06-20-2020, 06:39 PM | #1 |
Member#: 369969
Vehicle:1998 Impreza Outback Black |
Rear drums to disc conversion
Hey all!
Got a 98 Impreza 5 Spd. Drums in back. Drums FINALLY are showing it’s wear. Given that opportunity I’d like to take this chance to convert the drums to disc. I’ve read I can convert them to late legacy models(98,99) with ABS. But what about 00-04 legacy models and 2.5 RS Imprezas? Does anyone know?
06-22-2020, 08:03 AM | #2 |
Member#: 19843
Vehicle:2000 2.5 RS Sedan 2016 Base 5MT VRP |
2.5 RS GC imprezas yes for sure,
I guess old rear disc car knuckles aren't too hard to find? IDK good luck getting the "big ass bolt" out of your old control arms though. Last edited by Cujo31; 07-13-2020 at 10:27 AM. |
07-09-2020, 08:02 PM | #3 |
Member#: 369969
That bolt it’s already broken. So my plan is replacing the control arms as well as the trailing arms. Just need to know the compatible years.
08-10-2020, 03:59 PM | #4 |
Member#: 369969
Update on this?? Anyone know what years is compatible with my 98 Impreza wagon?
08-22-2020, 05:26 PM | #5 |
Member#: 130623
Vehicle:1999 STi-R #95/1000 WRB (in Progress) |
You can bolt any Impreza or WRX up to at least 2005. 93-01 Impreza rear hubs would be the best bet.
The regular 06-07 Impreza rear discs will also work. 06-07 WRX hubs require a 16x7 wheel set, so unless you're doing a full upgrade, avoid. Legacy hubs from 93-01 should also work (they're the same as the Impreza). Do not get any of the 2004+ STi stuff. You will spend major $$$$ trying to get that to work. |
03-06-2021, 07:16 PM | #6 | |
Member#: 369969
Thank you for this reply (almost a year later for me to thank you!). I will keep this in mind when looking for parts. |
03-11-2021, 01:36 PM | #7 |
Member#: 372109
E. Canada
Vehicle:2018 WRX STI Pure red |
Reading this, what proportioning valve can we get?
I have a 2000 impreza L non ABS with rear drums. I'd like to convert to 2002 WRX rear assembly. What is needed exactly? hub, knuckle, disk, calipers, pads, , proportioning valve ? |
