11-08-2007, 05:08 PM | #1 |
Member#: 92582
MWSOC
Vehicle:* |
Fuel Systems
I am trying to find somewhere that sells complete fuel system upgrades, preferably something bigger than a Walbro... Think Aeromotive stuff. I have checked with JEGS, and Summit, but I was hoping someone is already creating them for Subarus... Anyone know of who might sell these?
11-08-2007, 05:30 PM | #2 |
Member#: 92582
MWSOC
Vehicle:* |
Found this, but I wish I could find one not from Vivid... http://www.vividracing.com/catalog/p...ducts_id/32179
11-08-2007, 06:10 PM | #3 |
Citizen Mick
Member#: 27646
NWIC
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
Perrin sells that kit direct but I will say that the pump is very, very, very loud
What you looking to spend? I helped setup a fueling kit on a built STi recently and it turned out very well. Basically a single in-tank walbro fills a TurboXS fuel surge tank. Out of the tank are two huge fuel pumps (can't rememebr the part # off my head) Each pump has an external non return check valve and the outputs of these T togther to a single dash 8 steel braided running down the car. Return lines from the front of the car fills the surge tank, surge tank then overflows into the fuel tank. It turned out sweet but lets just say it was pricey mainly due to the non return valves, fittings and pumps. |
11-09-2007, 02:35 AM | #4 |
Member#: 30798
Vehicle:2001 RS-T Hybrid 2.5>2.2T>257>2.35S |
Get in touch with aeromotive. I have their prototype fuel rail kit for the wrx going onto my rs soon. It was built very well and I'm sure if you get in touch with them they can help you put the rest of the system together,pump,lines,filter etc.
11-09-2007, 10:13 AM | #5 |
Member#: 33782
MAIC
Vehicle:96 3MI Racing search FIRST, then PM!!! |
putting the whole system together isn't hard. You just have to think things through...welding a sump for an A1000/2000 to a gas tank is recommended but not needed...oh, they are also VERY loud...right now I'm finishing up my designs on my double and triple 255 intank.
11-10-2007, 06:43 PM | #6 |
Member#: 92582
MWSOC
Vehicle:* |
I wouldn't mind spending the $ if it is done right. I have a GT35R that I hope to get about 500whp out of, but I don't want to have to upgrade my fuel system again if I decided to go faster. I do love Aeromotive's parts, but I haven't seen too much outside of the big V8s. I suppose I can just get a second walbro and run one of these...
http://www.rallysportdirect.com/shop...3bb9a695430876 If anyone can explain how the above would be setup, I would appreciate that... |
11-10-2007, 07:48 PM | #7 |
Top Scoob 002
Member#: 32771
BAIC
Vehicle:03 Black WRX 04 White M3 |
It's pretty easy to set up a surge tank and it is well worth it if you have high hp and track your car or drive it hard on the street. Plenty of fuel for a 35R
Here's what my setup consists of Intank walbro 255 feeds a surge tank -8AN feeds a Bosch 044 external pump -8AN line to the front of the car splits into -6AN Axis Fuel Rails RC1000cc Injectors Aeromotive FPR feeds into stock return line that goes to the surge tank Last edited by dan avoN7; 11-10-2007 at 07:53 PM. |
11-11-2007, 06:21 PM | #8 |
Member#: 92582
MWSOC
Vehicle:* |
^^Thanks, but I can't see the pics! Want to though...
11-11-2007, 08:11 PM | #9 |
Member#: 95109
We just did a setup on my brothers bugeye. Its twin Walboros with 6 an lines merging in a Y into an 8 an line, 8 an line feeds the aeromotive rails(very nice) and then 8an back to the regulator, 6 an return line to the tank.
It works very well. Good Luck Matt |
11-11-2007, 10:59 PM | #10 | |
Member#: 33782
MAIC
fuel block return is 2 -6an to -8an return... monitoring rail system fuel pressure independently. |
11-11-2007, 08:14 PM | #11 |
Member#: 92582
MWSOC
Vehicle:* |
^^Thanks! Sound like a nice setup. Anyone have anything else?
11-12-2007, 04:41 AM | #12 |
Member#: 131371
TXIC
Vehicle:05 buy my parts so i can get my sti running |
i know buscher sells a twin fuel pump setup...check it out pretty good price also....
11-12-2007, 07:09 AM | #13 |
Member#: 109527
Vehicle:1997 GC8 8.38@165Mph blue |
quick question I run dual 044 bosh pumps right now , I had one fail and the engine went lean and blew one time. Does any one make a controller that will just shut down if one pump fails?
11-13-2007, 02:00 PM | #14 | |
Member#: 33782
MAIC
having a pump take a dump is a big worry... |
11-13-2007, 11:13 AM | #15 |
Member#: 92582
MWSOC
Vehicle:* |
^^Never heard of that, but I can see where that would be useful. Thanks bloopsta26, gonna go check now.
11-13-2007, 12:09 PM | #16 |
Member#: 92582
MWSOC
Vehicle:* |
Me want!!!
11-13-2007, 01:19 PM | #17 |
Member#: 42614
SCIC
Vehicle:0405 WRX STi/S2000 AspenWhite/Silverstone |
Me likes this one:
11-13-2007, 01:20 PM | #18 |
Member#: 42614
SCIC
dan avoN7 setup FTW !! I researched the Aeromotive A1000: A pump controller is needed to bring the duty cycle down when crusing / idle to lengthen pump life, otherwise your pump will need an early replacement The Bosch 044 can be used @ 100% DC and it may last longer. Surge tank : Speedmachine performance.com ~$150 Pump: eBay, web ~$220 fittings / hoses : Jegs, Summit, ANplumbing.com ~$lots (get good fittings Earls, Aeroquip, not the generic Jegs or Summit brands!) I recommend the Teflon tubing/Steel braided lines http://www.anplumbing.com/shop/index...ept=Speed-Flex http://www.anplumbing.com/shop/index...-Seal-Aluminum My Setup (GT35R / 1000cc) Large pic: http://subaru-wrx-sti.com/web/MODS/B...ytemlayout.jpg other pics: http://subaru-wrx-sti.com/web/MODS/f...ne-routing.jpg |
11-13-2007, 01:25 PM | #19 |
Member#: 92582
MWSOC
Vehicle:* |
^^^Holy crap! Thanks for that info, that is exactly what I was looking for. That explains everything that my dumbass had a question about. Thanks again!
11-13-2007, 01:52 PM | #20 |
Member#: 42614
SCIC
Another of my diagrams: *dual lines from FPR to surge tank: I used stock return line *dual lines from surge tank to OEM tank: I used single -06 line *I added an Aeromotive 10 micron after-pump filter, keep your injectors clean! *don't quote me on pricing... those are ballpark, I'm not responsible if you end up spending all your yearly allowance or if your car explodes (my disclaimer) large http://subaru-wrx-sti.com/web/MODS/f...emdiagram2.jpg glad to help! that's what the forums are for.... to ask dumbass questions and get intelligent answers Weeeeeeeeee vsssssssssss weeeeeeee sssssssssssss That's the noise most big pumps make (except the Weldons but those are mucho$$$) - you get used to it, usually it gets lost amidst the exhaust, suspension, turbo, radio noises..... I compared my in-cabin fuel pump noise levels of one of my buddies IN-Tank Bosch 044.... I'm pretty happy about mounting the pump outside, under the car. Serves 2 purposes: 1. "Safer" - not 100% - But .... the HIGH-pressure line starts outside the car, you still have the tank-to-surge tank line. But minimizing high pressure lines inside passenger compartment is always a good thing. 2. Quieter inside car Take your time deciding, and make a list of parts you will need, draw a diagram listing parts, it will save you time & money in the long run Good luck ! Last edited by engineerx; 11-13-2007 at 02:04 PM. |
12-06-2007, 12:21 AM | #21 | |
Member#: 145145
MWSOC
Vehicle:2006 wrx STi |
Also, the surge tank is cool as far as making sure you have a good fuel sump. However, is there a problem you have noticed with fuel heating? If you take the bypass fuel and dump it right back into the surge tank, and proceed to re pump; it will pick up heat, it doesn't mix and exchange heat with the mass amounts of fuel in the tank (assuming, no overflow is taking place) |
12-06-2007, 11:15 AM | #22 | |
Member#: 126242
TXIC
Vehicle:2005 STi/2012 GTR TXIC's most loved |
I plan on running mine under the car, though. |
03-08-2008, 04:29 PM | #23 | |
Member#: 42614
SCIC
In addition, the frigging noise these pumps make is quite alot BBBBBBHHHHH...BBHHHHHHH.... BHHHHHH !! by placing it under the car the noise doesn't transmit as much as having the pump inside the trunk or even inside the tank. One of my buddies has his 044 in-tank and it's noisier than where I mounted mine Also I think I'm going to leave the rear seat cushions on at all times.... just in case I get arse-ended hard, don't want all that California 91 piss gass to end up inside the cabin another routing diagram pic I made, to help those who have questions about surge tank setups there might be better setups so always good to research all available options. Alright, so I get asked very frequently about what fittings to use, where to get them, etc. Here's the answer - Hope that helps: Yeah, there's no easy way to go from the 8mm (5/16") OEM pump hanger lines to AN hoses. You have to use multiple fittings to get to a 5/16" barb fitting. The nicest way would be using bulkhead fittings and eliminate the hanger hard lines but as you said it's more costly and more work. like this http://forums.nasioc.com/forums/show...5&postcount=80 I ended up using the following From OEM in-tank pump: 5/16" fuel rubber hose - 5/16" barb x 3/8" NPT - 3/8" NPT female coupler - 3/8" NPT male x -6AN - -6AN hose to surge tank same fittings for the return line, make a list of all the stuff you need so you place 1 order from Summit and only pay the handling fee of $10 once. *keep in mind the lightweight braided hose lets the fumes escape out thru the rubber hose and stink up the inside of your car with gas fumes, use steel braided good quality hose like Earl's or Aeroquip. I ended up using teflon lined hose http://www.summitracing.com/search/B.../?autoview=SKU parts http://www.summitracing.com/parts/AE...5/?image=large or http://www.summitracing.com/parts/MAA-9-38021/ http://www.summitracing.com/parts/EAR-991003ERL/ http://www.summitracing.com/parts/SUM-220648/ Last edited by engineerx; 10-01-2009 at 04:49 PM. Reason: A lot of questions from fellow members :) |
11-13-2007, 02:12 PM | #24 |
Member#: 109527
Trouble is you have to catch the failing pump instantly or your in the crap.
I want a control board that will shut down or send an ecu signal as soon as one fails. I have really resigned myself to getting a big weldon pump. |
11-13-2007, 02:14 PM | #25 | |
Member#: 33782
MAIC
also working on my own meth kit with them. failsafes are a must |
Similar Threads | ||||
Need APS fuel system and tumbler deletes to use APS fuel rails? | GoRacerXGo | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 06-17-2005 02:07 AM |
Difference between fuel SYSTEM cleaner and fuel INJECTOR cleaner? | burnout555 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 12-17-2003 11:52 AM |
Maximum HP on stock RS fuel system with walbro fuel pump | Chav | Normally Aspirated with bolt-on Forced Induction Powertrain | 11 | 06-17-2002 03:42 PM |
fuel system managment system | jeffsnyder | Normally Aspirated Powertrain | 2 | 09-23-2001 01:13 PM |
Fuel Injectors / Fuel system | JC SPORTS | Technical Forum Archive | 75 | 07-14-2000 08:51 PM |
