10-07-2000, 01:22 AM | #1 |
Member#: 2501
Gear Ratios
What gear ratio is in a MY00? What other ratios are available? Thanks for any help.
10-07-2000, 04:23 AM | #2 |
Member#: 2501
Forgot to tell yall that it's an rs. Sorry.
10-07-2000, 05:00 AM | #3 |
Member#: 1904
TXIC
Vehicle:2017 Impreza Sport E36 M3/4/5 |
hey, i don't know them offhand... but it is in the owners manual, and if you don't own one, either you could do a search here, or find someone's personal web-page, and lots of people have it listed there.
10-08-2000, 11:42 PM | #4 |
Member#: 1366
VIC
Vehicle:2000 RS-T -> RSTi-8 Blue Ridge Pearl |
Only the forward gears:
3.545, 2.111, 1.448, 1.088, 0.780 Final = 4.11 |
10-09-2000, 02:24 PM | #5 |
Member#: 1510
If it's an automatic..the final is 4.44
10-12-2000, 05:24 PM | #6 |
Member#: 2501
Thanks, but are there any other final drive ratios available? Right now my car just has an intake and exhaust and I can almost wind 5th gear completely out(5900 rpm). If I put on a turbo(50+ hp) I will definitely run out of gear.
10-12-2000, 10:11 PM | #7 |
Member#: 2501
bump
10-13-2000, 08:54 AM | #8 |
Member#: 524
Vehicle:04 STi White |
Yes there is other trannies that fit, depending on how cute you want to get with it.
The most likely one you would want is the legacy double overdrive unit. If you want to play with 1/2 shafts and possibly driveshafts you can select from a Huge array of trannies including the 85+ 4wd 5spds. I would stick to the 99+ trannies though as it should not require any modification. |
10-13-2000, 05:24 PM | #9 |
Member#: 2501
Is there no way to actually change the gear on the diffs?
Similar Threads | ||||
Final Drive ratio & 6th gear ratio? | scuzzy | Transmission (AT/MT) & Driveline | 1 | 11-09-2013 10:54 AM |
what gear ratio is 2004 FXT? and what other 4Eat ratios are available? | WRXINTX | Transmission (AT/MT) & Driveline | 4 | 08-26-2008 02:44 PM |
Learning Gear Ratio and Final Drive Ratio | madwrxing | Transmission (AT/MT) & Driveline | 0 | 04-16-2006 10:02 PM |
97L gear ratios vs. RS ratios? (MT) | Murray | Transmission (AT/MT) & Driveline | 7 | 08-12-2003 11:26 AM |
Gear ratios and differential ratio for 95 legacy and 95 imprezza | ciper | Transmission (AT/MT) & Driveline | 0 | 06-14-2002 06:58 PM |
