11-05-2011, 12:13 AM | #301 |
Member Sales Rating: (49)
Member#: 55252
SCIC
Vehicle:* pullup bar * |
^^^ya, those look quite thin
i was considering repurchasing another set of urethanes as i regret selling the ones i originally had but now..
11-05-2011, 06:52 AM | #302 |
Vendor Sales Rating: (1)
Member#: 44856
Vehicle:1999 Impreza WRX Rally Blue |
Hi Big-E.
Thank you for your continued support and participation in this years Scoobies for Boobies campaign. In response to your question, the 02-07 UR's you are referencing have been the same since their release in 2006. The clearance specifically incorporated into the front, allows for a wider ranger of aftermarket wheel compliance and compatibility - without sacrificing any outer coverage. Example (GR) As you may already be aware, the Classic application's characteristics are much "stiffer", do not require additional mounting within the confines of the wheel well area. The UR's are much more flexible and the clearance helps avoid any tire interference. Thanks much Team R/A
__________________
Rallyarmor® LLC To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
11-23-2011, 08:46 AM | #303 |
Member Sales Rating: (2)
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
I bought Rally Armor's Motorsport Spec mudflaps and fitted them.
They are twice as thick, and provided both the outside (vertical) and bottom (horizontal) coverage I wanted. They are very nice, very durable, actually cut-down on some road-noise, and are not inexpensive. As compared to the regular UR's (left is front, right is rear): MSpec installed, front and rear: Taken from Rally Armor's Website: Last edited by Big-E; 05-20-2014 at 09:23 PM. |
01-05-2012, 11:07 PM | #304 | |
Member Sales Rating: (11)
Member#: 304299
NESIC
Vehicle:2018 2018 sti, black 2014 Crosstrek, tangerine |
03-12-2012, 11:40 PM | #306 |
Member#: 310707
SCIC
Vehicle:2012 WRX Hatch WR Blue Pearl |
Just installed these on my 2012 WRX.
Some thoughts on installation: - Give yourself a good three hours to install these if you've never done it before. Make sure you have some place out of the sun for the install - I can't imagine baking in the sun doing the install. -Get the offset screwdriver that RA sells...and also get some stubby screw drivers. -Do the fronts first... Much harder than the rears. Might as well be in a great mood when you get done, and the rears are much easier. - You will be scared of breaking something when you pull off the lower skirt. As a result, it will take you forever because you won't pull hard enough. Eventually, frustration will allow you to dial in the right amount of force. - You don't need to take the wheels off.. But you will want to reorient the front wheels at various times depending on what you're trying to do. For the rears, the inner most screw is a pain to fasten...so take off the rear wheels OR just fasten that portion of the bracket to the mud flap before mounting it up. - Instead of eyeballing the rears for being level, just get a level measure - make sure the ground is level, and then use the level on the mud flaps. - There's a video online that goes you how to do it... Their advice on the rear is much harder than just following the instructions that RA provides. |
05-06-2014, 08:58 PM | #307 |
Member#: 366932
Vehicle:2012 WRX PBP |
Going to bump this up to write a nice review.
This weekend I caught a curb while parking. It pinched the mudflap between the wheel and the curb and pulled it right off. Upon inspection though, it was just a bit scuffed up. The urethane must have stretched enough to allow it to slip over the washer and mounting nut, preventing any real damage. When I got home I pulled the bracket off to straighten it a bit, and slipped the flap right back on. Good as new. I was impressed and have been very happy with the product. |
08-26-2016, 07:25 PM | #308 |
Member#: 442160
Vehicle:2016 WRX Limited Man CWP |
Anyone else having this issue with their RA Mudflaps? They are practically melting on me. Not sure if it's the weather or manufacturer defect. Been cleaning them thoroughly every couple of months but it doesn't look good at all. Looked great the first couple of months. Bought these in March and they are not holding up well at all.
What should I do? http://imgur.com/spuUa4b.jpg http://imgur.com/DqXyj4N.jpg http://imgur.com/bCL9qA4.jpg http://imgur.com/UF9oxwl.jpg |
08-26-2016, 08:59 PM | #310 | |
Member#: 442160
Submitted a ticket to RA and received a very quick response.
Damn good customer support response if you ask me. Last edited by TehRegulator; 08-26-2016 at 10:20 PM. |
08-27-2016, 07:55 PM | #311 |
Member#: 453305
Vehicle:2016 Impreza Sport White |
looking for white mud flaps
I'm trying to keep a more stock look & don't like them black with white lettering. Is there a solid white low profile mud flap someone would recommend?
01-23-2017, 05:54 PM | #313 |
Member#: 440246
Vehicle:2016 WRX Limited Crystal White Pearl |
I currently have the black with red letters and was thinking of pulling the trigger on the white with red to go with a white and red theme but I'm glad I saw this thread before I actually pulled the trigger though!
08-15-2021, 11:58 AM | #316 |
Member#: 526081
Recently bought a set of UR’s and they look great. I had to go back and re adjust them i dnt like how they sometimes look uneven (like cambered out) on other cars i like them parallel to the car. Overall they look great. Keep em’ clean!
02+ Rally Armor Mud Flaps, Rally Lightbar | WgnWheel | SWIC Private Classifieds | 6 | 04-10-2009 12:18 PM |
WTT 06 2.5i sedan factory mud flaps for Rally Armor mud flaps | SubieCubed | Tri-State Area Private Classifieds | 3 | 03-29-2007 07:22 AM |
Installed: 06 STI - Rally armor mud flaps, PICS... | FleaDog | Interior & Exterior Modification | 17 | 11-04-2005 06:12 PM |
Rally Armor Mud Flaps for 02-06 WRX/STi | forgedSTi | Private 'For Sale' Classifieds | 6 | 10-16-2005 12:35 AM |
Rally Armor Mud Flaps, Now Available! | AZP Installs | Tri-State Area Vendor Classifieds | 12 | 10-24-2004 12:41 AM |
