Old 02-28-2021, 01:54 AM   #1
opualuan
Member#: 265940
Default Suspension noises ‘11 wrx hatch
Just had my struts (OEM) professionally replaced on all four corners of my 2011 wrx hatch, and new whiteline/kartboy sways/endlinks put in. I have a creaky old bedspring sound on passenger side front now at low speeds, when parked if I stand on the sill and bounce it will creak badly.
Does this indicate something to do with the spring, strut, or something about the install? Could the strut itself be blown out of the box?
opualuan is offline   Reply With Quote
Old 04-23-2021, 04:28 PM   #2
duder56
Member#: 522926
2008 Impreza OBS
Old thread but here you go:
Lubricate your sway bar bushings and links... 9/10 times creaks are from aftermarket bushings not having adequate lubrication or fitment. If that does not work, then look for loose parts... If no parts are loose (or you can't tell by yourself) have it diagnosed by a professional to see if anything is actually wrong.
My bet is sway bar bushings
duder56 is offline   Reply With Quote
