#1 |
Member#: 296058
AKIC
Vehicle:2003 WRX Rally Blue |
![]() Hi guys. my car showed up a code P1088. i guess it has something to do with the TGV. but i have no idea what am i suppose to do. and no idea wher to start. anyone can help explain whats going on and how to fix it. maybe some pictures of locations.? thanks a whole bunch
#2 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
![]() did ya even THINK of searching that one????
#3 |
Member#: 296058
AKIC
![]() yes i did scotty. thats why i was asking for help because what i have found so far is just the same words over and over put in different ways. i havent really gotten any real solution.
#4 |
Medium Frank
Moderator Member#: 140114
Vehicle:2020 Subaru Outback |
![]() P1088-Tumble Generator Valve #1 (RH) Position Sensor Circuit Low Input
Being a thinking man, I would conclude your Right Side TGV position sensor is bad. Crazy eh? |
#5 | |
Member#: 296058
AKIC
![]() Quote:
#6 |
Member#: 293652
RMIC
![]() Looks like a job for... Repair man man man man!! Tehe
#7 |
Member#: 296058
AKIC
![]() Pictures
#8 |
Member#: 315868
Vehicle:2006 WRX white/carbon fiber |
![]() Back side of the tgv nestled up next to the turbo, has a 2 wire connector going to it, i have found info to support that particular sensor is the same as a tps sensor which is important because i did not find the tgv sensor available without the entire tgv assembly.....your findings may vary.
#9 |
Member#: 321409
SWIC
Vehicle:2003 Big Effing Van 7.3L powerstroke diesel |
#10 |
Medium Frank
![]() If you don't have any idea how to fix it, find a repair shop. Simple. Obviously it was hard enough for you to search on the subject, and TGV's can be a fairly intimidating job for someone without basic skills.
#11 |
Member#: 315384
Vehicle:2005 Porsche 904 kit Silver |
![]() Check out P2009 DTC should be the same thing.
#12 | |
Member#: 315384
![]() JUST A REMINDER:
http://forums.nasioc.com/forums/misc.php?do=cfrules Quote:
#13 |
Member#: 296058
AKIC
![]() Soo back again...i had the check engine light turned on with the code p1088 i was gonna have replace the tgv sensor but while I was driving, my check engine light turned off. I used the obd2 to diagnose to see if the code was still ther and it was so i decided to delete it and see if it would come back on. And few fays ago it came back one with both the same code p1088 and a new code p1090. Any tips??
#14 |
Member#: 315384
![]() Get hold of the service manual for your car, I know that those codes are in the manual.
#15 |
Member#: 326998
Vehicle:2009 WRX sedan WRB TP-Stg2 |
![]() well what year/model car do you have? Because i would imagine if your car is new enough and still covered under factory/extended warranty. That taking it to a dealership may be your best bet?
#16 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
![]() Both codes are TGV. I would think that looking at both wiring/connection and the tgv itself might be a place to start.
Or see your friendly local Subaru mechanic to fix this for you. |
#17 |
Member#: 296058
AKIC
![]() Its a 2003 wrx. So i dont believe warranty will play a role in this situation.
Gosh! Thing is is that i dont wanna play with the car wen it sooo close to winter already. But any tips on where to start? |
#18 | ||
Member#: 321321
Vehicle:2010 Ford SVT Raptor Tuxedo Black |
![]() Quote:
#19 |
Member#: 315384
#20 |
Member#: 42133
PRSIC
Vehicle:2002 Impreza WRX Rally Blue Pearl |
![]() Ok,is an old thread but right now i get this code too and found those videos:
