08-22-2020, 12:13 PM | #51 | |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
08-22-2020, 01:59 PM | #52 | |
Member#: 15036
Vehicle:2004 STI WR blue |
Register here. Not that many people are registered since this one wasn't posted on the call club Rallycross site like the previous 4 this year were. Same organizer- vahan Anyone that wants to try reaching your car on dirt should go. The racing surface is a smooth dry lake bed. I run Street tires on it and it works great. The only issue is the road going in is a 3 mile dirt road with rocks. I drive my stock height 08 STI in and out without issue, but wouldn't take a lowered car. Here is the registration link http://www.myautoevents.com/pls/mae/frmEventList.Show?psevent_type_id=26 |
08-22-2020, 02:00 PM | #53 |
Member#: 15036
My appointment is coming up. I'm going in with a cat back, silicon IC piping, and agrimspeed AOS. Wish me luck
08-22-2020, 03:00 PM | #54 |
Member#: 29292
SCIC
08-23-2020, 12:48 AM | #55 |
Member#: 50586
BAIC
Vehicle:64 Impala |
08-23-2020, 03:51 PM | #56 |
Member#: 29292
SCIC
08-25-2020, 12:09 AM | #57 | |
Member#: 184183
SCIC
Vehicle:1996 Impreza RSTi V8 EJ207 Aerosim Carbon |
The silicone hoses are gonna be case by case(they could prob fail you if they want to be a dick about it, silicone has higher permeability than rubber hoses so technically it could make higher emissions). If you have an aftermarket silicone coupler they prob wont hold it against you but if you have a silicone turbo inlet that prob wont fly. |
08-26-2020, 04:00 AM | #58 |
Member#: 375696
SCIC
Vehicle:2011 Wrx STi Super duper silver love |
Just catching up to this thread again, so I thought I'd might post some information i recently received. This would only apply if you went from bone stock on a OEM factory tune to an Cobb AP3. (Or your tuner or you backed up the original factory tune in the first place*) I emailed them for clarification as to what exactly the AP backs up on its first marriage. The reply is posted below. This only may help some people and alleviate some concerns. But anyways I thought I'd pass this on.
"The Accessport does fully back up the Subaru ROM exactly as found at the time of install. When doing so it can even back up the data if the ROM is not fully stock such as the case if the car has previously been open source tuned without an Accessport. When uninstalling, the Accessport performs a file check on the backup to ensure integrity and then restores it if the file passes. This means that in some cases, an open source tune without any alerted CAL ID or ROM ID can be backed up and restored back to the car as the AP won't be able to detect it differing from stock. In other cases, the AP may detect the file is not indeed a stock ROM or that the file does not pass the integrity check and instead uses a known good file that is also scanned. This backup is a copy of the ROM provided by us directly from Subaru without any alteration. The AP always has the ability to restore the car to stock. On the note of CARB approval. The Subaru Accessports are not currently and have never been CARB approved. This is something we are currently working towards. Finally, on the note of inspections, there are some common issues. The first is cars originally being open source tuned and the Accessport restores this tune during the uninstall as discussed above. Second, some people flash the Stage0 map instead of uninstalling beliving that to be the same. However, Stage0 is a copy of the same engine calibrations as a stock file but in OTS map form with different ID's!" I think that makes a lot of sense. I'm satisfied with the reply. I hope this helps someone else down the bumpy road! |
08-26-2020, 12:39 PM | #59 | |
Member#: 29292
SCIC
09-23-2020, 11:39 PM | #60 |
Member#: 15036
So I had my ref appointment today. It was for sound only sure to a modified exhaust.
2008 STI I brought the car in with- Iag AOS Silicon IC pipes Cobb OTS stage 1 tune OBX cat back ( I thought it was quiet enough) I passed all visual checks and the OBD2 check...... And came in at 97 to 99db The limit is 95. The guy was nice and gave me several tries. I am installing my stock cat back and will re-test. I should have done that from the start but I wanted to pass with the exhaust so I could show any future cops. Oh well. |
09-24-2020, 12:22 AM | #61 |
Member#: 90804
SCIC
Vehicle:2021 Ascent 2012 Accord |
Thanks for the update!
09-26-2020, 01:12 AM | #62 | |
Member#: 100449
SCIC
Vehicle:'04 WRX 307whp278tq 03WRX wgn, '72 MGB |
09-26-2020, 10:11 AM | #63 |
Member#: 15036
09-28-2020, 08:22 PM | #64 |
Member#: 100449
SCIC
09-28-2020, 08:56 PM | #65 |
Member#: 15036
10-24-2020, 12:12 PM | #66 | |
Member#: 450677
Vehicle:2012 WRX Hatchback World RAlly Blue |
Im going to bump this post back up to the top. Just went in for my smog today. My DMV paperwork form stated Star Certified only. So found the local guy with a coupon, need to save a buck. Anyways he hooks it up and it pops up on the screen- "this vehicle can only be certified by a referee". He checked it twice and both times it said that. I can only assume its do to my Cobb OTS stage 1 flash. I only have the airbox. And its been like that for a full year. So I unistalled the AP, and will drive around until my readiness codes are set. Then need to find a referee and retest. I will update when I get more info.
10-25-2020, 10:33 PM | #67 |
Member#: 90804
SCIC
That sucks. At least you're mostly stock so no big deal to get it fixed.
10-25-2020, 10:38 PM | #68 |
Member#: 55252
SCIC
Vehicle:* pullup bar * |
wooof
10-25-2020, 11:17 PM | #69 |
Member#: 50586
BAIC
Vehicle:64 Impala |
11-24-2020, 10:50 PM | #70 |
Member#: 380971
BAIC
Vehicle:2013 WRX Silver |
Not a complaint here just checking my understanding:
So the COBB street fighter CAI has an EO sticker, but to SMOG (renew or sell) the car the whole kit must swap out for stock air box lest one risk engine damage (or poor smog/power etc) from stock tune not being calibrated for COBB intake. Right? And if leaving COBBs intake and tune in place, despite the sticker, it would fail the test with the AP tune (and go to referee then, and annually afterward). So is the sticker just for police inspections? |
11-25-2020, 12:44 AM | #71 | |
Member#: 171412
SCIC
If you REALLY want to keep it. Smog places will check for EO number. If it has it then visual inspection passes. As far as the tune goes, as long as all parameters are met it will pass. I do not have the stock engine nor tune. If you reflashed a day before it will not pass. ECU needs time to re-learn as well as putting some mileage before the test. If you flashed it a while a go and have been driving around it should be fine. No its not just for the police. Also go get a real tune and get off that OTS crap. Either run it stock or get a real tune. You'll feel more power from a tune than throwing a intake will ever do (to an extent) |
11-25-2020, 09:37 PM | #72 | |
Member#: 450677
11-27-2020, 02:58 PM | #73 |
Member#: 380971
BAIC
Thanks for the replies guys. I’m just going to revert to stock to avoid issues. The other question is whether removing tgv butterflies (but leaving shafts/motors/sensors intact) will impact readiness indicators. Anyone know?
11-29-2020, 02:12 PM | #74 |
Member#: 29292
SCIC
