08-21-2018, 09:49 PM | #1 |
Member Sales Rating: (11)
Member#: 301166
Vehicle:02 WRX V7 Swap WRB |
FL: Full Partout - 2002 WRX WRB FULL JDM STI Swap RUST FREE
Parting out my 02 WRX with V7 EJ207, 05 STI 6 spd, JDM R180, Brembos etc. Motor was perfect was making 385whp with a JR tune, and I had it out and apart to do ARP headstuds so I could turn up the boost, but other priorities happened. Decided to just part the whole thing to get more money out of it for a house.
If you don't see certain performance or appearance items listed that probably means they are sold, otherwise feel free to ask about anything else you might need! Pictures of for sale items: https://drive.google.com/open?id=1Qo...2kbRCXpkInU2vE Engine (55k miles): - V7 EJ207 Heads 700 - V7 EJ207 Shortblock 700 - Full Manifold Assembly fuel rails, harness 500 - Red Perrin Inlet 150 - Genuine Fujitsubo Header/Uppipe 600 - JDM Power Steering cooler w/ res - 50 - EJ207 AVCS Cam Gears 250 - EJ207 Timing Cover set 60 - EJ207 AC Compressor 80 - PS pump 75ea - Alternator 50ea - 06 Sti Oil Pan/Baffle 40 - Sti Oil Cooler 60 - V7 EJ207 ECU 180 - 02 WRX USDM ECU - 80 - OE Subaru Front O2 50 - OE Subaru Rear O2 30 - Sti Crank pulley 30 - Walbro 255 40 - Misc AC lines 40ea Drivetrain/Brakes: - 2005 Sti Transmission (w/stubs, cross members, fork, pin) - 2200 - DCCDpro manual controller (needs switch) 120 - JDM R180 (Clutch LSD) 500 - Sti Axles - 150ea - 5x100 Brembo/hub swap complete 1200 - Sti Driveshaft 80 - Clutch Hydraulics (MC, line, SC) 60 - Brake boost, MC - 35 Suspension/Steering: - ISC N1 Street Comfort Coilovers w/Rear Camber plates and extenders - 750 - Sti aluminum control arms 200 - Steering Rack 120 - PS Res w/line 40 - Steering column with ignition/key 60 - Rear Subframe w/ lateral links 100 - Front subframe 100 Exterior: - JDM Sti Scoop WRB 150 - Mirrors WRB 40ea - Tail lights 30ea - JDM Sti front fenders WRB 120ea - 02-05 Sideskirts WRB 100 - Doors (complete minus door cards) 150ea - WRB Sti Fog light covers 150 - WRB tow hook cover 20 - WRB Fuel door 30 Interior: - Ver8 Spec C steering wheel w/ clock spring - 250 - WRX embroidered floor mats 60 - STI blue floor mats 80 - 02-07 OEM Subaru all weather mats - 40 - 02-03 WRX seats - 180 - 02-03 Door cards - 80 - 02-07 Black carpet - 100 - Clutch/Brake pedal assembly - 70 - Gas Pedal 40 - Autometer Boost gauge - $20 - Complete OEM Subaru Carbon Fiber Trim set 150 - Sti 6spd knob 35 - Complete dash w/ airbag 150 - Complete 02 WRX Chassis Harness w/ AVCS wiring 250 - Seatbelts full set 50 - Wiper/Signal Assembly 40 - Ebrake Handle 20 - Lower Driver Dash w/switches 30 - Lower Center Dash 30 - Glovebox 50 - Shift boot assembly 25 - Ebrake Console section 30 - Full Console w/armrest extension 40 - HVAC Controls 40 - 6CD Changer Radio 40 - Steering column upper/lower trim 25 Miscellaneous: - JDM OEM HID ballasts with pig tails 100 - 02-03 Complete core support 80 - 02-03 JDM lightweight bumper beam - 80 - 02 WRX Fuel Pump Controller 40 - ABS pump 30 - Heater Core - 50 - Front Chassis Harness withfull fuse box (partially cut) 75 - Wiper Motor Assembly 75 - Trunk/Gas Door release cables 20 - Hood Latch Release Lever Free - Hood hinge set 15 - Cowl Cover 40 - Washer Bottle w/ motor 20 - Wipers w/good blades - 25 - Evap canister and all hoses etc. 40
