04-27-2021, 08:18 PM | #1 |
Member#: 414428
Figuring Out a Swapped Engine
Going to look at a complete engine tomorrow - already pulled from the car.
Problem is it is advertised as a turbo’d 2.5 from a 2002 Impreza ..... If it is really a 2.0 that is easy to see on the engine case by the alternator. What I really want to know - is how to tell if it was a full 255 or 257 swapped in? Or maybe a hybrid made with a 253 and the original 2.0 heads? 99% sure the seller won’t let me pull a head and see if it is an open deck or a semi-closed deck block. First experience with Subaru. Son bought an 04 Forester with a replaced engine (supposed to be the “right” 255) with the “STi mods” and an open source stage 2 tune. Someone decided not to listen to reason and wait until we had a Tactrix cable in hand and a WBO2 installed and we could look at the tune and datalog some easy runs .... pretty sure it took out the ring lands on three cylinders.
04-30-2021, 07:28 PM | #2 |
Member#: 414428
This one is OBE now - guy also had the "correct" EJ255 from an 05 Forester XT.
Now just to figure out if it goes in stock as it sits or if it gets pistons, bearings, valve job, and new gaskets/seals first.... |
04-30-2021, 09:26 PM | #3 |
Member#: 459287
VIC
Vehicle:1998 JDM Impreza STi V4 GF8 White |
05-01-2021, 09:05 PM | #4 |
Member#: 487
TXIC
Vehicle:1998 /2005 STunIcorn Acadia Green USDM 22b |
Im sure that Built Motor forum section will be able to give you definitive answers
Im thinking that microfiche pix of heads might show you what your are looking for too |
05-01-2021, 09:25 PM | #5 |
Add Lightness
Moderator Member#: 13699
Vehicle:2021 Building It Better |
05-03-2021, 09:21 PM | #6 |
Member#: 487
TXIC
05-11-2021, 12:00 AM | #7 |
Member#: 414428
