Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 08-22-2020, 10:38 PM   #1
Ryanvilas102
Member#: 491712
Default My 02 wrx has rough idle. Just replace long block.
Hey guys, I’m new here but have been a Subaru owner for about 2 years now and my wrx has had this problem sense I’ve owned it. But here we go pretty much I just got my ej205 swapped with a new block (also a ej205) because it had a motor knock and blow head gasket. So the people that did the swap for me used my old ecu all the sensors etc, etc but the car is still have sporadic idle, once it cools down the check engine light will pop on and it’ll bounce from 1000 to 1500 at a constant rate. The codes are for MAF sensor, coolant temp sensor (which I was told would come on if the car was shooting a MAF code) and also an idle air control valve code. The place that I got the motor from sent me the throttle body with the idle air control valve on it with the motor and used it instead of my old one but they told me the new one was throwing the code so they put the old one back on and it acted way worse so they put the that I got with the motor back on... so that’d be weird if both of them of them would be bad right? But anyways I’m just trying to figure what’s going on so I can finally drive this car again. Also back when the car had the original motor whoever had the car before messed with the wiring for the maf sensor so I had a mechanic cut it off and solder in a pig tail.. I’m not sure if this could be a problem as well. Like I said in the beginning I’ve had this problem sense I’ve owned the car.
Ryanvilas102 is offline   Reply With Quote
Old 10-04-2020, 09:38 AM   #2
dictoresno
Member#: 139816
2019 Impreza
have you tried cleaning the MAF sensor? if dirty, it can cause a rough idle.
dictoresno is offline   Reply With Quote
Old 12-01-2020, 11:05 PM   #3
Morgynn96
Member#: 520567
Default ?
Possibly it's the map sensor?
Morgynn96 is offline   Reply With Quote
Old 01-28-2021, 05:24 PM   #4
DeM6Nz
Member#: 522004
More then likely it’s the MAF sensor..
DeM6Nz is offline   Reply With Quote
Old 01-29-2021, 01:58 PM   #5
Ryanvilas102
Member#: 491712
I have replaced it it with 3 different MAF sensors they were used but I figured all of them couldn’t be bad. I’m thinking it’s due to vacuum leaks and also possibly bad wiring.
Old 02-10-2021, 02:31 PM   #6
Supersnake
Member#: 522031
You could try taking out the iacv and cleaning with some wd40
Supersnake is offline   Reply With Quote
