10-04-2010, 09:13 PM | #351 |
Member#: 134530
Vehicle:2006 Wrx Wrb |
I adjusted the right hood stopper on my car because the right side of the hood was wobbling pretty bad, the next day my LEFT low beam was out.
I doubt my high's have even half the usage that the low beams have but, I was thinking about replacing all of them anyway. The 9011's definitely seem like the crowd favorite for high beam.... To the other 06/07 owners out there, which H7 bulbs should I purchase to get better results over the stock bulbs??
10-12-2010, 04:52 AM | #352 |
Member#: 260596
An excellent work.
10-22-2010, 11:25 PM | #353 |
Member#: 152707
NESIC
Before I order lights for my 2000 Impreza RS I want to be sure I'm getting the right ones. It looks like the H4/9003 Narva RangePower+50's are one of the better (best/brightest?) bulbs for my headlights. I just want to make sure, are the 55/60w bulbs are the right ones for my car?
Thanks for any help! |
10-23-2010, 01:13 AM | #354 | |
Member#: 230795
Vehicle:2011 Impreza WRX 5dr WR Blue Pearl |
10-23-2010, 12:20 PM | #355 |
Member#: 126446
Vehicle:2006 WRX Ltd Wagon San Remo Red |
sorry if this has already been mentioned......but just wanted to clarify. for an '04 wrx I'd be using the for h1 Osram Silverstar, part # 64150SVS for low beams?
10-24-2010, 10:57 PM | #356 | |
Member#: 152707
NESIC
I just want to make sure the 55/60w bulb is the right one for my car though, is it? |
10-29-2010, 01:18 PM | #357 |
Member#: 174357
Vehicle:2002 OBS |
duplicate >> http://forums.nasioc.com/forums/show....php?t=2079421
(Question about LED turn signal bulbs) Last edited by DC16A2; 10-29-2010 at 02:23 PM. Reason: remove duplicate |
10-29-2010, 03:57 PM | #358 |
Member#: 230795
Sorry for the delay in posting back. I'm not sure which bulb your car uses, but the on-line lamp guides (google "automotive lamp replacement guide") and ones in parts houses will tell you correctly.
11-03-2010, 02:16 PM | #359 |
Member#: 142322
TXIC
Vehicle:2002 wrx wrb |
Where to get these bulbs that are Quality and have this look such as these pointed out here?
11-03-2010, 02:57 PM | #360 |
Member#: 204304
Vehicle:2008 WRX 4D Stage 2 Silver |
With is getting dark sooner and sooner I driving more I need to get some new bulbs bad for my 08.
Are the H9 showing up more in the stores? Last I looked trying to find the H11 was hard. Trying to find a H9 was horrable. Napa could not even order them. I know I have to mod the H9 a little to work in the H11 socket. That little tab and a dremel should fix the issue very fast. |
11-03-2010, 09:14 PM | #361 | |
Member#: 230795
11-03-2010, 09:14 PM | #362 | |
Member#: 147065
11-03-2010, 09:19 PM | #363 |
Member#: 204304
11-04-2010, 02:17 AM | #364 |
Member#: 230795
Double post -- sorry. Next one is correct.
11-04-2010, 02:20 AM | #365 |
Member#: 230795
Finally was able to post a picture of the beams and cutoff from my HID install (approx 25 feet away from garage door). Glare in windshield and speckles are from car approaching from left as I shot this photo.
http://i1135.photobucket.com/albums/m621/bassman12350/IMG_0165.jpg |
11-04-2010, 02:34 AM | #366 |
Member#: 230795
11-04-2010, 05:12 PM | #367 | |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
11-06-2010, 11:55 AM | #368 | |
Member#: 204304
I want to do a before and after shot with the H11 to the H9. Show the temp differance on the wire and socket. I know some people are worried about the wires and socket getting over heated. I would rather show the temps off a probe instead of just saying how it feels. Anything else I should check on this mod or does anyone else have any questions about the mod? I will test it out as I do it. |
11-06-2010, 01:59 PM | #369 |
Member#: 236305
My headlight housing covers on the inside felt really hot after the mod.. but they might have before too, I dunno. It is cold weather here now so I am not worried in the least. I am conscious of it though and on hot days next summer I won't ever idle with low beams on for no reason. On cold or rainy/snowy days I don't think twice about it. It has been fine for the past couple months for me and I love the extra light from the low beams. That's all I can say though, no melted wire harness or headlight housing yet. I doubt I will ever have a problem, but you never know. I would just keep an eye on it and don't do anything foolish. Basically don't push your luck with "testing" and don't leave low beams on while not moving any longer than needed. Just common sense stuff really.
11-07-2010, 12:59 PM | #370 | |
Member#: 230795
11-07-2010, 05:57 PM | #371 |
Member#: 204304
Waiting for it to get a little darker to install the H9 so I can show how differet the light is. My housing and wire started off at 69F. After just having the lights on for 10min with the stock bulbs the housing heated up to 132F and the wires heated up to 77F. I got both of the H9 filed down. It took me less then 10min each.
11-07-2010, 07:58 PM | #372 |
Member#: 204304
Link to the DIY with temps.
http://forums.nasioc.com/forums/show...0#post32392880 I hope this helps anyone thinking of doing this. |
11-07-2010, 08:28 PM | #373 | |
Member#: 21038
South East
Vehicle:05 STi CGM 08 WRX 5D SSM |
11-15-2010, 08:07 PM | #374 |
Member#: 199746
TXIC
Vehicle:2010 WRX 5-Door |
an HID kit would be bad in a headlight housing with reflectors.
now if one has projectors their car, wouldn't a plug and play HID kit work with proper beam cut off? or would one have to keep using halogen bulbs in their projectors? |
12-08-2010, 09:23 PM | #375 |
Member#: 100263
Vehicle:2003 WRX Wagon PSM |
I recently picked up Osram Night Breaker +90 bulbs in H4 for my girls car and H3 for my factory fog lights. I was skeptical at first when I saw the slight blue tint on the glass of the bulbs.
The difference in light between these bulbs and stock bulbs were amazing! I have no pictures for proof, but I am very happy with how bright these are and so is the lady. I also replaced my stock bugeye headlight bulbs with the Philips +80 bulbs. Also a great improvement in light output. The actual color of the bulb is very similar if not the exact same as the stock bulb color. At first I thought I would like this, but after seeing the difference in light output with the combination on the whiter bulb, I really wish the Osram +90 bulbs made a bulb that would fit my headlight. Still very happy with both brands. In the past, I have ran plug n' play hid systems, sylvania silverstars, narva yellow and several colored PIAA bulbs. The +90's are by far the best bulbs I have ever spent money on and I will continue to run them in the future. The +80's came in a close second. |
The 'Everything You Ever Wanted to Know About Smog' Thread | WagonMonster | Southern California Impreza Club Forum -- SCIC | 667 | 06-27-2016 02:18 AM |
Everything you ever wanted to know about anything ever made......ever | Hester Prynne | Off-Topic | 12 | 11-05-2008 05:57 PM |
All you've ever wanted to know about farting | TheRex | Off-Topic | 5 | 02-01-2005 03:48 PM |
Everything you ever wanted to know about WRX exhauasts (old model) --> | rao | Normally Aspirated Powertrain | 5 | 02-12-2001 08:56 PM |
