06-03-2015, 08:38 AM | #951 |
Member#: 422740
06-17-2015, 02:00 AM | #952 |
Member#: 129395
SWIC
Vehicle:2006 OBPWRX VF39 E85 333WHP 385WTQ 21PSI SD |
Ok so I put a 2006 sti cluster into my 2006 wrx that has an outside air temp display but no climate control. Everything works the way I want excep the OAT. It just reads --- or 43degrees F. I am at a loss on getting this to work. Do I have to buy that kit from that guy selling OAT wiring or is the a pin I can switch around?
06-17-2015, 07:09 AM | #953 | |
Member#: 27874
NESIC
Vehicle:2002 WRX V7 EJ207 DOM1.5 6MT 360 whp |
So, your setup is a little different then the normal setup I built harnesses for, but I have done them to work with your setup before. Your car should already have the sensor and wiring to the sensor, but now with the sti cluster you need the power supply, that in an sti is built into the auto HVAC, your stock cluster had the power supply built in to it. |
08-04-2015, 07:29 PM | #954 |
Member#: 427343
Where do i get a new cluster?
i have an american 2006 sit and i need a canadian cluster id love a mother 06 cluster to make life easier. does anyone know where i can get one? or have one i can buy?
10-25-2015, 12:10 AM | #955 |
Member#: 418090
Vehicle:2004 wrx wagon red |
I'm looking to be putting an 07 usdm sti cluster in my 04 wrx. I searched endlessly and could only find one person who has done this but they did it with a 07 jdm sti cluster. would the re-pinning/snipping of wires be the same as doing an 06 usdm sti to 04 wrx swap? thanks in advance
10-25-2015, 12:18 PM | #956 |
Member#: 418090
12-12-2015, 05:42 PM | #957 |
Member#: 436019
RMIC
Vehicle:2018 STi RA #406-500 Peral White |
STi gauge cluster swap
I have a 1997 2.5rs with a EJ207 V7 STi swap in it with no DCCD and I'm wanting to install a STi gauge cluster. Short of rewiring everything is there any way to install a JDM Prodrive V8 blue cluster or will any of the STI clusters fit for that matter?
12-14-2015, 01:58 PM | #958 |
Member#: 363509
South East
Vehicle:2013 STI Ice Silver |
After spending the entire evening reading through this and trying to figure out my specific question I am at a loss. Can you swap a JDM for a USDM? I have km/h and need mph. I know the mileage stays with the cluster which isn't a problem, this baby isn't leaving my possession.
12-14-2015, 04:45 PM | #959 | |
Member#: 27874
NESIC
You would want to compare the pin outs of your car and a 02-03 USDM WRX. You mite want to buy a spare cluster harness for a 2.5rs and re-pin the spare one. Its not to bad. I know I could do it easily. Their are v8 non dccd prodrive clusters. I would go with that so you don't have non functioning dccd indicators. |
12-14-2015, 04:50 PM | #960 | |
Member#: 27874
NESIC
you its a newer car like your profile lists I would think it would be drop in, but the dealer will have to reprogram your immobile to get the car to start. |
12-15-2015, 07:39 PM | #961 | |
Member#: 436019
RMIC
i will be doing this mod shortly then. i know i can repin the harness that should be cake. thanks for the info! |
12-16-2015, 07:04 AM | #962 |
Member#: 27874
NESIC
12-17-2015, 08:01 AM | #963 |
Member#: 241819
Vehicle:1993 EG33 GC8 |
i have few clusters for sale guys V7 STI prodrive non-dccd (blue faced) and V7 STI clusters (black faces with yellow needles) mileage can be adjusted , 04 STI CLUSTERS with around 50k miles on it pictures available on email
http://forums.nasioc.com/forums/show....php?t=2418920 |
12-21-2015, 04:12 PM | #964 |
Member#: 435576
Vehicle:2005 Wrx Wagon Crystal Grey Metallic |
Are the v7 clusters plug n play with an 05 Wrx?
12-21-2015, 07:18 PM | #965 |
Member#: 27874
NESIC
The V7 and V8 prodrive sti and also the 04 USDM STi should work, not 100%sure on the JDM ones.
V7 jdm was 2001-2002 I think so I would think that cluster would work in your 05. the 05-07 usdm sti's had a reversed ABS circuit. |
01-13-2016, 08:23 PM | #966 |
Member#: 310786
Ok just did a ton of reading and didn't find an answer so if the question has been answer please direct me to where. I have an 04 STI cluster in my 02 WRX with everything working properly, however going 70mph the cluster reads 74mph, i use my AP to check my actual speed but not being able to watch the cluster is starting to drive me nuts. I called Tacoma Speedo and they said they do not have a fix for this but said possibly a Dakota speed healer could do the trick. Anyone ever used a speedo healer in a subaru and can confirm it works, or possibly another solution?
01-29-2016, 04:20 PM | #967 |
Member#: 435576
Put a v7 cluster in my 05, everything works except the abs light is stuck on and the cruise light is missing. I did read that I need to switch a pin for the cruise, but didn't see a fix for the abs light. Also, is it true that you can not swap needles? I wanted to swap my stock red needles to this cluster. Thank you.
01-30-2016, 05:12 PM | #968 |
Member#: 435576
Bump...plus, the speedometer and tachometer seem dimmer than the rest of the cluster, even after installing new LEDs. Any idea on how to get the lighting even?
01-30-2016, 05:29 PM | #969 | |
Member#: 27874
NESIC
Swaping the needs maybe physically possible but geting them back on in the right spot would be near impossible. |
01-30-2016, 07:30 PM | #970 |
Member#: 388185
International
Vehicle:2002 Impreza WRX Sonic blue |
Hello, I have 2002 WRX with full STI swap (DCCD gearbox, engine, brembo.. ) I got a 2007 Spec C Type RA Cluster (260km/h) and fit into my car..everythink works perfect but cluster didnt make full sweep. I try cluster in STI 2007 and works fine.. Any one know what could be the problem?
01-30-2016, 07:40 PM | #971 | |
Member#: 435576
02-08-2016, 07:14 PM | #972 |
Member#: 280946
Hey guys,
What is the easiest Sti cluster to put in a 04 forester? I really like the 05+ gauges as they just look clean with the bright red and sweep. |
02-25-2016, 07:30 AM | #973 | |
Member#: 27874
NESIC
Use a standard automotive relay. Cut the abs wire a couple inches back from the cluster. Crimp on female spade connectors to both sides. Relay pin 85 to ground, Relay pin 86 to the car side of the cut abs wire. Relay pin 30 to +12 volts Relay pin 87a to the cut abs wire going to the cluster. Next time I get a 05-07 USDM sti cluster in for mileage adjustment I mite give it a try if I have time. Last edited by AFBeefcake; 02-25-2016 at 10:50 AM. |
02-25-2016, 10:32 AM | #974 | |
Member#: 435576
02-25-2016, 10:55 AM | #975 | |
Member#: 27874
NESIC
I haven't really looked into this, but most logic inverters are only 5 volts. |
can we get some mods to start deleting duplicate threads? | [27] | Political Playground - Chaotic Neutral Edition | 2 | 11-05-2008 02:01 AM |
STi hare emblem? where can i get one... | evoeater8 | Interior & Exterior Modification | 13 | 07-12-2006 08:53 PM |
can we get something started in RDU???(nc) | imprezivSTi04 | Mid Atlantic Impreza Club -- MAIC | 3 | 04-04-2006 06:47 PM |
02 sti hood scoop?? where can i get one? | slaterdrew | Private 'Wanted' Classifieds | 2 | 02-06-2004 11:37 AM |
lighted keyhole ring, can we get one? | makanouchi | Interior & Exterior Modification | 12 | 11-22-2002 08:38 PM |
