Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 11-29-2006, 04:19 PM   #1
leep133
Member#: 93245
Default Torque bind questions
Please before you start flaming, I did search, and I could not find what I was looking for.
I have a 97 LGT, AT with about 110k miles on it. I bought the car used around 82k miles. I noticed the torque bind when I first bought the car, but it wasn't too bad. After about 5-10K miles I changed the diff fluid, and the torque bind was reduced. Well now at 110k miles the torque bind is back and with a vengeance. I want to get it repaired permanently. I'm looking to see what a good price is (searching I've found anywhere between $400-$2000) Also are there any recommendations for a good place to get it done in northern California (bay area) Thanks
leep133 is offline   Reply With Quote
Old 08-15-2020, 08:48 AM   #2
feliz
Member#: 517506
97 impreza brighto
Default new guy old problem
torque bind. 97 impreza 2.2 4EAT. fwd fuse makes it go away. pull fuse and awd works for pulling seadoos back up the boat ramp. so, the solenoid releases fluid pressure to the rear drive clutch. if fwd fuse works, that implies sol works and pressure releases. so, is it that the pressure doesn't release fast enough for the 30 hz cycle rate to release clutches? but releases well enough for always open? and that why trans fluid change sometimes helps? planning on doing MT and turbo to this beastie eventually so don't wanna sink too much time-money into this auto trans. gonna be the kid's first car. he wants a 22B. we don't have 100k to spend so i figured the wannabe-clone route...
feliz is offline   Reply With Quote
Cost to fix the torque bind problem on a 98 GT MaddMax Legacy Forum 18 04-08-2011 02:22 AM
Torque Bind Subbie95 Mid Atlantic Impreza Club -- MAIC 9 04-05-2005 01:07 AM
1999 outback 5mt torque binding question cboggess Transmission (AT/MT) & Driveline 2 07-15-2004 04:36 PM
Torque bind ciper Transmission (AT/MT) & Driveline 3 06-26-2002 06:55 PM
Is this torque bind? BJamerican Transmission (AT/MT) & Driveline 4 05-02-2002 01:03 AM
