Old 04-04-2021, 03:31 PM   #1
robg0656
Member#: 522254
2020 WRX Base
WR Blue
Default 2020 WRX OLM LED Turn Signal Bezel Hyperblink
Recently installed the Subispeed LED DRL Headlights for base WRX and the OLM LED turn signal bezel. Everything with the headlights, DRLs, and hazards are working correctly.
After installing the hyperblink module, I lose my right turn signal completely and still have hyperblink on the left signal.
I followed all the instructions from Subispeed, clipped the tine off of add a fuse, and have verified its plugged into the right spot on the fuse box.
Has anyone experienced this before? Is it possible I received a bad hyperblink module?
robg0656 is offline   Reply With Quote
Old 04-04-2021, 08:54 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
To verify the wiring to the right side lights is okay I would first check the resistance to the lights at the module and compare the left and right side readings. If they are close to the same readings then I would think that part of the wiring is good.
Cougar4 is offline   Reply With Quote
