Welcome to the North American Subaru Impreza Owners Club Wednesday July 9, 2025
Old 04-30-2025, 02:23 PM   #1
BajaBran
Member#: 540470
2003 wrx
sonic yellow
Default 3:90 to 4:11 swap
I've heard that people have swapped only the ring gear to get their rear diffs to 4:11, is that true? if not, could i take my diff out and swap it into the case with the 4:11 gears? the reason why i wanna swap the gears and not just the whole diff all in one is because the 4:11 diff has some pretty bad rust inside where the axle splines go, and i'd rather not keep "gambling" on different used diffs hoping to get a good one. just hoping i can get something usable while i have it
BajaBran is offline   Reply With Quote
Old 05-05-2025, 07:05 AM   #2
Unabomber
Big Ron
Super Moderator
Member#: 18062
2004 WRX Sport Wagon
Platinum Silver Metallic
I mean you can, but you'd blow up your center diff in short order. To do a proper swap, you have to ensure your front diff, center diff and rear diff all play nicely with proper ratios, so just doing the rear is not wise at all. Get a used 3.90 pumpkin and swap the whole ding dong thing out as they are cheap.
Old 05-05-2025, 10:44 AM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I believe you can swap your 3:90 gears/diff (complete) into a 4:11 case. I believe the case is the same.
You should still check gear engagement since the machining of the case may be different and you may need to change shims.
Do NOT just "swap parts of the diff", rings and pinions are different (I believe) AND the ratio needs to match the other 2 diff's in the car.
As Unabomber stated, just get a "new to you" diff., YMMV.
Old 05-06-2025, 04:59 PM   #4
BajaBran
Member#: 540470
2003 wrx
sonic yellow
Reason why I'm swapping to 4:11 is because my replacement tranny is 4:11. I was planning on making sure I've got good engagement on the ring gear after I swap my pumpkin over, just wanted to make sure that's something I can even do before I rip everything out. Thanks a ton for the insight, both of you
Old 06-20-2025, 08:54 PM   #5
SubieDoucheDrew
Member#: 531630
2000 00Gc8, 03GD
Silver/both
Default not so sure
The ring AND pinion are different from a 411 to a 390 diff, why not just get a 411 diff from a junk yard?
SubieDoucheDrew is offline   Reply With Quote
