Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 01-24-2000, 01:57 PM   #1
RS>Z
Guest
Member#:
Question 215's on stock rims
can i put 16" 215/50 size tyres on my stock rims? And will 215's rub if i lower the car at all?
thanks,
RS>Z
Old 01-24-2000, 02:03 PM   #2
IMPRZIV
Member#: 628
Cool
Hey RS,
I just mounted a set of BFGoodrich G-Force KDW's on my MY99. They are 215/50ZR 16 in size. Be warned, clearance is tight in the rear. I could not get my finger between the tire and the rear strut when we mounted them on the car. However, I have noticed no signs of rubbing at all.
I've only put about 500 miles on them so far, but check the rear inside sidewalls every day and have yet to see any signs that they are rubbing the strut. They also do not appear that they will rub the outer fender lip. My Suspension is stock for now, but I plan the addition of a Pro Drive kit when funds are available. Hope this is of some help to you...
~Scott
Rally Blue MY99 (IMPRZIV)
Owings Mills, Md.
IMPRZIV is offline
Old 01-24-2000, 02:15 PM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
And that's why I pause when someone says the stock wheel, 16x7 +55 is optimal. If you go with less positive offset you may have to roll the fenders, but at least you can do SOMETHING. Let's see you move the strut out of the way.
Glad to hear they fit, btw. I've seen 205/55-16 A032R's rub lightly on the stock struts.
ColinL is offline
Old 12-05-2000, 01:00 PM   #4
Travis R
Member#: 153
'07 Mazda CX-7, '91
BMW 535i & '06 Ninja 650R
Thumbs up
I have the BFG KDW 215/50-16 on stock wheels also. They are great. There is about 5mm of clearance between the tire and the spring perch on the strut. And the bonus is that the speedo should still be pretty accurate.
Take a look: http://216.242.153.40/MembersList/Us...bfg-2-edit.jpg
They are about $90 at The Tire Rack.
Travis R is offline
215's on stock 16" rim??? mrgenius Tire & Wheel 2 05-16-2004 12:55 PM
Dunlop SP 5000 225/50/16 on stock rims on lowered WRX? MY03WRX Tire & Wheel 3 03-23-2004 09:57 AM
Trade: RComps on Stock rims for your allseason on Stock Gonz Mid Atlantic Impreza Club -- MAIC 9 11-11-2003 05:25 PM
225 50's on stock rims with a lowered car Fred Zaplitny Brakes, Steering & Suspension 0 12-24-2000 05:20 PM
