11-01-2019, 10:59 PM | #10151 |
Member#: 16840
Vehicle:17 4Runner |
I have the Sonos sound bar and the sub and like them for the living room. The usability and ease of setup along with the whole Sonos integration thing is worth the price to me.
To me something like that is an ideal odd-shaped no built in wires room solution for anybody non-audiophile. It’s like the apple of speakers.
11-02-2019, 02:21 AM | #10152 | |
Member#: 52314
South East
Vehicle:... 02 and 04 WRXs! 2020 G70 3.3T RWD |
Klipsch Reference RSB-11 Sound Bar with Wireless Subwoofer |
11-04-2019, 11:42 AM | #10153 |
Member#: 43357
Vehicle:2004 Smug 46MPG 2016 Clown Car also zoom3 |
Hmm. Apparently my research is not complete, then. Most of my collection is DTS, so I would need that capability.
Rethinking the idea.....Not liking it, but liking the savings if I don't spend as much as I would on the sonos system. |
11-04-2019, 01:57 PM | #10154 | |
Member#: 43357
But the more I read about the stuff the more confused I get. There are way too many abbreviations. I may just lave it the hell alone and continue using my 9 year old Sony HTIB 5.1 system. Just may have to man up and brave the spiders in the crawlspace to run cables. Or do the tacky cable management along the trim in the room and run cables that way. |
11-04-2019, 02:11 PM | #10155 | |
Member#: 21356
NESIC
Vehicle:2017 Subaru Corolla STI Limited SE-R Type (R) |
All video codecs and HDR types (DV, HDR10+), and all sound codecs (Dolby up to Atmos and DTS up to DTS-X, so all). Everything else mentioned is just DSP settings for sound and video (make stuff sound cooler) I would pull the bottom wall trims and run cables through there. Sound bars are just for the convenience of not having to pass cables to the rear speakers/sub. |
11-04-2019, 02:19 PM | #10156 |
Member#: 43357
I tried to pull the baseboards when I was installing the flooring, but, that wasn't going to work. I ended up cheating and installed the flooring then had to quarter-round it.
There are two open archways I would have to route the wire around, as well. That's why I wanted to go the wireless route. At that price, it will be more expensive than the Sonos play bar + 2-pack Play:1 combo I was looking at at Costco, but, at least this one includes a sub at this price point. If I were to get both a Sony TV and the sound bar from Crutchfield, though, I get to save $200 on the sound bar. I was going to get the LG 55" C9 TV from Costco, but now I can get the Sony XBR-55A8G for the same price at Crutchfield. Hmmm.... |
11-04-2019, 03:30 PM | #10157 |
Member#: 34670
South East
Vehicle:2016 slowmobile |
Why is the **** just so much confusion. And then different brands call the same feature different things sometimes! |
11-04-2019, 04:47 PM | #10158 |
Member#: 13772
RMIC
Vehicle:16 Frontier Red |
Baseboards painted/caulked to the wall? I've had to run a razor blade along baseboards a few times to get them off without destroying the wall/paint.
11-04-2019, 05:56 PM | #10159 |
Member#: 262254
Vehicle:2000 silver/ tan |
Rearranged my room and got rid of my 106" Elite pull down screen. Replaced it with a 125" Akia zero edge fixed. Moved all my equipment to a rack and got an articulating mount to still use my 900e. Very happy with the results the screen is amazing. Just waiting on some black velvet for the screen wall.
11-04-2019, 07:49 PM | #10160 |
Member#: 43357
Not sure. They've been there since 1968 and when I tried to remove, I couldn't without damaging the drywall. So I just went around. If I could pull them off, I would replace with taller baseboards too
11-04-2019, 07:51 PM | #10161 | |
Member#: 43357
Almost pulled the trigger on the TV / HT combo up there, but decided I didn't really need it and stopped. |
11-05-2019, 08:46 AM | #10162 |
Member#: 34670
South East
My biggest beef is that the sound bar won't passively pass signal when connected with HDMI to the HDMI ARC input on my TV. I don't really want to watch the morning news with the sound bar and sub, ya know? So I fell back to the optical connector, which is just dumb.
I was in that boat, but the wife was with me as I was comparing systems and got "oooh, that one. It sounds really good, better than the other one." So, well, there you have it. |
11-05-2019, 08:53 AM | #10163 |
Member#: 43357
Yeah. I hear you.
I put that project on hold for now. I think cable management systems will be cheaper, and I am reconsidering the placement of the TV as I previously planned. |
11-05-2019, 08:55 AM | #10164 | |
Member#: 17975
Vehicle:2023 Macan GTS Python Green |
11-05-2019, 08:56 AM | #10165 | |
Member#: 52314
South East
11-05-2019, 09:40 AM | #10166 | |
Member#: 13772
RMIC
I'm using a 1080p PJ and after 4 years it still brings a smile to my face every time - even with not so great source material. I want to upgrade to a laser PJ next... someday. Who needs a furnace, or a water heater, or siding, frickin lasers are all you need right? |
11-05-2019, 10:05 AM | #10167 | |
Member#: 17975
11-05-2019, 11:22 AM | #10168 | |
Member#: 262254
The HT3550 has vertical lens shift only, so make sure you check the projector calculator found on their site to make sure it will work for your distance and screen size. I'm doing 125" from approx 12 feet. I would definitely recommend a fiber hdmi cable such as the Ruipro brand. A little pricey but will save you any hdmi issues, especially if you'll have a longer run. The Akia screen is also a hidden gem. They're made by Elite Screens and are a great quality for the price. Note, if you game the lag is somewhat high on the 3550, but unless you're playing fps competitively it's not that bad. If you have any questions, feel free to ask. -Justin |
11-05-2019, 12:11 PM | #10169 | |
Member#: 34670
South East
I guess I could try as you suggest and see what happens. |
11-05-2019, 01:26 PM | #10170 | |
Member#: 34670
South East
And another rant... what takes so long with these devices? I plugged it all in and no sound. Jiggled, pressed buttons, nothing. Walk upstairs to office and delete emails, come back down and as I'm about to give up the TV flashes "Amp Volume" and starts using the soundbar. |
11-05-2019, 04:01 PM | #10171 |
Member#: 21356
NESIC
Regular ARC can go up to DD+ while optical can do up to DD.
e-ARC can go all the way to newest format. Gripe: My Sony receiver got a firmware update to enable e-Arc, my Sony TV did not. Dont matter, I got the Shield. |
11-11-2019, 09:30 AM | #10172 | |
Member#: 303030
BAIC
Vehicle:2009 STI DGM |
I've been completely out of HT at home for almost 10 years. Just moved, just reconnected everything via wired (cable management with flat speaker wire tucked along the ceiling). I've got a really old Onkyo 7.1..but only wired 5.1. Speakers are a full Polk TSi/CSi setup and I have a couple of small Polk for satellite. Really enjoying the simplicity of this setup. TV has an optical out and I'm loosely considering swapping out my ancient Onkyo and getting a Marantz 1609 or 1710 to modernize, get something smiller and for bluetooth/wifi. Possibly adding a couple of atmos enabled floorstanding front channels. |
11-11-2019, 10:12 AM | #10173 |
Member#: 34670
South East
Yes, TV < sound bar < proper receiver.
Newer higher end soundbars have come a long way, but just can't compete if you have the room for a proper setup. Soundbars are super simple. I did find out that audio over the HDMI - ARC is superior to digital if you have that option. My 5 year old Insignia dumb TV even has it. |
11-11-2019, 11:42 AM | #10174 | |
Member#: 43357
11-12-2019, 11:20 AM | #10175 |
Member#: 34670
South East
Bought the soundbar, and in a moment of weakness almost got the Square Trade warranty when it popped up. Then the maths hit...
It adds 2 years of warranty for basically 10% of the purchase price. Doesn't even cover accidents. |
The official Post pics of your Home Audio/Video setup? V2.0 | GRUMPY514 | Off-Topic | 74 | 07-30-2008 09:50 AM |
VA: Home Audio/Video/Game | AspenWhite | Non-Subaru Stuff | 5 | 03-06-2007 09:43 AM |
WRX parts, home Audio/Video stuff, and more... | NicFunkadelic | NESIC Private Classifieds | 6 | 02-15-2007 10:38 AM |
Home audio/video wiring gurus, need a bit of help. | trail*of*dead | Off-Topic | 16 | 12-23-2006 02:25 AM |
Home audio/video goodies for sale! Tivo! Replay! Pronto! | BiggSean | Private 'For Sale' Classifieds | 7 | 02-26-2006 11:15 PM |
