09-25-2020, 08:27 PM | #1 |
Member#: 493909
Built FA20DIT (2017 WRX)
Hey guys! I was running stock block stock turbo, Full Bolt on, running e60 blended at the pump and was making JUST over 400hp and 390TQ. Well on a high speed pull I met Rod through the top of my block at about 130mph. Now I have built my new engine.
Closed deck Manly platinum pistons BC I beam rods APR rod bolts and head studs. GSC Beehive valve springs GSC titanium retainers GSC race valves GSC valve stem seals. IAG comp AOS FMIC Full IBR TGV Deletes EGR delete ETS 5558 gen 2 full kit Cobb ethanol sensor kit Grimspeed EBCS boomba BOV Nostrum HPFP Dw300 AEM Meth injection with VP m5, w/ 500cc nozzle spraying 100% meth no water*starting spray at 7PSI and spraying full at 15 PSI Let me know what you think what kind of power this car is gunna make! I'm just starting the break in. Mikey Botti is my Tuner! He also did the first 400hp stock tune! Let me know if you think my 600HP goal is realistic!
09-25-2020, 10:59 PM | #2 |
Member#: 57064
Vehicle:2008 STi IAG built HTA86 E85 Kel272s Cos IM |
Throw in a BRZ IM
09-26-2020, 02:38 PM | #3 |
Member#: 508775
Vehicle:2020 WRX CWP |
Just curious - were you running Mikey's "Send It" tune on the stock motor? How long were you running for at that power level?
09-26-2020, 05:38 PM | #4 |
Member#: 493909
It was not his "Sent it" tune. It was close. But we were not maxing the car. And the motor lasted a month shy of 2 years and 30,000 hard hard miles.
09-29-2020, 02:27 AM | #5 | |
Member#: 456257
Vehicle:2016 WRX Limited World Rally Blue |
also, what oil you running? |
09-29-2020, 03:33 PM | #6 | |
Member#: 493909
First startup I ran a lucas oil high zinc break-in oil for about 10-15 minutes, then switched to Motul 5-40 which is what I run forever. |
