Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 02-23-2020, 09:39 PM   #1
xX_STI_Xx
Member#: 493470
2019 STI
Crystal White Pearl
Default Dashboard and Interior Material Cleaning???
Hi,
For those of you with a VA2 chassis WRX or STI, what have you used to clean the rubber dashboard on your cars? I have never cleaned the dashboard since I purchased the car new, and it has a white-ish film in sunlight that I have thought about cleaning, but am afraid to use the wrong cleaner or detergents. Any recommendations would be appreciated. Thanks.
xX_STI_Xx is offline   Reply With Quote
Old 02-23-2020, 10:30 PM   #2
Blktrax
Member#: 220971
2004 Impreza
https://www.goldeagle.com/product/30...ve-protectant/
Use this on the dash, all the hard plastics, and the soft rubber door seals.
Blktrax is offline   Reply With Quote
Old 02-24-2020, 06:28 AM   #3
HCAutoDetail
Member#: 451697
1998 Outback Sport
Green/Slate
If you feel as though there is a buildup of crud on the dash, old dirt and dust, or an accumulation of previous interior dressings that you've used, it's a good idea to clean it FIRST before adding more dressing. A water damp microfiber just might do the trick. If you need a little cleaning ability, spray your microfiber with an all purpose cleaner diluted in strength. Meguiar's has a gallon jug of All Purpose Cleaner that is concentrated. You mix it 10:1 in a spray bottle. It can be used for tons of cleaning needs, in the car or in the home. May be the last cleaner you buy for a while!
After that, Aerospace 303 (mentioned above) or another UV protectant dressing would be added. Some dressings have the level of gloss listed on their label; satin, flat, glossy, etc.
HCAutoDetail is offline   Reply With Quote
Old 02-24-2020, 12:30 PM   #4
xX_STI_Xx
Member#: 493470
2019 STI
Crystal White Pearl
Thank you both!
I have never cleaned the dashboard or even wiped it since new. The car was purchased November 2018, and currently has 2600 miles lol. This will be the first wipe down of anything interior.
Old 02-24-2020, 01:29 PM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
I've had great luck with Griot's interior cleaner:
https://www.griotsgarage.com/product...ior+cleaner.do
but I also keep a clean microfiber towel in the car and wipe it clean often
Old 02-24-2020, 04:57 PM   #6
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
A mild soapy-water mixture is generally recommended by vehicle manufacturers.
car_freak85 is offline   Reply With Quote
Old 02-24-2020, 06:55 PM   #7
mvadenais
Member#: 472751
2018 WRX
Griots interior cleaner is great stuff. I usually dust (California duster) then do a quick clean with the interior cleaner. About every other cleaning I'll dress the dash and other things with the griots interior detailer.
mvadenais is offline   Reply With Quote
Old 02-25-2020, 01:13 AM   #8
amyacker
Member#: 511987
2001 2001 Forester
The only issue I had was getting the wipes out of the container. It had a seal over it, and took seal off, the cloths are connected, but having problems getting out of the spout. I open up, got a couple ripped off, and tried it on my car's dash.
amyacker is offline   Reply With Quote
Old 03-02-2020, 04:08 PM   #9
zbrewha863
Member#: 512121
2020 STI
World Rally Blue
I like the Armor All cleaning wipes for daily stuff, I keep some in the trunk. And for detailing that 303 is good, but I like Chemical Guys Inner Clean:
https://www.chemicalguys.com/innercl...pineapple.html
zbrewha863 is offline   Reply With Quote
Old 03-17-2020, 02:24 PM   #10
joesstripclub
Member#: 461015
2017 WRX
I'm a fan of the Meguiars Vinyl and Rubber Cleaner as I used to use it when I was detailing cars. It will clean the dust off, but it will save your conditioner towel to wipe down with a wet microfiber first. And get a good detailing brush for crevices if you dont want to look like an amateur.
joesstripclub is offline   Reply With Quote
Old 03-17-2020, 04:44 PM   #11
trey99ek
Member#: 497127
As far as actual cleaning goes I just use a microfiber damp with warm water. After that I wipe it down with aerospace 303.
trey99ek is offline   Reply With Quote
Old 03-22-2020, 10:05 AM   #12
Applecore
Member#: 512800
I've always had terrible luck with those container things.
Applecore is offline   Reply With Quote
Old 03-27-2020, 11:44 AM   #13
electricmarquis
Member#: 407348
2020 STI
CWP
The new rubber dashes are crap to clean. On my regular impreza I tried CarPro Pearl to add some slickness. It made the cleaning a bit easier. I have yet to find a towel that does not grab like a magnet.
electricmarquis is offline   Reply With Quote
Old 04-06-2020, 04:20 AM   #14
Antony44
Member#: 513199
whate
I have been using it LIQUI MOLY KUNSTSTOFF-TIEFEN-PFLEGER for a long time. This product is a classic plastic cleaner with a revitalizing effect. I use it as well as in everyday life.
It has anti-static and dirt-repellent effect.https://grilliam.com/
Antony44 is offline   Reply With Quote
Old 04-06-2020, 04:44 AM   #15
Fishreeler
Member#: 511441
grey
CarPro Pearl also use it easily cleans everything!
Fishreeler is offline   Reply With Quote
Old 04-19-2020, 11:37 PM   #16
Kaykay
Member#: 409353
I use a Swiffer duster on that spot first. It helps a lot with the majority of the dust and dirt. Then I do the microfibre cloth with a gentle soap and warm water. Seems to work well and then you can do whatever protective stuff afterwards.
Kaykay is offline   Reply With Quote
Old 03-30-2021, 04:41 PM   #17
LenaGaleana
Member#: 504046
Use this on the dash, all the hard plastics, and the soft rubber door seals.[/quote]
This is great means for cleaning. Indeed. If you want to do it on your own. But if you have no idea or time for this, rather a great variant is to ask professional help to make everything perfect. Why not save time and money?
LenaGaleana is offline   Reply With Quote
Old 04-20-2021, 12:42 AM   #18
Suberion
Member#: 523795
Love this stuff- it’s all I use and it does wonders in the TX heat. No greasy feeling either.
Suberion is offline   Reply With Quote
Old 06-02-2021, 07:47 AM   #19
SLOOWSCOOB
Member#: 524671
Chemical Guys "Interior Clean" works great for me!
SLOOWSCOOB is offline   Reply With Quote
Old 06-07-2021, 04:38 AM   #20
Solowsti
Member#: 359833
I’ve used the interior detailed from adams with great results!
Solowsti is offline   Reply With Quote
Old 06-10-2021, 12:25 PM   #21
GloriaH
Member#: 524825
2014 Chevrolet
black
Hello everyone here, guys. Well, as for me, I usually use Simple Green - Deck + Fence cleaner and Karcher for outdoor surfaces, and I guess that you can also try any of these pressure washer soaps and detergents. I just thought that this article can help you to compare different variants and then make the best decision after it. I hope that it will help you a little bit. You will be able to order anything on Amazon.
GloriaH is offline   Reply With Quote
Old 07-26-2021, 03:47 AM   #22
brylemr
Member#: 414507
I use 303 also because it is not greasy and shiny.
brylemr is offline   Reply With Quote
Old 08-31-2021, 12:04 PM   #23
usdmf
Member#: 526173
Glass cleaner -> 303
usdmf is offline   Reply With Quote
Old 09-11-2021, 03:40 PM   #24
pe3046
Member#: 526507
SILVER
In the heat here, I really like the 303 but really prefer the finish of Einzett Cockpit Cleaner which was recommended to me over on some detailing forums. It has the most natural finish and the looks clean and new. The 303 tends to get a bit too shiny for me, but the UV protection is nice. It really works well on the plastic pieces in the engine compartment.
pe3046 is offline   Reply With Quote
Old 09-24-2021, 02:13 PM   #25
Scootin0605
Member#: 510129
2004 Wrx Sti
me personally, i use chemical guys interior cleaner. its pretty much all purpose, and it also smells really good
Scootin0605 is offline   Reply With Quote
