04-19-2021, 03:00 AM | #1 |
Member#: 516780
Vehicle:2008 Subaru wrx sti WRB |
Did I ruin it?
Brand new garrett gtx3582r Gen 2 pre drilling for boost source nipple and the one time in my life the bit is sharp when I don't want it to be. FML?
04-19-2021, 11:59 AM | #2 |
Member#: 193940
Vehicle:2004 WRX STI Black RalliSpec Shortblock |
Ah man, I want to say you should be fine, but to be honest, there might be a leak.
04-19-2021, 12:00 PM | #3 |
Member#: 30804
SWIC
Vehicle:87 Yugo Red |
Show me a pic of the mating surface? Is there an o-ring?
04-19-2021, 03:41 PM | #4 |
Member#: 516780
There is a large orange oring that looks like it sits on that lip. I'll post a Pic when I get home. There is still a tiny ledge there and I've smoothed off the metal there so it doesn't damage the oring and in hopes to still give it a surface to seal too.
04-21-2021, 08:52 PM | #5 |
Member#: 515308
Lil epoxy or even rtv
04-21-2021, 10:46 PM | #6 |
Member#: 516780
U don't think that would get sucked into the engine do you?
04-22-2021, 12:35 AM | #7 |
Member#: 515308
If it was me I wouldn’t sweat it, prob wouldn’t make it past the intercooler, and one hell of a chance if it did it would go right through the engine.
I would tell a customer to replace it cause it’s not my $$ so there is no reason to suggest anything else. I’d put rtv in the hole |
04-22-2021, 06:18 AM | #8 |
Member#: 275099
NESIC
Vehicle:2015 STI Limited CWP |
Put it back together, cap off one end, boost leak test from the other.
04-22-2021, 05:53 PM | #9 |
Member#: 30804
SWIC
It's pretty much under pressure all the time so it'll be pushing out against that wall so I don't think you'll have any issues.
04-26-2021, 08:59 AM | #10 | ||
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
Compressors make pressure! So the most force that seal will be seeing is the direction to try and push it out of the housing. I wouldn't have any fear of this getting suck into the compressor wheel, chopped up into tiny bits and then lodging themselves in you intercooler. |
04-26-2021, 09:40 AM | #11 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
IIRC that o-ring pushes to the outer edge of the compressor cover, so that notch will have little if any impact on the seal.
05-22-2021, 02:38 AM | #12 |
Member#: 489016
Vehicle:2015 STI Silver |
