03-28-2019, 09:52 PM | #1051 |
Member#: 492832
Hey guys. Been doing a swap on my 99 2.5RS with a 2005 STI cluster (GC8 to STI cluster swap). Here's what I've been using:
and here's the pinouts I've come up with: Code:
Function 1999 RS Pin 2005-07 Sti pin N/A A1 Coolant Signal A2 A11 Fuel Gauge A3 A3 ??? A4 ??? A5 ABS Light A6 B3 (Reverse Circuit) Low Fuel Warning A7 n/a ??? A8 ??? A9 Coolant Temp Ground A10 A10 EBD (Ground this wire) n/a A2 N/A B1 N/A B2 N/A B3 N/A B4 Door Warning Light B5 B13 Door Warning Light B6 B14 Seat Belt Warning LightB7 B9 Illumination +12V B8 B24 N/A B9 N/A B10 N/A B11 N/A B12 Turn Signal LH B13 A9 Airbag Light B14 B18 Turn Signal RH B15 C3 ??? B16 Headlights +12V C1 B30 Hi-Beam Light C2 B29 Illumination Ground C3 C6 Illumination +12V C4 C8 N/A C5 Park brake/fluid light C6 B19 Ignition +12V C7 C7 Constant +12V C8 C10 Tach RPM/ECM C9 C5 VSS C10 C2 N/A C11 N/A C12 Turn Signal Ground C13 B4 Oil Press Warning Light C14 B2 N/A C15 N/A C16 Charge Warning Light C17 B1 CEL C18 A6 E-Brake light fix: A2 on the STI cluster must be grounded. This is input from the EBD. Without it, the brake light stays on. With it, the light comes on when the brake is pulled. P.S. check the spring/switch on the handbrake. Mine wasnt going into position all the way and was driving me nuts (false positives/negatives). ABS: this is a reversed circuit on the STI cluster compared to the gc8 one. When the GC8 abs circuit is grounded, the light comes on. On the STI cluster, when ABS input sees +12V, the light comes on. Simple relay reverse circuit was used to fix it. AS outlined a few times in the thread. Hope this helps a few people.
05-31-2019, 11:22 AM | #1052 |
Member#: 98838
SCIC
Vehicle:2005 STi CGM |
Im looking for a direct bolt in a usdm STI gauge cluster for my 05 STI. I heard you can use a usdm 04 and 05 cluster but the 06 and 07 cluster is slightly different, can anyone verify this?
05-31-2019, 11:36 AM | #1053 |
Member#: 27874
Vehicle:2002 WRX V7 EJ207 DOM1.5 6MT 360 whp |
05-07 should work. They have the 16 pin left connector. The 04 is 14 pin and the abs function is reversed. I don't have the 05 diagram, but 06-07 do have a wire in A2 that might have to be grounded when in your 05.
06-06-2019, 09:05 PM | #1054 |
Member#: 502942
2017
anybody know anything about swaping the 2018 cluster into a 2017?
I really like the look of the white and red together |
08-11-2019, 11:05 PM | #1055 |
Member#: 503860
Vehicle:2005 Impreza RS Red |
Impreza RS to STI S202 cluster Swap
Hello, I have a 05 RS and recently bought a 02-03 STI S202 cluster and would like to know if there is anybody that has done the same thing (Impreza to STI cluster) that could make this any easier for me?? Any information about the plug and play or just rewiring it. Like is it just plug and play? My RS is manual.
04-06-2021, 09:07 AM | #1056 |
Member#: 395793
Vehicle:2005 92x Aero Beige |
Figure I'd ask here instead of starting a new thread. Have an 06 USDM STi cluster and am wondering if there's a hack to get the shift light to go higher than 7000. I'd like to set it to 7600. If not, does anyone know which wire to delete so it stops working?
04-06-2021, 10:12 AM | #1057 |
Member#: 27874
You can reprogram the cluster and raise the max shift light to 8k like the jdm units. I ve done it on a couple clusters.
04-27-2021, 08:04 PM | #1058 |
Member#: 503160
Throughout the Forum I see a large number of posts about how to wire after market DCCD controllers in conjunction with a JDM STI instrument cluster and JDM ECU. I've done a number of searches and can't find any discussing installing a JDM DCCD controller and just plugging it into the ECU, which should by extension cause the full complement of DCCD related cluster lights to work as intended. What am I missing? I see a number of JDM DCCD controllers available for sale.
07-09-2021, 01:52 PM | #1059 |
Member#: 500924
Vehicle:2003 WRX Blue |
Hey everyone, I cant find seem to find anything definite that sounds like it will help. I just installed the 05 sti cluster in my 03 wrx(I followed the instructions on the main thread on how to do it). When I plug everything back in, the fuel level gauge is on empty, the low level light is flashing, and I am getting an CEL for P0462 saying the fuel level sensor circuit is low. When I put the old cluster in, it works just fine, no engine light and fuel level is reading around 3/4 tank. The temp gauge functions as it should and all of the needles do the sweep when I turn the key. Anyone have any idea what it could be?
Update: Got it figured out. Two of the pins in the connector on the cluster were pushed back and unable to reach the plug from the harness. Crisis averted. Last edited by alupo0; 07-12-2021 at 11:25 AM. |
07-31-2021, 03:21 PM | #1060 |
Member#: 237270
08-11-2023, 11:56 PM | #1061 |
Member#: 533413
Vehicle:2004 Impreza WRX Blue |
V7 UKDM Cluster in 04 Wrx Wagon
Let me start by saying, yes, I read all 43 pages of this faq. Everything works except for OAT which I don't care about. My ABS is on and so is my Airbag light(Assuming that will be normal since person before me did Sti seat swap in the front). Was wondering if I should do the relay fix noted on page 39 or 40. Or is it a re-pin/grounding fix? Should mention cluster in also not Prodrive and also non-dccd. Even a pin out schematic would work.
09-18-2023, 10:56 PM | #1062 | |
Member#: 28990
South East
Similar Threads | ||||
can we get some mods to start deleting duplicate threads? | [27] | Political Playground - Chaotic Neutral Edition | 2 | 11-05-2008 02:01 AM |
STi hare emblem? where can i get one... | evoeater8 | Interior & Exterior Modification | 13 | 07-12-2006 08:53 PM |
can we get something started in RDU???(nc) | imprezivSTi04 | Mid Atlantic Impreza Club -- MAIC | 3 | 04-04-2006 06:47 PM |
02 sti hood scoop?? where can i get one? | slaterdrew | Private 'Wanted' Classifieds | 2 | 02-06-2004 11:37 AM |
lighted keyhole ring, can we get one? | makanouchi | Interior & Exterior Modification | 12 | 11-22-2002 08:38 PM |
