neutral Edition | 53 | 04-05-2010 06:41 PM |
Myths of the Heathcare Bill | matt30 | Political Playground - Chaotic Neutral Edition | 22 | 09-09-2009 02:02 PM |
Unraveling the myth of the Straight Talk Express | HB_Dad | Political Playground - Chaotic Neutral Edition | 4 | 09-14-2008 12:12 AM |
Just ordered a set of the P1 rims (woo, hoo!) | gtguy | Brakes, Steering & Suspension | 3 | 12-06-2000 07:29 PM |
