Brakes & Suspension Forum sponsored by The Tire Rack |
02-15-2004, 02:09 AM | #1 |
Member#: 37579
Vehicle:2003 WRX WRB |
AutoX advice
Okay, so i'm an AutoX noob and have a few questions about driving a WRX in STX....
My current set up plan is: 40mm DMS coils with 250lb all the way around Noltec front caster/camber plates Rear Cusco plates 17x7.5 wheels with azenis sports i'm having a custom turbo back built, and going to get the accessPort cobb lightweight rear sway my alignment plan is: -3 camber front -2 camber rear no toe and as much caster as I can get my questions: dose that look good? will i need a front sway to stop overstear? or will my coils/alignment be able to handle it? can i get -2 camber in the rear with the 40mm and cusco plates, or will I need camber bolts? any other advice?
02-15-2004, 03:08 AM | #2 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Based on my experience with the DMS Golds you should be able to control the oversteer with front/rear damping mismatch and front/rear tire pressure adjustments.
Pat Olsen '97 Legacy 2.5GT sedan |
02-15-2004, 03:16 AM | #3 |
Member#: 31629
South East
Vehicle:2012 Mazda 2 Spirited Green |
sounds good to me, though I can't give advice on spring rates. Headers and up-pipe are also STX-legal, you may wanna think about those (sounds like money is not an issue here). Just make sure your not running more than stock boost. I think there is an STi part similair to an ALK that is STX-legal also, probably worth looking into. And don't forget the steering-rack bushings (not sure if its legal or not for stx). Definately get some links to go with the rear sway. Corner-weighting the DMS's will work wonders I would imagine. Not sure about the rear camber but you should be able to get close to -2 without bolts. And I almost forgot.....brakes!
Sounds like your on the right track. Have fun...STX is a very competitive class. Don't underestimate the mini's! |
02-15-2004, 09:05 AM | #4 |
Member#: 18148
Vehicle:'08 WRX Dark Gray |
It all depends on how serious you are and how street worthy you want your car. The setup you're talking about will give you a good general-purpose car.
With the setup you describe, too much oversteer won't be a problem. However, a front swaybar would help transitional response. I can get down to -1.2 degrees rear camber with Cusco adjustable plates. For STX, you can run camber bolts OR adjustable rear Camber plates, but not both. Make sure the COBB reflash doesn't touch boost. For an autox-specific setup, you'd want significantly higher spring rates and less rear camber. -Steve p.s. Oversteer is your friend on an autox course! It takes some pretty extreme settings to get a WRX to rotate too much for autox. Note - an optimally set up autox car will be a bit twitchy on the street. |
02-15-2004, 09:32 PM | #5 |
Member#: 48377
Vehicle:1996 Gutted, built XP class Impreza L |
I would add a little front toe out to help with higher overall grip in turns. Other than that I agree with MNbiker's comments.
02-16-2004, 12:28 PM | #6 | |
Member#: 18148
-Steve p.s. Toe out is really easy to set on Imprezas. I've done it at events a number of times. |
02-16-2004, 01:40 PM | #7 |
Member#: 37579
Would I really want all the toe? With all the caster that I will have with the noltec front caster plates?
02-16-2004, 03:44 PM | #8 | |
Member#: 18148
I do run a bit of toe out in back (as mentioned above), which affects a different part of the car's handling characteristics. -Steve |
Similar Threads | ||||
AutoX Advice Needed Please ;) Tire Presures, Open Exhaust ??? etc . . . | Hotrodguru | Texas Impreza Club Forum -- TXIC | 26 | 10-02-2004 01:10 AM |
I need AutoX advice....been into it for 2yrs | buster | Motorsports | 18 | 04-14-2004 07:04 PM |
AutoX advice | imprezive | South East Region Forum | 13 | 02-22-2003 09:51 PM |
First time autoxer ... advice needed | Ricter | South East Region Forum | 9 | 08-05-2002 09:33 PM |
