08-29-2015, 05:09 PM | #1 |
Member#: 423975
Broken pitch stop firewall mount...
As the title says. Been feeling a clunk lately while shifting. Thought it may be the differential clunk that comes typically in these cars. Ran out real quick and popped the inter cooler off to inspect the pitch stop. Damn thing has broken all the welds and there is actual metal split in half. Another user here had the same issue but couldn't find the thread. Any thoughts? I know, take it to the dealer. I ask because it looks to be quite the task to replace.
Thanks!
08-29-2015, 06:18 PM | #2 |
Member#: 423975
08-29-2015, 06:31 PM | #3 |
Member#: 404807
Vehicle:2015 WRX Crystal Black Silica |
Looks like the aftermarket pitch stops are too rigid. I've been considering buying one but now I'm definitely going to take a look at this mounting point and see if there is anyway to reinforce it or get some more weld in there.
08-29-2015, 06:35 PM | #4 |
Member#: 423975
Not sure if you can tell from the pic, the left side is actually broken... As in the metal snapped in half. No amount of welding is going to help that. It is probably safe to assume that ALL of the mounts should be upgraded at the same time rather than piece by piece. Strengthen one to make the weak point another. I am just curious how much work this is going to take to fix/ correct.
08-29-2015, 07:26 PM | #5 |
Member#: 337626
TXIC
Vehicle:2015 WRX Crystal White Pearl |
This was my concern originally and why I went with the group n pitch mount instead of the overkill ones from perrin, torque solutions, beatrush ... and pretty much every other aftermarket company because everybody makes these You can try contacting Laile/Beatrush, but they are over the ocean, language barrier and I doubt they provide any kind of warranty especially for a gaijin
Do you have any other aftermarket drivetrain mounts/bushings? How long have you had that part installed? That may indicate how many people will soon have this issue because that is a very popular part. |
08-29-2015, 07:37 PM | #6 |
Member#: 423975
No other mounts except the Beatrush. Yea, wasn't even going to bother going the route of contacting them. Aftermarket parts are pretty much install at own risk. It does exactly what it is supposed to. I am going to take it in to Subaru. I've got a few "friends/enthusiasts" I know you that work for them including a service advisor. It has been installed for about 2 months now and 1500 miles of driving.
I agree, it could become an epidemic at some point. Lot of stage 2's running around with them. I searched and searched but couldn't find the other thread about a guy that just purchased either a 15 or 16 all stock same exact issue. Metal cracked and entire mount had moved from the firewall. It came from the dealer that way if I remember correctly. |
08-29-2015, 07:48 PM | #7 |
Member#: 378996
Vehicle:2015 LightingRed WRX 2009 Accord Exl v6 (sold) |
Wow that's crazy :0 just about to order one.
Did you notice the new clanking after some spirited driving? Is the mount to the firewall just flimsy? |
08-29-2015, 07:54 PM | #8 |
Member#: 423975
It's more of a thud and only when shifting spiritedly.
Yea, it would appear that the mount on the firewall is a tad on the flimsy side. Ha ha. Apparently Subarus have been notorious for bad welds on earlier models. The metal splitting in half could be so many different things. |
08-29-2015, 09:14 PM | #9 |
Member#: 94623
NESIC
Vehicle:2015 Wrx Limited GBP |
this is on a 2015? lets us know how it works out for you.
08-29-2015, 09:29 PM | #10 |
Member#: 423975
Yea, 2015. Just scheduled my appointment for Tuesday.
08-29-2015, 09:31 PM | #11 |
Member#: 393629
W. Canada
This is EXACTLY the reason I'm not buying an aftermarket pitch stop. It simply transfers too much force to the chassis due to the rigidity of the mount whereas the stock one will break way before... this happens.
08-29-2015, 09:39 PM | #12 |
Member#: 423975
I need to find that thread with the stock one that did the exact same thing. I would be amazed if the only one that this has happened to.
08-29-2015, 10:14 PM | #13 |
Member#: 288345
Vehicle:2015 WRX Limited CBS |
I was picking up parts at a local dealer several months ago and saw a 15 on their lift. I asked the service manager what it was in for and he explained that the firewall pitch stop mount had failed and subaru had sent engineers to have a look at the car. It was modded and was going to be covered under warranty. Apparently subaru is aware that this is an issue.
08-29-2015, 10:14 PM | #14 |
Member#: 165955
Vehicle:2015 WRX Base WRB |
Jesus....Weld failed...No way that should happen.
08-29-2015, 10:16 PM | #15 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
this just proves to me that FHI has a REAL PROBLEM with the design and execution of their body structure in general and the firewall in particular
I HOPE SOMEBODY AT FHI IS LOOKING AT THIS AS BEING THE REAL PROBLEM THAT IT IS!!!!!!!!!!! this kind of cheezy BS with firewall welds failing tells ME that there is no way in HELL im buying one of these matchbox POS cars again. you GOTTA BE KIDDING weldS WELDS THIS IS A MULTIPLE WELD FAILURE |
08-29-2015, 10:21 PM | #16 | |
Member#: 165955
08-29-2015, 10:41 PM | #17 | |
Member#: 423975
08-29-2015, 10:50 PM | #18 | |
Member#: 9264
Vehicle:2016 BMW M235i 6MT |
What other weld issues are you so terribly concerned about? Last edited by MaddMax; 08-29-2015 at 11:05 PM. |
08-29-2015, 10:52 PM | #19 |
Member#: 391110
Vehicle:15' STI |
Looking at the picture, it does not appear that the actual welds broke but rather the metal. Certainly this shouldn't be happening but some bad metal on a car is a little better than a improperly engineered chassis.. I guess.
Will be interesting to see how they handle this. Even with the aftermarket part, I would not be surprised to see a fix due to the safety concerns.. |
08-29-2015, 10:57 PM | #20 |
Member#: 423975
My pictures aren't the greatest. There are definitely busted welds along with the actual metal. I would assume the welds snapped then the metal.
As stated though, it will get repaired one way or another. |
08-29-2015, 11:39 PM | #21 | |
Member#: 16200
maxie boi you are well and truly a ****ing blithering idiot |
08-30-2015, 12:57 AM | #22 |
Member#: 288345
I guess there's a market for pitch stop brace's the same way there was/is a market for master cylinder braces in previous gen wrx's
08-30-2015, 07:25 AM | #23 | |
Member#: 16200
no...this issue isn't the same kind of thing.....but it DOES show that there IS an issue with the design and materials used at the firewall....an ongoing issue. if Subaru doesn't get its act together and fix this kind of ****.....nobody is going to buy their cars |
08-30-2015, 10:16 AM | #24 |
Member#: 423270
Vehicle:2015 WRX (sold) |
I've read of a few of these failures now. All seemed to be using the more rigid of the aftermarket mounts.
Has anyone seen this happen on a stock or group n pitch mount? |
08-30-2015, 11:32 AM | #25 |
Member#: 67
SCIC
Vehicle:1999 Outlasting the competition. |
Just skimmed the post. Do you have upgraded engine and trans mounts? We've said it before. You should do all three at the same time. Engine, Pitch, Trans mounts.
No idea what the durometer is on the BR pitch mounts. |
