Old 07-28-2020, 12:16 AM   #226
subaru_gc8
Member#: 29292
2004 WRX wagon
Originally Posted by Waddlz View Post
You are not. The pressure drop is normal.
The DAVCs will drop pressure like that, and is why Subaru started using the 11mm in the cars with DAVCs
My 2012 will do exactly the same thing as killer-b is showing, but my buddies GD with SAVCs does not.
Oh okay thanks for the explination
Old 10-02-2020, 10:51 AM   #227
pcampbell
Member#: 437670
2005 2.5 SC OB
Any thoughts as to what sort of oil pressure do I want to see up to say 7300 rpm on an 2005 EJ253 (non-AVLS)? I am trying to figure out if it needs a 9mm or if 7mm is fine. Currently my stock 7mm with T6 gives me about 65psi-70psi at high rpms, I haven't hit 7000 yet.
I know what you are thinking... it won't make any power at 7300rpm. Cams and centrifugal supercharger on there so I do not expect power to drop off.
pcampbell is offline   Reply With Quote
Old 10-02-2020, 09:35 PM   #228
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I'd want to see ~85psi or better at that RPM. If the pump is sized right, the pressure will scale up with RPM. If the pump is too big, pressure drop may occur.
Old 10-02-2020, 09:36 PM   #229
murrdogg24
Member#: 50586
64 Impala
funny this thread showed up in new posts, as I just discovered today I have a leak on my oil pump on my EJ205...
murrdogg24 is offline   Reply With Quote
Old 10-10-2020, 05:17 PM   #230
pcampbell
Member#: 437670
2005 2.5 SC OB
Default Why you don't need GR (11mm) Oil Pump in GD (10mm) Engine
Thanks, it is a stock 7mm pump. If it does fine until higher rpms and then falls off should it be shimmed?
I want to say that I am seeing around 60psi at 6000rpm. I'm trying to rev to 7000 though. I'm not exactly sure if I should be looking at a 9mm pump, thicker oil (currently using 5w40 rotella t6) or shimming. Another option is a new 7mm pump, if perhaps the old stock one is worn and has lost some of it pumping ability. Perhaps the bearing clearances are higher due to age (208k miles).
there is no avls or avcs and also the supercharger is self contained oil so it’s pretty basic.
Old 10-26-2020, 08:55 AM   #231
pcampbell
Member#: 437670
2005 2.5 SC OB
One other question. I know the pump screws have a tendency to back out. Can they back out enough to affect pumping?
Old 10-26-2020, 09:48 AM   #232
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Absolutely. One, or worse two, loose screws can adversely effect pressure. Also will depend which screws (suction side, pump side, or between).
Old 10-26-2020, 11:39 PM   #233
brecks
Member#: 435142
2004 STi
Java Black Pearl
I’ve noticed an oil pressure drop in the higher rpms that lead me back to this thread. I’d read it before, but since you bumped it in April, I reread it... despite the pissing match in the middle, a lot of good info here. I see right around 85psi when the engine is warm once the relief valve opens (~3000rpm and beyond). The idle pressure hangs out around 24psi.
SAVCS 04 STi
Mains: 0.0017”
Rods: 0.002”
Oil: Motul Sport 5w40
Revving to 7200rpm
External oil cooler with 200° thermostatic sandwich plate, -10 lines, no OEM cooler.
DBB turbo with restrictor on feed
Stock 10mm oil pump, no added shims
Pressure measured at galley under alternator.
I understand my mains are rather loose compared to the numbers you like to use, but seeing as I couldn’t reliably get this block line bored in a timely manner, it is what it is there. However, I’ve been noticing that at WOT, I’ll get an oil pressure drop past 5000rpms, typically from ~85psi to ~75psi. I’ve verified that my electronic gauge is reading correctly with a mechanical gauge, made sure the oil cooler setup isn’t restricting (shouldn’t be, as -10 is about the be same ID as the block passages). KillerB pickup and baffle, so no cracked pickup. I checked the pump prior to installing for any burrs as well as loose screws on the backing plate. 5000-5100rpm happens to be the range where my AVCS goes to 0, which I believe would allow for more oil flow, potentially dropping pressure? I’m somewhat stumped here, and given the info you’ve posted, this could even indicate the pump is oversized, no? It’s been mentioned that using an 11mm pump on SAVCS is too much pump and leads to aerating/pressure drop. But in certain circumstances, could even the 10mm be too large for a single AVCS engine? The pressure drop doesn’t really concern me, except for on the track where that 75psi can get closer to 65psi
brecks is offline   Reply With Quote
Old 10-27-2020, 09:29 PM   #234
Scargod
Member#: 260314
2007 STI
silver gray metallic
Brecks,
What is your normal max RPM? Do you have any data logging capability?
It could easily be several things happening simultaneously. Your small, stock pump could be pooping out due to loose bearing clearances or it could be cavitating at higher RPM's. The centrifugal forces due to the high crankshaft rotation speeds (plus loose clearances) could also affect the oil system needs.
Scargod is offline   Reply With Quote
Old 10-28-2020, 07:13 AM   #235
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Can you e-mail me a log?
-10 lines are the smallest we recommend and should be fine for your RPM. Who's kit? Some have garbage fittings and/or sandwich adapters that can have funky issues with turbulence or pressure drop at certain RPMs.
DBB turbo? What's that? BB or journal? What size restrictor?
Were the pump clearances checked?
Very rare to have bypass issues on the 10mm; it's well matched to that engine. I've seen the 10mm pump work flawlessly to 10,000 RPM on these engines so I don't think it's an issue of RPM.
Old 10-28-2020, 02:24 PM   #236
brecks
Member#: 435142
2004 STi
Java Black Pearl
Originally Posted by Scargod View Post
Brecks,
By normal max rpm, do you mean normal shift rpm? It’s right at 7000, 7200 as redline is just a cushion for certain situations where it’s best to run the rpm out some vs upshifting. I don’t have the data logging function of the oil pressure gauge wired up, however I could change that quite easily. Clearly if it’s cavitating up top, adding a shim would do no good. Possible that my looser clearance are causing the oiling needs to be greater than the pump can provide? I know KillerB has stated that increasing the clearances with a built motor doesn’t typically justify the need for a bigger pump.
Old 10-28-2020, 02:50 PM   #237
brecks
Member#: 435142
2004 STi
Java Black Pearl
Once I hook up the AEM gauge to an input on the ECU, I certainly can. It’s very consistent at 5000rpm.
The cooler was pieces together, consisting of Russell fittings and hose (straight off the sandwich plate, 90 into the cooler, 120 out, straight back into the sandwich plate) a Mocal thermostatic sandwich plate, and a 16 row 1-series Setrab core. I suppose I could always disconnect the sandwich plate and bypass the whole cooler circuit to see if the issue persists.
DBB (dual ball bearing) EFR 7163. The restrictor on the turbo is a 1.5mm
I did not check the clearances for the rotor/backing plate, only checked that the screws were properly fastened and that the relief valve functioned as it should. The pump was brand new, so I didn’t even think to check that.
By saying it’s not an issue of rpm, is this to say that at my rpm the pump shouldn’t be outflowed by the oil demands? It’s my understanding that adding a shim to the pump wouldn’t help the issue much, and is more of a bandaid. To me it seems like there’s a flow restriction somewhere.. seems like disconnecting the oil cooler cuircut might be a good place to start
Old 10-28-2020, 08:59 PM   #238
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
brecks, I think you're going in the right direction by removing the cooler/adapter from the circuit. Process of elimination.
Going from OEM journal to a BB turbo typically reduced oiling demand, which is what you've done here. Along with increasing the mains it's typically a wash... or not enough to make an appreciable difference.
It's almost as if you have an AVCS bleed.
By 'not an issue of RPM' I mean that the 10mm has no issue with RPM. You should be able to rev far above your target without any pressure drop. It should continue to climb.
Old 10-31-2020, 04:18 PM   #239
brecks
Member#: 435142
2004 STi
Java Black Pearl
I ended up getting some logs of the condition, and it appears quite related to AVCS to me. I didn't disconnect the oil cooler circuit yet, though that's next on the troubleshooting list.
In the logs, you can see that the pressure drop coincides with when AVCS goes to 0... the pressure drops and stays there until the AVCS comes back up. I think your AVCS bleed theory is looking spot on
If you'll PM me an email, I'd be more than happy to send over the logs
Edit: For those interested, I changed the RPM for which AVCS goes to zero and the pressure drop followed, so it's definitely related to AVCS. I'd say it's safe to say it's not oil pump related.
KillerB pointed out that as the car loads (2500rpm, WOT) my left side AVCS was lagging behind the right side by ~5-10deg. By about 2900rpm, they were both reading where they should, and continued to read within 1-2deg for the rest of the pull. What's strange, is that on partial throttle and cruise, they both read the same- no lagging. I removed, cleaned, and swapped OCVs between left and right, but observed the same pressure drop/left side lag. I may try swapping cam sensors, but I have a feeling that it's not an electrical issue, because cam sensors don't cause oil pressure drops
Log view of condition:
https://imgur.com/a/COPTGcT
Old 08-02-2021, 04:27 PM   #240
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ did you ever get this sorted out?
Old 08-09-2021, 02:37 PM   #241
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
So read the whole thread and lots more, plus watched all videos I could find about EJ oil pumps and its funny how even the top builders are still split between the three.
I'm in the process of building a de-stroker for track use and after talking to some of the top subaru eng builders, that have a great track record, and some very knowledgeable people that are well known on here, and I was given all three suggestion. Reading and and talking to knowledgeable people it came to that a 10mm is the way to go. Then after requesting eng build quotes, one shops told me to use a 11mm shimmed and ported, another said 10mm or 11mm would work for my needs and two other builders said to use a JDM 12mm. I know of a guy in NJ who tracks his GD for podium placement and he also uses a 12mm. Its going to be a 05 STi 2.3 de-stroker with D25 SAVCS closed deck at around 500whp with a GT3582 going to be used on a street course, not drag.
I'm still leaning towered the 10mm or maybe a 11mm ported and shimmed but its funny how after all these years, there is still no 100% answer. The only reason why the shops are suggesting different pumps might be due to each one picking different kind of bearing clearance. Any thought behind this?
Old 08-09-2021, 08:47 PM   #242
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Within the next few weeks we have scheduled to run all 3 pumps on the same engine. One of the parameters we'll be measuring is the actual oil flow into the engine, which no one has ever done or documented before. Maybe we will put some of this debate to rest.
Old 08-09-2021, 11:05 PM   #243
BlueSTI4Me
Member#: 34361
04.7 STI
WRB IG @got2boostit2
Taps foot. How long has this been discussed? LoL
BlueSTI4Me is offline   Reply With Quote
Old 08-10-2021, 08:34 AM   #244
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Too long!!
It has been a crazy year. All of our resources have been put into production for nearly the last year straight. Extracurricular activities have taken a backseat
Old 08-30-2021, 03:50 PM   #245
sebastian323
Member#: 510671
2006 WRX
Gray
Originally Posted by vicious_fishes View Post
fwiw i ran the stock 8mm pump when i boosted my N/A EJ251. would only lose oil pressure once the oil got really, really hot. installed an oil cooler and problem solved.
no idea how different the demands are on the N/A donks with SOHC heads though.
did you try running a thicker oil before adding the oil cooler ?
sebastian323 is offline   Reply With Quote
Old 08-31-2021, 09:15 AM   #246
BlackFighter
Member#: 193940
2004 WRX STI Black
Hey, have you guys done any testing yet on the 3 different pumps?
Old 08-31-2021, 08:08 PM   #247
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The dyno rig is almost complete
Old 10-19-2021, 11:28 AM   #248
BlackFighter
Member#: 193940
2004 WRX STI Black
Is the dyno rig complete yet
Old 10-19-2021, 01:11 PM   #249
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It is, but we're waiting on some software upgrades from Mustang so we are kind of stuck right now. We should have this sorted out in the coming few weeks.
Old 11-30-2021, 07:53 AM   #250
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Neat stuff...
Solid = 10mm
Dashed = 11mm
Wide Dashed = 12mm
All pumps were untouched OEM, except for initial disassembly and inspection for smooth action. We are going to be doing a follow-up, with shims, and some other stuff
Also, if you look at the comments at the top you can see run each run; 1, 2, and 3. They correspond with the data at the bottom of the page.
