Brakes & Suspension Forum sponsored by The Tire Rack |
04-26-2021, 06:03 PM | #1 |
Member#: 443213
Vehicle:2005 Saab 9-2x |
Axle bind after lift
My car is an 05 NA Saabaru with a 5 speed. I've lifted it with Forester struts and it also has sedan control arms with sedan axles. Ever since the lift a few months ago I've been fighting my driver front axle clunking after turning and going from a stop. The axle has been swapped with the same issue. Everything I read says there shouldn't be any issues and I can't find any similar issues after a common lift like this. Ideas?
04-28-2021, 07:30 AM | #2 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
Oh boy, when I bought my 02 WRX it had Forester struts on it and was lifted, so should be more or less identical to what you're running. It never had an issue that I knew of before I removed the Forester stuff. I didn't keep it that way for long.
When you swap axles, did they immediately clunk? If so, I would suspect the clunk is something else. |
05-01-2021, 02:54 PM | #3 | |
Member#: 443213
